Hello everyone,
I am trying to compile some dolfin cpp code that includes vtk headers in python, as in the example below:
import dolfin
cpp = """
#include <pybind11/eigen.h>
#include <dolfin/function/Expression.h>
#include <dolfin/mesh/MeshFunction.h>
#include <vtkPolyData.h> // this include seems to produce the error
#include <vtkPointData.h>
class MeshExpr : public dolfin::Expression
public:
MeshExpr() : dolfin::Expression() {}
void eval() {}
PYBIND11_MODULE(SIGNATURE, m)
pybind11::class_<MeshExpr, std::shared_ptr<MeshExpr>, dolfin::Expression>(m, "MeshExpr")
.def(pybind11::init<>());
module = dolfin.compile_cpp_code(cpp)
I tried to run this code on ubuntu 20.04 with two different setup:
- using dolfin 2019.1.0 from ubuntu packages and vtk 9.1 built from source
- using conda with dolfin 2019.1.0 and vtk 9.0.1
In both cases I obtain the same error:
File "test.py", line 30, in <module>
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/pybind11jit.py", line 95, in compile_cpp_code
module, signature = dijitso_jit(cpp_code, module_name, params,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 50, in mpi_jit
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py", line 106, in dijitso_jit
return dijitso.jit(*args, **kwargs)
File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 212, in jit
lib = load_library(signature, cache_params)
File "/usr/lib/python3/dist-packages/dijitso/cache.py", line 363, in load_library
lib = __import__(signature)
ImportError: /home/colin/.cache/dijitso/lib/dolfin_cpp_module_15eebeeafcd4861f4a013c9eef458e55.so: undefined symbol: _ZN31vtkObjectFactoryRegistryCleanupD1Ev
I don’t have this issue on macOS with conda.
Thanks in advance for your help!
