Eigenvalue solver problem
Hi everyone,
i have a question about defining the number of eigenvalues in a simple eigenvalue problem in dolfin-x.
in this code:
from dolfinx.plotting import plot
from dolfinx import DirichletBC, Function, FunctionSpace, UnitSquareMesh, RectangleMesh
from dolfinx.fem import assemble_matrix, Form
from ufl import TrialFunction, TestFunction, grad, dx, dot
from slepc4py import SLEPc
from dolfinx.cpp.mesh import CellType
from math import sqrt
from dolfinx.mesh import locate_entities_boundary
from dolfinx.fem import (apply_lifting, assemble_matrix, assemble_vector,
                         locate_dofs_topological, set_bc)
nev=38
mesh = RectangleMesh(
    MPI.COMM_WORLD,
    [np.array([0, 0, 0]), np.array([1, 1, 0])], [10, 10],
    cell_type=CellType.triangle)
V = FunctionSpace(mesh, ("CG", 2))
a = dot(grad(u), grad(v))*dx
A = assemble_matrix(a,[])
eigensolver = SLEPc.EPS().create(MPI.COMM_WORLD)
eigensolver.setDimensions(nev)
eigensolver.setWhichEigenpairs(2)
eigensolver.setOperators(A)
eigensolver.solve()
for i in range (nev):
    l = eigensolver.getEigenpair(i)
    print(l.real)
there is some problems with some specific numbers.
for example for " nev = 38 " or " nev = 39 " there is this error:
Error                                     Traceback (most recent call last)
<ipython-input-10-8401c9868766> in <module>
     38
     39 for i in range (nev):
---> 40     l = eigensolver.getEigenpair(i)
     41     print(l.real)
SLEPc/EPS.pyx in slepc4py.SLEPc.EPS.getEigenpair()
Error: error code 63
[0] EPSGetEigenpair() line 411 in /usr/local/slepc/src/eps/interface/epssolve.c
[0] Argument out of range
[0] Argument 2 out of range
but for the numbers lower than 38 or more than 40 it can compute the eigenvalues and there is not any error.
so, I can not understand the reason of the error for some specific numbers.
Thanks
Looks like you forgot to set the problem type. Adding
eigensolver.setProblemType(SLEPc.EPS.ProblemType.HEP)
will give some numbers at least.
Dear @nate
Thanks for your help and sorry for the delay.
by adding Dirichlet Boundary Condition and two matrices as input parameters of “EPSSetOperators()”, the code can not runs properly when I am trying to collect the eigenvalues from smallest to largest values ( eigensolver.setWhichEigenpairs(2) ). But when I am trying to collect them from the largest to smallest values ( eigensolver.setWhichEigenpairs(1) ) there is not any problem and the code runs properly. I could not find any way to solve the problem.
In the following I have attached the codes and its outputs.
from dolfinx.fem import (apply_lifting, assemble_matrix, assemble_vector, locate_dofs_topological, set_bc)
nev=15
mesh = RectangleMesh(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([0.01, 0.01, 0])], [100, 100], cell_type=CellType.triangle)
b = u*v*dx
m0 = Function(V)
def boundary(x):
    return np.full(x.shape[1], True)
facets = locate_entities_boundary(mesh, 1, boundary)
bc = DirichletBC(m0, locate_dofs_topological(V, 1, facets))
A = assemble_matrix(a, bcs=[bc])
B = assemble_matrix(b, bcs=[bc])
B.assemble()
eigensolver.setProblemType(SLEPc.EPS.ProblemType.GHEP)
eigensolver.setOperators(A,B)
eigensolver.solve()
    l = eigensolver.getEigenvalue(i)
    print(l.real)
the result is:
12884606589.887491
12884606589.860409
12880572884.786907
12880572884.766441
12880160603.670452
12880160602.680973
12876235995.878403
12876235994.537903
12873321949.421896
12873321949.389496
12873206723.191608
12873206720.327929
12869827520.723207
12869827520.722536
12868483436.616455
​and by changing “eigensolver.setWhichEigenpairs(1)” to “eigensolver.setWhichEigenpairs(2)” to collect the eigenvalues from the smallest to largest values there is an error:
<ipython-input-6-ae37569cdb16> in <module>
     47
     48 for i in range (nev):
---> 49     l = eigensolver.getEigenvalue(i)
     50     print(l.real)
SLEPc/EPS.pyx in slepc4py.SLEPc.EPS.getEigenvalue()
[0] EPSGetEigenvalue() line 450 in /usr/local/slepc/src/eps/interface/epssolve.c
I’m running into a similar problem right now. Are you sure that assembling both A & B with the same boundary conditions is right ? I don’t know what dolfinx does under the rug, but I have a feeling it could be wrong.
As for your current problem (maybe the term is not so appropriate now) I would use eigensolver.setWhichEigenpairs(eigensolver.Which.SMALLEST_MAGNITUDE) as well as calling eigensolver.getConverged() before trying to print anything.
