On a 3D domain, I want to explicitly assemble Neumann boundary conditions using
gmshwithPhysical Surfacesdolfin-convertto convert from.mshto thedolfininput files- and a
dolfin.MeshFunctionto assess boundary measuresds
What works well on one example, simply fails on another example (see the code below). The returned measure is just empty.
Even more difficult for me to understand, if I use the same MeshFunction in dolfin.DirichletBC definitions, the resulting values are not empty.
I suspect that there are many pitfalls in treating meshes and boundary conditions. But maybe someone has an idea how to go about this issue.
Here is the example. The mesh karman3D... does not work, whereas the 4-segs-... mesh works (in the sense that the Neumann boundaries do not appear empty)
Please see here for downloading the meshes and this code snippet.
Btw. Iām using dolfin 2019
import dolfin
import scipy.sparse as sps
meshlevel = 1
meshprfx = 'karman3D_lvl{0}'.format(meshlevel) # not working
meshprfx = '4-segs-3D_lvl{0}'.format(meshlevel) # working
meshfile = meshprfx + '.xml.gz'
physregs = meshprfx + '_physical_region.xml.gz'
fctsregs = meshprfx + '_facet_region.xml.gz'
mesh = dolfin.Mesh(meshfile)
boundaries = dolfin.MeshFunction('size_t', mesh, fctsregs)
subdomains = dolfin.MeshFunction('size_t', mesh, physregs)
# a Paraview file to check the facet numbering
pvd = dolfin.File('mf.pvd')
pvd << boundaries
ds = dolfin.Measure('ds', subdomain_data=boundaries)
V = dolfin.FunctionSpace(mesh, 'CG', 1)
# checking as Dirichlet type
bcexp = dolfin.Expression("1", degree=1)
for diripe in range(15):
diribcs = dolfin.DirichletBC(V, bcexp, boundaries, diripe)
bcdict = diribcs.get_boundary_values()
bcvals = []
bcvals.extend(bcdict.values())
print(f'id:{diripe} -- Dirichlet valsum: {np.array(bcvals).sum()}')
# checking as Neumann type
v = dolfin.TestFunction(V)
for pe in range(15):
obsop = dolfin.assemble(v*ds(pe)).get_local().reshape((1, V.dim()))
obsopmat = sps.csc_matrix(obsop)
print(f'id:{pe} -- Neumann valsum: {obsopmat.sum()}')
