Neumann BC for 2 conductors
I have a question about Neumann boundary conditions.
I have a 2D plot in a room where the bottom is the ground with Dirichlet BC = 0 and 2 electrical conductors with a positive voltage and a negative voltage. The surface of the conductors should contain the Neumann boundary condition. I can’t get both conditions to be executed.
Here is the code. Unfortunately it is a bit big.
But only the bottom part is important.
#Mesh Erzeugung:(mit GMSH)
from dolfinx import mesh
import warnings
warnings.filterwarnings("ignore")
from dolfinx import fem
from dolfinx import nls
from dolfinx import log
from dolfinx import io
from dolfinx.cpp.mesh import to_type, cell_entity_type
from dolfinx.fem import Constant, Function, FunctionSpace, assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector, create_vector, set_bc
from dolfinx.graph import create_adjacencylist
from dolfinx.geometry import BoundingBoxTree, compute_collisions, compute_colliding_cells
from dolfinx.io import (XDMFFile, cell_perm_gmsh, distribute_entity_data, extract_gmsh_geometry,
                        extract_gmsh_topology_and_markers, ufl_mesh_from_gmsh)
from dolfinx import geometry
from dolfinx.mesh import create_mesh, meshtags_from_entities
from ufl import SpatialCoordinate, TestFunction, TrialFunction, dot, ds, dx, grad
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym)
import tqdm.notebook
import scipy.constants as c
#Domain-Definieren:
L =24.
H =18.
c_x1 = 8.
c_y1 = 13.
r1 = 0.01
c_x2 = 16.
c_y2 = 13.
r2 = 0.001
gdim = 2
rank = MPI.COMM_WORLD.rank
if rank == 0:
    rectangle = gmsh.model.occ.addRectangle(0,0,0, L, H, tag=1)
    obstacle1 = gmsh.model.occ.addDisk(c_x1, c_y1, 0, r1, r1)
    obstacle2 = gmsh.model.occ.addDisk(c_x2, c_y2, 0, r2, r2)
if rank == 0:
    Mesh_domain = gmsh.model.occ.cut([(gdim, rectangle)], [(gdim, obstacle1), (gdim, obstacle2)])
    gmsh.model.occ.synchronize()
#Verbinden aller Mesh-Punkte
Mesh_domain_marker = 1
if rank == 0:
    gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], Mesh_domain_marker)
    gmsh.model.setPhysicalName(volumes[0][0], Mesh_domain_marker, "Mesh_domain")
inlet_marker, outlet_marker, wall_marker, obstacle1_marker,obstacle2_marker, wall_top = 2, 3, 4, 5, 6, 7
inflow, outflow, walls, obstacle1, obstacle2 , top = [], [], [], [], [], []
if rank == 0:
    for boundary in boundaries:
        if np.allclose(center_of_mass, [0, H/2, 0]):
            inflow.append(boundary[1])
        elif np.allclose(center_of_mass, [L, H/2, 0]):
            outflow.append(boundary[1])
        elif  np.allclose(center_of_mass, [L/2, 0, 0]):
            walls.append(boundary[1])
        elif np.allclose(center_of_mass, [L/2, H, 0]):
            top.append(boundary[1])
        elif np.allclose(center_of_mass, [c_x1, c_y1, 0]):
            obstacle1.append(boundary[1])
        elif np.allclose(center_of_mass, [c_x2, c_y2, 0]):
            obstacle2.append(boundary[1])
    gmsh.model.setPhysicalName(1, inlet_marker, "Inlet")
    gmsh.model.addPhysicalGroup(1, outflow, outlet_marker)
    gmsh.model.setPhysicalName(1, outlet_marker, "Outlet")
    gmsh.model.addPhysicalGroup(1, obstacle1, obstacle1_marker)
    gmsh.model.setPhysicalName(1, obstacle1_marker, "Obstacle1")
    gmsh.model.addPhysicalGroup(1, obstacle2, obstacle2_marker)
    gmsh.model.setPhysicalName(1, obstacle2_marker, "Obstacle2")
    gmsh.model.addPhysicalGroup(1, top, wall_top)
    gmsh.model.setPhysicalName(1, wall_top, "top")
if rank == 0:
    gmsh.option.setNumber('Mesh.MeshSizeMin', 2e-1)
    gmsh.option.setNumber('Mesh.MeshSizeMax', 2e-1)
    gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 8)
    gmsh.option.setNumber("Mesh.RecombineAll", 2)
    gmsh.option.setNumber("Mesh.SubdivisionAlgorithm", 1)
if MPI.COMM_WORLD.rank == 0:
    # Mesh Geometrie
    x = extract_gmsh_geometry(gmsh.model)
    # Topologie für jedes Element vom Mesh
    topologies = extract_gmsh_topology_and_markers(gmsh.model)
    num_cell_types = len(topologies.keys())
    cell_information = {}
    cell_dimensions = np.zeros(num_cell_types, dtype=np.int32)
    for i, element in enumerate(topologies.keys()):
        properties = gmsh.model.mesh.getElementProperties(element)
        name, dim, order, num_nodes, local_coords, _ = properties
        cell_information[i] = {"id": element, "dim": dim, "num_nodes": num_nodes}
        cell_dimensions[i] = dim
    # Sort elements by ascending dimension
    perm_sort = np.argsort(cell_dimensions)
    # Broadcast cell type data and geometric dimension
    cell_id = cell_information[perm_sort[-1]]["id"]
    tdim = cell_information[perm_sort[-1]]["dim"]
    num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
    cell_id, num_nodes = MPI.COMM_WORLD.bcast([cell_id, num_nodes], root=0)
    if tdim - 1 in cell_dimensions:
        num_facet_nodes = MPI.COMM_WORLD.bcast( cell_information[perm_sort[-2]]["num_nodes"], root=0)
        gmsh_facet_id = cell_information[perm_sort[-2]]["id"]
        marked_facets = np.asarray(topologies[gmsh_facet_id]["topology"], dtype=np.int64)
        facet_values = np.asarray(topologies[gmsh_facet_id]["cell_data"], dtype=np.int32)
    cells = np.asarray(topologies[cell_id]["topology"], dtype=np.int64)
    cell_values = np.asarray(topologies[cell_id]["cell_data"], dtype=np.int32)
    cell_id, num_nodes = MPI.COMM_WORLD.bcast([None, None], root=0)
    cells, x = np.empty([0, num_nodes], np.int64), np.empty([0, gdim])
    cell_values = np.empty((0,), dtype=np.int32)
    num_facet_nodes = MPI.COMM_WORLD.bcast(None, root=0)
    marked_facets = np.empty((0, num_facet_nodes), dtype=np.int64)
    facet_values = np.empty((0,), dtype=np.int32)
# Create distributed mesh
ufl_domain = ufl_mesh_from_gmsh(cell_id, gdim)
gmsh_cell_perm = cell_perm_gmsh(to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm]
mesh = create_mesh(MPI.COMM_WORLD, cells, x[:, :gdim], ufl_domain)
tdim = mesh.topology.dim
fdim = tdim - 1
# Permute facets from MSH to DOLFINx ordering
facet_type = cell_entity_type(to_type(str(ufl_domain.ufl_cell())), fdim, 0)
gmsh_facet_perm = cell_perm_gmsh(facet_type, num_facet_nodes)
marked_facets = np.asarray(marked_facets[:, gmsh_facet_perm], dtype=np.int64)
local_entities, local_values = distribute_entity_data(mesh, fdim, marked_facets, facet_values)
adj = create_adjacencylist(local_entities)
bb_tree = geometry.BoundingBoxTree(mesh, mesh.topology.dim)
# Create DOLFINx MeshTags
ft = meshtags_from_entities(mesh, fdim, adj, np.int32(local_values))
ft.name = "Facet tags"
#Funktionspace und Vektorfunktionspace defenieren
s_cg1 = FiniteElement("CG", mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, s_cg1)
V_E= fem.VectorFunctionSpace(mesh, ("DG", 0))
fdim = mesh.topology.dim - 1
E_cp = -16.5e5
E_cn = 16.5e5
#Boundary conditions definieren
# Walls
u1_nonslip = np.array((0,) *mesh.geometry.dim, dtype=PETSc.ScalarType)
u11_nonslip = np.array((0,) *mesh.geometry.dim, dtype=PETSc.ScalarType)
wall_facets = ft.indices[ft.values == wall_marker]
bc_walls = dirichletbc(PETSc.ScalarType(0), locate_dofs_topological(V, fdim, wall_facets), V)
#Boundary conditions for equations:
bcwall = [bc_walls]
#Laplace
u1 = ufl.TrialFunction(V)
v1 = ufl.TestFunction(V)
dObt = Measure("ds", domain=mesh, subdomain_data=ft, subdomain_id=obstacle1_marker)
dObs = Measure("ds", domain=mesh, subdomain_data=ft, subdomain_id=obstacle2_marker)
a = ufl.inner(ufl.grad(u1), ufl.grad(v1)) * ufl.dx
x = SpatialCoordinate(mesh)
L =  ufl.inner(E_cp, v1) * dObs + ufl.inner(E_cn,v1) * dObt
problem1 = fem.petsc.LinearProblem(a, L, bcwall, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
phi = problem1.solve()
print("phi_max: ", np.max(phi.x.array), " / phi_min: ", np.min(phi.x.array))
print(phi.x.array)
with io.VTKFile(mesh.comm, "Laplace.pvd", "w") as vtk:
    vtk.write([phi._cpp_object])
with io.XDMFFile(mesh.comm, "Laplace.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_function(phi)
Start by making sure that the facet markers are correct by visualizing ft in Paraview.
then assemble simple forms such as dolfinx.fem.assemble_scalar(dolfinx.fem.form(1*dObt)) and dolfinx.fem.assemble_scalar(dolfinx.fem.form(1*dObs)) and check that they give reasonable results
How do I visualize ft in ParaView?
Is that what you mean?
k = Constant(mesh, PETSc.ScalarType(0))
f = k/c.epsilon_0
fem.assemble_scalar(fem.form(1*dObt))
fem.assemble_scalar(fem.form(1*dObs))
u1 = fem.Function(V)
ft can be written to an XDMFFile as shown in dolfinx/demo_gmsh.py at 2be366d20632377e0688df585fcd7e201d5dc86c · FEniCS/dolfinx · GitHub
I have checked the ft and it seems to be ok.
Do you have any idea why it still doesn’t work?
I do not have time to parse though a code of over 200 lines to find a potential typo. I would suggest starting with one of the tutorials, which as verification checks:
https://jorgensd.github.io/dolfinx-tutorial/chapter3/robin_neumann_dirichlet.html
and do incremental adjustments to the code to get to your problem.
I have changed the geometry of the 2d space and now it works with the 2 Neumann boundary conditions.
I just do not know how.
Thank you for the good support!
