In trying to run a modified version of the poisson-subdomain tutorial, I now get an error.
In trying to run
with XDMFFile(MPI.comm_world, "ps_mesh.xdmf") as xdmf_infile:
mesh = xdmf_infile.read(dolfin.cpp.mesh.GhostMode.none)
mvc_subdomain = xdmf_infile.read_mvc_size_t(mesh, "subdomain")
tag_info = xdmf_infile.read_information_int()
I get
File "demo_poisson_subdomain.py", line 156, in <module>
AttributeError: module 'dolfin.cpp.mesh' has no attribute 'GhostMode'
as an error. Can someone shed light on how to fix this?
If it helps, the relevant packages in my pip3 list are
fenics-dijitso 2019.1.0
fenics-dolfin 2019.1.0
fenics-dolfinx 2019.2.0.dev0
fenics-ffc 2019.1.0.post0
fenics-ffcx 2019.2.0.dev0
fenics-fiat 2019.2.0.dev0
fenics-ufl 2019.2.0.dev0
See this test which highlight the change in interface
Noted. I’ve changed MPI
to be imported from mpi4py
as opposed to dolfin
or dolfinx
, and replaced MPI.comm_world
by MPI.COMM_WORLD
I still get the same error as before. Trying but importing dolfinx without dolfin (is dolfinx intended as a replacement of or as an extension to dolfin?), upon running
with XDMFFile(MPI.COMM_WORLD, "ps_mesh.xdmf") as xdmf_infile:
mesh = xdmf_infile.read(dolfinx.cpp.mesh.GhostMode.none)
I get
File "demo_poisson_subdomain.py", line 155, in <module>
TypeError: read(): incompatible function arguments. The following argument types are supported:
1. (self: dolfin.cpp.io.XDMFFile, arg0: dolfin.cpp.mesh.Mesh) -> None
2. (self: dolfin.cpp.io.XDMFFile, mf: dolfin.cpp.mesh.MeshFunctionBool, name: str = '') -> None
3. (self: dolfin.cpp.io.XDMFFile, mf: dolfin.cpp.mesh.MeshFunctionSizet, name: str = '') -> None
4. (self: dolfin.cpp.io.XDMFFile, mf: dolfin.cpp.mesh.MeshFunctionInt, name: str = '') -> None
5. (self: dolfin.cpp.io.XDMFFile, mf: dolfin.cpp.mesh.MeshFunctionDouble, name: str = '') -> None
6. (self: dolfin.cpp.io.XDMFFile, mvc: dolfin.cpp.mesh.MeshValueCollection_bool, name: str = '') -> None
7. (self: dolfin.cpp.io.XDMFFile, mvc: dolfin.cpp.mesh.MeshValueCollection_sizet, name: str = '') -> None
8. (self: dolfin.cpp.io.XDMFFile, mvc: dolfin.cpp.mesh.MeshValueCollection_int, name: str = '') -> None
9. (self: dolfin.cpp.io.XDMFFile, mvc: dolfin.cpp.mesh.MeshValueCollection_double, name: str = '') -> None
Invoked with: <dolfin.cpp.io.XDMFFile object at 0x7f6d47149d70>, GhostMode.none
You should not mix dolfin and dolfinx. Dolfin is the stable release of the FEniCS project. Dolfinx is the development version, see https://fenicsproject.org/fenics-project-roadmap-2019/ .
As shown in the link in my previous reply, this is how you should load meshes in dolfinx
with XDMFFile(MPI.COMM_WORLD, filename, 'r') as xdmf:
