Hi all,
I am perseverating in my effort to port this notebook to Fenicsx. There are still numberless rough edges (e.g. as I understand there is no LocalSolver in Fenics I need to do code the projection myself, I think it is just a matter of a simple weak form but just to get it going I am brutally interpolating for now). Also, I am very unsure on how to translate assemble from Dolfin, and eventually I found some posts on the same error suggesting compliance = fem.assemble_scalar(fem.form(ufl.action(L, uh)) ) . I honestly have not fully understood at all the necessity for fem.form , but at least I do not get a syntax error, the sooner I get it at least running I am hopeful I can try to make more sense of it.
Anyhow, I got close to the end without syntax errors at least, but I now get an error which I cannot get an idea about. This is the code, I have to attach it all including the optimisation loop as the simple elastic problem works solved over one iterations works fine
from dolfinx import *
from dolfinx.fem import FunctionSpace, Function
from dolfinx.fem import VectorFunctionSpace
from dolfinx import fem, io
from dolfinx import mesh
from dolfinx.mesh import CellType, create_rectangle
#from dolfinx.la import solver
# Algorithmic parameters
niternp = 20 # number of non-penalized iterations
niter = 80 # total number of iterations
pmax = 4 # maximum SIMP exponent
exponent_update_frequency = 4 # minimum number of steps between exponent update
tol_mass = 1e-4 # tolerance on mass when finding Lagrange multiplier
thetamin = 0.001 # minimum density modeling void
# Mesh
L = 5
domain = create_rectangle(MPI.COMM_WORLD, np.array([[0,0],[3*L, L]]), [30,30], cell_type=CellType.triangle)
tdim = domain.topology.dim
fdim = tdim - 1
# Problem parameters
thetamoy = 0.4 # target average material density
E = fem.Constant(domain, ScalarType(1))
nu = fem.Constant(domain, ScalarType(0.3))
lamda = E*nu/(1+nu)/(1-2*nu)
mu = E/(2*(1+nu))
# Traction and body forces
f = fem.Constant(domain, ScalarType([0,-1])) # vertical downwards force
body = fem.Constant(domain, ScalarType((0, 0.1)))
# Function space for density field
V0 = fem.FunctionSpace(domain, ("DG", 0))
# Function space for displacement
V2 = fem.VectorFunctionSpace(domain, ("CG", 2))
# Definition for boundary conditions
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V2, fdim, boundary_facets), V2)
def left(x):
def right(x):
return np.isclose(x[0], 3*L)
fdim = domain.topology.dim -1
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
# SIMP parameters
p = fem.Constant(domain, ScalarType(1)) # SIMP penalty exponent
exponent_counter = 0 # exponent update counter
lagrange = fem.Constant(domain, ScalarType(1))# Lagrange multiplier for volume constraint
thetaold.x.set(thetamoy)
coeff = thetaold**p
theta = Function(V0)
volume = fem.assemble_scalar(fem.form(thetaold*ufl.dx))
avg_density_0 = fem.assemble_scalar(fem.form(thetaold*ufl.dx))/volume
avg_density = 0.
thetaold = Function(V0, name="Density")
# Functions definitions for weak form
def eps(v):
return ufl.sym(ufl.grad(v))
def sigma(v):
return coeff*(lamda*ufl.nabla_div(v)*ufl.Identity(2)+2*mu*eps(v))
# return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2*mu*epsilon(u)
def energy_density(u, v):
return ufl.inner(sigma(u), eps(v))
# Inhomogeneous elastic variational problem
u_ = ufl.TestFunction(V2)
du = ufl.TrialFunction(V2)
#a = ufl.inner(sigma(u_), eps(du))*ufl.dx
a = ufl.inner(sigma(u_), eps(du)) * ufl.dx
L = ufl.dot(f, u_)*ds(2)
# Functions for handling SIMP density field
def local_project(v, V):
dv = ufl.TrialFunction(V)
v_ = ufl.TestFunction(V)
a_proj = ufl.inner(dv, v_)*dx
b_proj = ufl.inner(v, v_)*dx
u_proj = fem.Function(V)
u_proj.interpolate(v)
# solver.solve_local_rhs(u)
return u_proj
def update_theta():
theta_new = Function(V0)
theta.x.array[:] = local_project((p*coeff*energy_density(u, u)/lagrange)**(1/(p+1)), V0).x.array
# theta.assign(local_project((p*coeff*energy_density(u, u)/lagrange)**(1/(p+1)), V0))
thetav = theta.vector().get_local()
theta.vector().set_local(np.maximum(np.minimum(1, thetav), thetamin))
theta.vector().apply("insert")
# avg_density = fem.assemble(theta*dx)/volume
avg_density = fem.assemble_scalar(fem.form(theta*ufl.dx))/volume
return avg_density
# Update Lagrange multiplier and SIMP penalty exponent
def update_lagrange_multiplier(avg_density):
avg_density1 = avg_density
# Initial bracketing of Lagrange multiplier
if (avg_density1 < avg_density_0):
lagmin = float(lagrange)
while (avg_density < avg_density_0):
lagrange.assign(fem.Constant(domain, ScalarType(lagrange/2)))
avg_density = update_theta()
lagmax = float(lagrange)
elif (avg_density1 > avg_density_0):
while (avg_density > avg_density_0):
lagrange.assign(Constant(fem.Constant(domain, ScalarType(lagrange*2))))
# Dichotomy on Lagrange multiplier
inddico=0
while ((abs(1.-avg_density/avg_density_0)) > tol_mass):
lagrange.assign(Constant((lagmax+lagmin)/2))
inddico += 1;
if (avg_density < avg_density_0):
print(" Dichotomy iterations:", inddico)
def update_exponent(exponent_counter):
exponent_counter += 1
if (i < niternp):
p.assign(fem.Constant(domain, ScalarType(1)))
elif (i >= niternp):
if i == niternp:
print("\n Starting penalized iterations\n")
if ((abs(compliance-old_compliance) < 0.01*compliance_history[0]) and
(exponent_counter > exponent_update_frequency) ):
# average gray level
gray_level = fem.assemble_scalar((theta-thetamin)*(1.-theta)*dx)*4/volume
# p.assign(Constant(min(float(p)*(1+0.3**(1.+gray_level/2)), pmax)))
p.assign(fem.Constant(domain, ScalarType (min(float(p)*(1+0.3**(1.+gray_level/2)), pmax))))
print(" Updated SIMP exponent p = ", float(p))
return exponent_counter
#### Main Iteration
u = Function(V2, name="Displacement")
old_compliance = 1e30
compliance_history = []
for i in range(niter):
problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
compliance_history.append(compliance)
print("Iteration {}: compliance =".format(i), compliance)
exponent_counter = update_exponent(exponent_counter)
# Update theta field and compliance
thetaold.assign(theta)
old_compliance = compliance
I get the error message, after solving the first elastic iteration
Couldn't map 'c_4' to a float, returning ufl object without evaluation.
I cannot figure it out what it could refer to, the traceback does not even point to the problematic code line. I got the same error earlier during the day when trying to understand how to interpolate a constant function, and I implemented the solution above, but in this case it is very unclear where it comes from.
Thanks so much
