Issue with dolfinx.fem.create_matrix
I am trying to use dolfinx.fem.create_matrix, but its giving me an error. This code is based on the fenicsx tutorial for phase field analysis.
E_alpha = ufl.derivative(total_energy,alpha,ufl.TestFunction(V_alpha))
E_alpha_alpha = ufl.derivative(E_alpha,alpha,ufl.TrialFunction(V_alpha))
damage_problem = SNESProblem(E_alpha, E_alpha_alpha, alpha, bcs_alpha)
b = dolfinx.cpp.la.create_vector(V_alpha.dofmap.index_map, V_alpha.dofmap.index_map_bs)
J = dolfinx.fem.create_matrix(damage_problem.a)
# Create Newton solver and solve
solver_alpha_snes = PETSc.SNES().create()
solver_alpha_snes.setType("vinewtonrsls")
solver_alpha_snes.setFunction(damage_problem.F, b)
solver_alpha_snes.setJacobian(damage_problem.J, J)
solver_alpha_snes.setTolerances(rtol=1.0e-9, max_it=50)
solver_alpha_snes.getKSP().setType("preonly")
solver_alpha_snes.getKSP().setTolerances(rtol=1.0e-9)
solver_alpha_snes.getKSP().getPC().setType("lu")
# We set the bound (Note: they are passed as reference and not as values)
solver_alpha_snes.setVariableBounds(alpha_lb.vector,alpha_ub.vector)
This is the error I am getting
TypeError                                 Traceback (most recent call last)
Input In [11], in <module>
      1 E_alpha = ufl.derivative(total_energy,alpha,ufl.TestFunction(V_alpha))
      2 E_alpha_alpha = ufl.derivative(E_alpha,alpha,ufl.TrialFunction(V_alpha))
----> 4 damage_problem = SNESProblem(E_alpha, E_alpha_alpha, alpha, bcs_alpha)
      6 b = dolfinx.cpp.la.create_vector(V_alpha.dofmap.index_map, V_alpha.dofmap.index_map_bs)
      7 J = dolfinx.fem.create_matrix(damage_problem.a)
File /workspaces/newfrac-core-numerics/snes_problem.py:30, in SNESProblem.__init__(self, F, J, u, bcs)
     26 self.u = u
     28 # Create matrix and vector to be used for assembly
     29 # of the non-linear problem
---> 30 self.A = dolfinx.fem.create_matrix(self.a)
     31 self.b = dolfinx.fem.create_vector(self.L)
File /usr/local/dolfinx-real/lib/python3.8/dist-packages/dolfinx/fem/assemble.py:87, in create_matrix(a, mat_type)
     85 def create_matrix(a: FormMetaClass, mat_type=None) -> PETSc.Mat:
     86     if mat_type is None:
---> 87         return _cpp.fem.petsc.create_matrix(a)
     88     else:
     89         return _cpp.fem.petsc.create_matrix(a, mat_type)
TypeError: create_matrix(): incompatible function arguments. The following argument types are supported:
    1. (a: dolfinx::fem::Form<double>, type: str = '') -> mat
Invoked with: Form([Integral(CoefficientDerivative(CoefficientDerivative(Product(FloatValue(0.5), Inner(ComponentTensor(Product(Indexed(Sum(ComponentTensor(Product(Indexed(Sym(Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2)), 3))), MultiIndex((Index(8), Index(9)))), Product(FloatValue(2.0), Division(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 0), Product(FloatValue(2.0), Sum(FloatValue(1.0), Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 1)))))), MultiIndex((Index(8), Index(9)))), ComponentTensor(Product(Indexed(Identity(2), MultiIndex((Index(10), Index(11)))), Product(Division(Product(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 0), Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 1)), Sum(FloatValue(1.0), Product(IntValue(-1), Power(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 1), IntValue(2))))), Trace(Sym(Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2)), 3)))))), MultiIndex((Index(10), Index(11))))), MultiIndex((Index(12), Index(13)))), Sum(FloatValue(1e-06), Power(Sum(IntValue(1), Product(IntValue(-1), Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4))), IntValue(2)))), MultiIndex((Index(12), Index(13)))), Sym(Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2)), 3))))), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0, None),)), ExprMapping(*())), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None),)), ExprMapping(*())), 'cell', Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), 'everywhere', {}, None), Integral(CoefficientDerivative(CoefficientDerivative(Product(Sum(Product(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 3), Dot(Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4)), Grad(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4)))), Division(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4), Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 3))), Division(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (), 2), FloatValue(2.6666666666666665))), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0, None),)), ExprMapping(*())), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None),)), ExprMapping(*())), 'cell', Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), 'everywhere', {}, None), Integral(CoefficientDerivative(CoefficientDerivative(Product(IntValue(-1), Dot(Constant(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), (2,), 4), Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2)), 3))), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 0, None),)), ExprMapping(*())), ExprList(*(Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 4),)), ExprList(*(Argument(FunctionSpace(Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), FiniteElement('Lagrange', triangle, 1)), 1, None),)), ExprMapping(*())), 'cell', Mesh(VectorElement(FiniteElement('Lagrange', triangle, 1), dim=2), 0), 'everywhere', {}, None)])
As shown in: dolfinx/test_nonlinear_assembler.py at 611361eb24a6b8f6a9480b2034f53dc67feecf7e · FEniCS/dolfinx · GitHub
you need to call fem.form(E_alpha) and fem.form(E_alpha_alpha).
The reason for this is explained in:
and suggested input parameters to fem.form is highlighted in
https://jorgensd.github.io/dolfinx-tutorial/chapter4/compiler_parameters.html
