Hi, Everyone!
Currently, I am decoupling and computing a 3D model:
E+ u\times B-(1/Rm)\curl B=g in \Omega E\times n=0 on \partial Omaga
Here, E represents the electric field, B represents the magnetic field, and u represents the velocity field. The discrete format of the equation is:
(E_h^n,F)+(u_h^n\times B_h^{n-1},F)-(1/Rm)*(B_h^n,\curl F)=(g,F)
I use the RT0 element to approximate B_h^n, the ND0(lowest-order edge element) to approximate E_h^n, and the vector P1 element to approximate u. And the B and u involved in the code are all calculated using the exact solution, but the convergence order I calculated was always incorrect. Can you help me see what’s wrong with the code?
from dolfinx import mesh, fem
from dolfinx.fem.petsc import assemble_matrix, assemble_vector, apply_lifting, create_vector, set_bc
import time
from ufl import dx, grad, dot, lhs, rhs,inner,cross,curl,ds
from basix.ufl import mixed_element,element
from numpy import sin, cos, pi, exp
# 精确解
Rm=1
left =0.0
right = 1.0
bottom = 0.0
top = 1.0
near = 0.0
far = 1.0
def ExactU(x,t):
factor = exp(-t) + 1.0
temp1=factor * sin(pi * x[0]) *sin(pi * x[1]) *sin(pi * x[2])
temp2=np.zeros_like(x[0])
temp3=factor * (x[2]**2 - x[2]) *sin(pi * x[0]) * sin(pi * x[1])
return [temp1,temp2,temp3]
def ExactE(x,t):
sint = sin(pi*t)+1.5
temp1=sint*(x[1]**2-x[1])*sin(pi*x[2])
temp2=sint*(x[0]**2-x[0])*sin(pi*x[2])
temp3=sint*(x[0]**2-x[0])*sin(pi*x[1])
def ExactB(x,t):
cost=(1/pi)*cos(pi*t)-1.5*t
temp1=cost*pi*(x[0]**2-x[0])*(cos(pi*x[1])-cos(pi*x[2]))
temp2=cost*(pi*(x[1]**2-x[1])*cos(pi*x[2])-(2*x[0]-1)*sin(pi*x[1]))
temp3=cost*(2*x[0]-2*x[1])*sin(pi*x[2])
def rhs_expr(x, t):
factor = np.exp(-t) + 1.0
sint=sin(pi*t)+1.5
cost=1/pi*cos(pi*t)-1.5*t
E1=(x[1]**2-x[1])*sin(pi*x[2])
E2=(x[0]**2-x[0])*sin(pi*x[2])
E3=(x[0]**2-x[0])*sin(pi*x[1])
u1= sin(pi * x[0]) * sin(pi * x[1]) *sin(pi * x[2])
u2= np.zeros_like(x[0])
u3= (x[2]**2 - x[2]) * sin(pi * x[0]) * sin(pi * x[1])
B1=pi*(x[0]**2-x[0])*(cos(pi*x[1])-cos(pi*x[2]))
B2=(pi*(x[1]**2-x[1])*cos(pi*x[2])-(2*x[0]-1)*sin(pi*x[1]))
B3=(2*x[0]-2*x[1])*sin(pi*x[2])
curlB1=-2*sin(pi*x[2])+pi**2*(x[1]**2-x[1])*sin(pi*x[2])
curlB2=-2*sin(pi*x[2])+pi**2*(x[0]**2-x[0])*sin(pi*x[2])
curlB3=-2*sin(pi*x[1])+pi**2*(x[0]**2-x[0])*sin(pi*x[1])
temp1=sint*E1\
+factor*cost*(u2*B3-u3*B2)\
-(1/Rm)*cost*curlB1
temp2=sint*E2\
+factor*cost*(u3*B1-u1*B3)\
-(1/Rm)*cost*curlB2
temp3=sint*E3\
+factor*cost*(u1*B2-u2*B1)\
-(1/Rm)*cost*curlB3
return [temp1, temp2,temp3]
# 固定终止时间
T = 1 / 2
# 结果记录
hs = []
errors_L2 = []
errors_max = []
errors_H1 = []
errors_curl =[]
start_time = time.time()
for i in range(3):
n = 2 ** (i + 2) # 空间划分数 n = 2^{i+2}
h = 1.0 / n
num_steps = 2 ** (2 * i + 3) # 时间划分数 tau = 2^{2i+4}
dt = T / num_steps
t = 0.0
# 创建 3D 网格(单位立方体)
domain = mesh.create_unit_cube(MPI.COMM_WORLD, n, n, n, mesh.CellType.tetrahedron)
V = fem.functionspace(domain, ("Lagrange", 1)) # 线性 Lagrange 元
Vv=fem.functionspace(domain, ("Lagrange", 1, (3, )))
# 磁场空间与电场空间的定义
VB = fem.functionspace(domain, ("RT", 1))
VE = fem.functionspace(domain, ("N1curl", 1))
E_n=fem.Function(VE)
u_n = fem.Function(Vv)
B_old = fem.Function(VB)
B_old.interpolate(lambda x: ExactB(x, t))
B_n = fem.Function(VB)
E_D = fem.Function(VE)
E_D.interpolate(lambda x: ExactE(x, t))
f_fun = fem.Function(VE)
# 施加 Dirichlet 边界条件(3D 边界)
tdim = domain.topology.dim
fdim = tdim - 1
bc = fem.dirichletbc(E_D, fem.locate_dofs_topological(VE, fdim, boundary_facets))
ns = ufl.FacetNormal(domain)
# 变分形式(3D 形式相同,但 dx 现在是 3D 积分)
E, F = ufl.TrialFunction(VE), ufl.TestFunction(VE)
G = inner(E,F)*dx + inner(cross(u_n,B_old),F)*dx- inner(f_fun,F)*dx \
- (1/Rm)*inner(B_n,curl(F))*dx
a = fem.form(lhs(G))
L = fem.form(rhs(G))
# 组装矩阵和向量
A = assemble_matrix(a, bcs=[bc])
b = create_vector(L)
E_h =fem.Function(VE)
# 定义求解器(直接法:LU 分解)
solver.setOperators(A)
# solver.setType(PETSc.KSP.Type.PREONLY)
# solver.getPC().setType(PETSc.PC.Type.LU)
solver.setType(PETSc.KSP.Type.BCGS)
pc1 = solver.getPC()
pc1.setHYPREType("boomeramg")
# 时间步进
for n_step in range(num_steps):
u_n.interpolate(lambda x:ExactU(x,t))
B_n.interpolate(lambda x: ExactB(x, t))
f_fun.interpolate(lambda x: rhs_expr(x, t))
# 更新矩阵
A.zeroEntries()
assemble_matrix(A, a, bcs=[bc])
# assemble_matrix(A, a, bcs=[bc])
# 重新组装右端向量
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, L)
# 施加边界条件
apply_lifting(b, [a], [[bc]])
set_bc(b, [])
# 求解线性系统
solver.solve(b, E_h.x.petsc_vec)
E_h.x.scatter_forward()
# 计算误差(在更高阶空间)
V_dg = fem.functionspace(domain, ("Lagrange", 1, (3,)))
# V_dg = fem.functionspace(domain, ("N1curl", 2))
E_ex = fem.Function(V_dg)
E_ex.interpolate(lambda x: ExactE(x,t))
E_ex1 = fem.Function(VE)
E_ex1.interpolate(lambda x:ExactE(x,t))
# L2 误差
error_L2 = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form((E_h - E_ex)**2 * ufl.dx)), op=MPI.SUM))
error_max= np.max(np.abs(E_ex1.x.array - E_h.x.array))
error_curl = np.sqrt(domain.comm.allreduce(fem.assemble_scalar(fem.form(curl(E_h - E_ex)**2*dx)), op=MPI.SUM))
if MPI.COMM_WORLD.rank == 0:
hs.append(h)
errors_L2.append(error_L2)
errors_max.append(error_max)
errors_curl.append(error_curl)
print(f"[i={i}] n={n}, num_steps={num_steps}, dt={dt:.3e}, h={h:.3e}")
print(f" → L2 error = {error_L2:.3e}, max error={error_max:.3e},curl error={error_curl:.3e}")
end_time = time.time() # 计时结束
elapsed = end_time - start_time
# 输出收敛阶
print("\nEstimated convergence rates (L2):")
for j in range(1, len(hs)):
r1 = np.log(errors_L2[j-1]/errors_L2[j]) / np.log(hs[j-1]/hs[j])
r2 = np.log(errors_max[j-1]/errors_max[j]) / np.log(hs[j-1]/hs[j])
r3 = np.log(errors_curl[j-1]/errors_curl[j]) / np.log(hs[j-1]/hs[j])
print(f"h={hs[j-1]:.3e} → h={hs[j]:.3e}, rate ≈ {r1:.2f},rate ≈ {r2:.2f},rate ≈ {r3:.2f}")
print(f"\nTotal runtime: {elapsed:.2f} seconds")
Looking forward to your reply!
