Eigen solver syntax in dolfin-x
I cannot reproduce this with Paraview 5.10.0-RC2
I would suggest you first:
  1. Remove the old eigenvector.xdmf and eigenvector.h5
  2. Use the following code instead:
xdmf = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "eigenvector.xdmf", "w")
xdmf.write_mesh(mesh)
eig_v = []
ef = 0
print("Number of converged eigenpairs %d" % evs)
if evs > 0:
    for i in range(evs):
        e_val = eigensolver.getEigenpair(i, vr, vi)
        if (~np.isclose(e_val.real, 1.0)):
            # Calculation of eigenfrequency from real part of eigenvalue
            freq_3D = np.sqrt(e_val.real)/2/np.pi
            # Beam eigenfrequency
            if ef % 2 == 0:
                # exact solution should correspond to weak axis bending
                I_bend = H*B**3/12.
                # exact solution should correspond to strong axis bending
                I_bend = B*H**3/12.
            freq_beam = alpha(ef/2)**2*np.sqrt(E*I_bend/(rho*B*H*L**4))/2/np.pi
            print(
                "Solid FE: {0:8.5f} [Hz] "
                "Beam theory: {1:8.5f} [Hz]".format(freq_3D, freq_beam))
            ur = dolfinx.fem.Function(V)
            ur.vector.array[:] = vr
            xdmf.write_function(ur.copy())
            eig_v.append(vr.copy())
            ef += 1
xdmf.close()
as you want to keep the xdmf file open until you are done writing the data.
Sir, Can you rerun this code.
import sys
import slepc4py
from scipy.optimize import root
from slepc4py import SLEPc
from dolfinx.mesh import CellType, locate_entities_boundary, create_box
from dolfinx.fem import (Constant, dirichletbc, Function, VectorFunctionSpace,
                         locate_dofs_topological,assemble_matrix, form)
from ufl import (TrialFunction, TestFunction, Identity, inner, dot, nabla_div,
                 nabla_grad, dx)
slepc4py.init(sys.argv)
L, B, H = 5., 0.3, 0.6
mesh = create_box(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([L, H, B])],
    [25, 3, 2],
    cell_type=CellType.tetrahedron)
E, nu = (2E11), (0.3)
rho = (7850)
mu = E/2./(1+nu)
lambda_ = E*nu/(1+nu)/(1-2*nu)
def sigma(u):
    return lambda_ * nabla_div(u) * Identity(u.geometric_dimension()) \
           + 2*mu*epsilon(u)
V = VectorFunctionSpace(mesh, ("CG", 2))
def clamped_boundary(x):
    return np.isclose(x[0], 0)
fdim = mesh.topology.dim - 1
boundary_facets = locate_entities_boundary(mesh, fdim, clamped_boundary)
u_D = Function(V)
with u_D.vector.localForm() as loc:
    loc.set(0)
bc = dirichletbc(u_D, locate_dofs_topological(V, fdim, boundary_facets))
T = Constant(mesh, (PETSc.ScalarType(0), PETSc.ScalarType(0),
                    PETSc.ScalarType(0)))
k_form= form(inner(sigma(u), epsilon(v)) * dx)
K = assemble_matrix(k_form, bcs=[bc])
K.assemble()
m_form = form(rho*dot(u, v)*dx)
M = assemble_matrix(m_form, bcs=[bc])
M.assemble()
shift = SLEPc.ST().create(MPI.COMM_WORLD)
shift.setType('sinvert')  # spectral transform
shift.setShift(0.0)  # spectral shift
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
eigensolver.setDimensions(nev=50)
eigensolver.setProblemType(2)
eigensolver.setST(shift)
eigensolver.setType('krylovschur')  # Solver type
eigensolver.setWhichEigenpairs(7)  # Target Real
eigensolver.setConvergenceTest(2)
eigensolver.setOperators(K, M)
eps_type = eigensolver.getType()
print("Solution method: %s" % eps_type)
problem_type = eigensolver.getProblemType()
print("Problem type: %s" % problem_type)
which_eigenpairs = eigensolver.getWhichEigenpairs()
print("Eigenpairs type: %s" % which_eigenpairs)
eigensolver.solve()
evs = eigensolver.getConverged()
vr, vi = K.createVecs()
# Exact solution computation
def falpha(x):
    return np.cos(x) * np.cosh(x) + 1
def alpha(n):
    return root(falpha, (2*n + 1)*np.pi/2)['x'][0]
import dolfinx.io
eig_v = []
ef = 0
if evs > 0:
            if ef % 2 == 0:
                I_bend = H*B**3/12.
                I_bend = B*H**3/12.
            print(
            ef += 1
xdmf.close()
I am getting white contour of eigen vector with Paraview 5.10.0
