Eikonal equation
Hi everyone!
I am trying to calculate the distance from each point to the upper and lower walls using the Eikonal equation.
My code:
from dolfinx import fem
from dolfinx import mesh, fem, io, nls, log
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
def walls(x):
    a = np.isclose(x[1],0)
    b = np.isclose(x[1],1)
    return np.logical_or(a,b)
fdim = domain.topology.dim -1
wall_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, walls)
wall_f = dolfinx.fem.locate_dofs_topological(V, fdim, wall_facets)
ubc = fem.Function(V)
bc = fem.dirichletbc(ubc, wall_f)
d = fem.Function(V)
F = (ufl.dot(ufl.grad(d), ufl.grad(d)) - 1) * v * ufl.dx
problem = NonlinearProblem(F, d, bcs=[bc])
solver = NewtonSolver(domain.comm, problem)
solver.rtol = 1e-6
solver.max_it = 100
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}ksp_rtol"] = 1.0e-8
opts[f"{option_prefix}pc_type"] = "hypre"
opts[f"{option_prefix}pc_hypre_type"] = "boomeramg"
opts[f"{option_prefix}pc_hypre_boomeramg_max_iter"] = 1
opts[f"{option_prefix}pc_hypre_boomeramg_cycle_type"] = "v"
ksp.setFromOptions()
# Resolver el problema
num_iterations, converged = solver.solve(d)
But I am getting a null solution…
Does anyone have any ideas??
Thank you so much!
Your variatonal form is not correct, as you are missing a sqrt.
Solving the unsmoothed version of the eikonal equations are notoriously difficult. Usually, one smooths the equation by adding a Laplace operator.
See:
and
https://fenicsproject.org/qa/1446/distance-to-boundary/
Me and collaborators are working on a new mixed method/variational form for solving the Eikonal equation. I will post it here once we have a preprint out.
I’m trying to adding a Lapalce operator and get:
that it is not the distance to the walls…
This is my new code:
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 100, 100)
def walls(x):
d0 = ufl.TrialFunction(V)
f = fem.Constant(domain, PETSc.ScalarType(1.0))
a = ufl.inner(ufl.grad(d0), ufl.grad(v)) * ufl.dx
L = ufl.inner(f, v) * ufl.dx
problem = fem.petsc.LinearProblem(a, L, bcs=[bc])
d0 = problem.solve()
hmax = 1e-6
d = fem.Function(V)
d.x.array[:] = d0.x.array[:]
eps = fem.Constant(domain, PETSc.ScalarType(hmax / 100))
F = ufl.sqrt(ufl.dot(ufl.grad(d), ufl.grad(d)) - f) * v * ufl.dx + eps*ufl.inner(ufl.grad(d), ufl.grad(v))*ufl.dx
solver.rtol = 1e-6
solver.max_it = 100
Please be more careful when writing up your variational form, as there is yet another typo:
should be
F = ufl.sqrt(ufl.dot(ufl.grad(d), ufl.grad(d)))*v*ufl.dx - f * v * ufl.dx + eps*ufl.inner(ufl.grad(d), ufl.grad(v))*ufl.dx
which yields
I just tried your formula and I get my same result as above…
Please check that your solver actually converges.
Here is the complete code I ran:
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 20, 20)
V = fem.functionspace(domain, ("CG", 1))
def walls(x):
hmax = 1e-6
d = fem.Function(V)
solver.rtol = 1e-6
solver.max_it = 100
dolfinx.log.set_log_level(dolfinx.log.LogLevel.INFO)
with io.XDMFFile(domain.comm, "eikonal.xdmf","w") as writer:
    writer.write_mesh(domain)
    writer.write_function(d)
