Hello
I have been using dolfin to find the eigenvalues of a 2x2 ufl tensor and it’s been working great. I now need to use dolfinx for a 3x3 tensor as the calculation involves complex numbers.
In dolfin I use the following piece of code to determine whether I have the right eigenvalues in 2D:
def e1(A):
return ((tr(A) + sqrt(tr(A)**2-4*det(A)))/2)
def e2(A):
return ((tr(A) - sqrt(tr(A)**2-4*det(A)))/2)
S = FunctionSpace(mesh, 'CG', 2)
Ca = Expression((('5','2'),('2', '1')), degree=0)
C = project(e1(Ca), S)
vertex_values = C.compute_vertex_values(mesh)
for i, x in enumerate(mesh.coordinates()):
print(x, C(x))
Here is the code I have written in dolfinx to find the eigenvalues of a 3D tensor. Can someone tell me where I’m going wrong?
from dolfinx import mesh
from dolfinx import fem
C = ufl.as_matrix([[-2, -4, 2], [-2, 1, 2], [4, 2, 5]])
a = -1
b = ufl.tr(C)
c = -0.5*((ufl.tr(C))**2-ufl.tr(C*C))
d = ufl.det(C)
del_0 = b**2 - 3*a*c
del_1 = 2*(b**3) - 9*a*b*c + 27*(a**2)*d
C_pos = (0.5*(del_1+ufl.sqrt (del_1**2-4*del_0**3) ))**(1/3)
prim = 0.5*(-1+ufl.sqrt(-3))
x0 = (-1/3*a)*(b+C_pos+(del_0/C_pos))
x1 = (-1/3*a)*(b+prim*C_pos+(del_0/(prim*C_pos)))
x2 = (-1/3*a)*(b+(prim**2)*C_pos+(del_0/((prim**2)*C_pos)))
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
uD = fem.Function(V, dtype=np.complex128)
uD.interpolate(fem.Expression(ufl.real(x0), V.element.interpolation_points, dtype=np.complex128))
The corresponding error message is:
AttributeError Traceback (most recent call last)
Input In [2], in <cell line: 32>()
29 V = fem.FunctionSpace(domain, ("CG", 1))
30 uD = fem.Function(V, dtype=np.complex128)
---> 32 uD.interpolate(fem.Expression(ufl.real(x0), V.element.interpolation_points, dtype=np.complex128))
File /usr/local/dolfinx-complex/lib/python3.10/dist-packages/dolfinx/fem/function.py:98, in Expression.__init__(self, ufl_expression, X, form_compiler_params, jit_params, dtype)
68 def __init__(self, ufl_expression: ufl.core.expr.Expr, X: np.ndarray,
69 form_compiler_params: dict = {}, jit_params: dict = {},
70 dtype=PETSc.ScalarType):
71 """Create DOLFINx Expression.
72
73 Represents a mathematical expression evaluated at a pre-defined
95
96 """
---> 98 assert X.ndim < 3
99 num_points = X.shape[0] if X.ndim == 2 else 1
100 _X = np.reshape(X, (num_points, -1))
AttributeError: 'builtin_function_or_method' object has no attribute 'ndim'
Thanks in advance,
Will.
