Efficient way to convert data from numpy to fenics Function
assuming a function
mesh = IntervalMesh(comm, 10, 0.0, 0.1)
u_0 = Constant(1.0)
u_n = interpolate(u_0, V)
What would be the fastest way to convert its values to a numpy array and back?
Converting the function’s value to a numpy array:
In [5]: time u_n.vector()[:]
CPU times: user 85 µs, sys: 60 µs, total: 145 µs
Wall time: 160 µs
Out[5]: array([1., 1., 1., 1., 1., 1., 1., 1., 1., 1., 1.])
time u_n.vector().get_local()
CPU times: user 58 µs, sys: 40 µs, total: 98 µs
Wall time: 105 µs
Out[6]: array([1., 1., 1., 1., 1., 1., 1., 1., 1., 1., 1.])
In [7]: %timeit u_n.vector()[:]
4.85 µs ± 35.4 ns per loop (mean ± std. dev. of 7 runs, 100000 loops each)
In [8]: %timeit u_n.vector().get_local()
5.01 µs ± 156 ns per loop (mean ± std. dev. of 7 runs, 100000 loops each)
Alternatively, using an Expression:
In [20]: expression_form = Expression("1.0", element=V.ufl_element())
n [21]: time interpolate(expression_form, V).vector()[:]
CPU times: user 528 µs, sys: 0 ns, total: 528 µs
Wall time: 537 µs
Out[21]: array([1., 1., 1., 1., 1., 1., 1., 1., 1., 1., 1.])
In [22]: time interpolate(expression_form, V).vector().get_local()
CPU times: user 521 µs, sys: 0 ns, total: 521 µs
Wall time: 530 µs
Out[22]: array([1., 1., 1., 1., 1., 1., 1., 1., 1., 1., 1.])
In [23]: %timeit interpolate(expression_form, V).vector()[:]
97.9 µs ± 1.92 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
In [24]: %timeit interpolate(expression_form, V).vector().get_local()
95.1 µs ± 854 ns per loop (mean ± std. dev. of 7 runs, 10000 loops each)
Defining the value of the function from a numpy array:
In [10]: %timeit  u_n.vector()[:] = np.array([0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10])
36.9 µs ± 1 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
In [12]: %timeit  u_n.vector().get_local()[:] = np.array([0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10])
8.21 µs ± 13.3 ns per loop (mean ± std. dev. of 7 runs, 100000 loops each)
As my model demands several of these convertions, I’m wondering if there’s a more efficient way of doing it to improve performance. Any idea/thought about this is appreciated. Thanks!
If you’re this concerned about performance, I’d recommend manipulating the data using PETSc directly, and avoiding python altogether.
This has been discussed in the fenics slack channel:
  1. set_local/vector the problem is set_local expects List[float] and when you pass F this F has magic getitem python method. It is implicitly lazy-calling F[0], F[1], F[2], … to get that List[float] and this is passed to set_local. Not only is List[float] not local in memory but its terrible to iterate over etc etc.
    (You can call set_local on some wrong arguments to see all possible signatures)
    set_local: 1. (self: dolfin.cpp.la.GenericVector, arg0: List[float]) → None
  2. set_local/get_local is a bit better, because F.get_local will be numpy array (yupii), however it will copy underlying data array to produce that numpy array. It is copy operation and also probably a conversion of numpy array to List[float] what you see here.
  3. array/get_local even better, because vector setitem interface allows to be set from numpy array, the only thing this you see here is copying numpy array on F.get_local call.
    setitem: 3. (self: dolfin.cpp.la.GenericVector, arg0: slice, arg1: numpy.ndarray[float64]) → None
  4. array/vector even better, because setitem has also following signature
    setitem: 2. (self: dolfin.cpp.la.GenericVector, arg0: slice, arg1: dolfin.cpp.la.GenericVector) → None
    which means you are assigning a Vector directly, i.e. doing just one copy assignment operation in cpp layer.
Thanks, but avoiding python is not an option for me …
Thanks a lot for your answer!
