I found an example of aI found an example of a monopole array antenna, but importing vtkplotter.dolfin got an error when I ran the code
I think it is the version problem, but i do not how to solve it.
my dolfin version is 2019.2.0.dev0
Please add the code in plaintext with 3x` encapsulation, and Also the full trace of your error messagw
import cmath as cm
import os, sys, traceback
a = 2.25
b = 0.5;
d = 0.3;
s = 0.5;
l = 10.0;
w = 3.0;
pi = 3.1415926536
tol = 1.0e-12
eta = 377.0
Dk = 1.0
qoffset = 0.0
poffset = 1.75
class PEC(SubDomain):
return on_boundary
class InputBC(SubDomain):
return on_boundary and near(x[2], -1, tol)
class OutputBC(SubDomain):
rb = sqrt(x[0] * x[0] + (x[1] + 1.25)* (x[1] + 1.25) + x[2] * x[2])
return on_boundary and near(rb, 10.0, 5.0e-2)
class PMC(SubDomain):
return on_boundary and (near(x[0], 0.0, tol) or near(x[1], -1.25, tol))
mesh = Mesh()
with XDMFFile(âmesh.xdmfâ) as infile:
infile.read(mesh)
mvc = MeshValueCollection(âsize_tâ, mesh, 3)
info(mesh)
#plot(mesh)
#plt.show()
Mark boundaries
sub_domains = MeshFunction(âsize_tâ, mesh, mesh.topology().dim() - 1)
sub_domains.set_all(4)
pec = PEC()
pec.mark(sub_domains, 0)
in_port = InputBC()
in_port.mark(sub_domains, 1)
out_port = OutputBC()
out_port.mark(sub_domains, 2)
pmc = PMC()
pmc.mark(sub_domains, 3)
File(âBoxSubDomains.pvdâ).write(sub_domains)
dk = 0.025
#for m in range(40):
for m in range(1):
K = 0.500 + m * dk
K = 0.5
k0 = Constant(K)
beta = K
b0 = Constant(beta)
Kr = Dk
Set up function spaces
For low order problem
cell = tetrahedron
ele_type = FiniteElement(âN1curlâ, cell, 2) # H(curl) element for EM
V2 = FunctionSpace(mesh, MixedElement([ele_type, ele_type]))
V = FunctionSpace(mesh, ele_type)
u_r, u_i = TrialFunctions(V2)
v_r, v_i = TestFunctions(V2)
#surface integral definitions from boundaries
ds = Measure(âdsâ, domain = mesh, subdomain_data = sub_domains)
with source and sink terms
u0 = Constant((0.0, 0.0, 0.0)) #PEC definition
h_src = Expression((â-(x[1] - poffset) / (2.0 * pi * (pow((x[0]-qoffset), 2.0) + pow(x[1] - poffset,2.0)))â, â(x[0]-qoffset) / (2.0 * pi *(pow((x[0]-qoffset),2.0) + pow(x[1] - poffset,2.0)))â, 0.0), degree = 2, poffset = poffset, qoffset = qoffset)
e_src = Expression((â(x[0] - qoffset) / (2.0 * pi * (pow((x[0]-qoffset), 2.0) + pow(x[1] - poffset,2.0)))â, â(x[1]-poffset) / (2.0 * pi *(pow((x[0]-qoffset),2.0) + pow(x[1] - poffset,2.0)))â, 0.0), degree = 2, poffset = poffset, qoffset = qoffset)
Rrad = Expression((âsqrt(x[0] * x[0] + (x[1] + 1.25) * (x[1] + 1.25) + x[2] * x[2])â), degree = 2)
#Boundary condition dictionary
boundary_conditions = {0: {âPECâ : u0},
1: {âInputBCâ: (h_src, Dk)},
2: {âOutputBCâ: Rrad},
3: {âPMCâ: 0.0}}
#Build PEC boundary conditions for real and imaginary parts
bcs =
for i in boundary_conditions:
if âPECâ in boundary_conditions[i]:
bc = DirichletBC(V2.sub(0), boundary_conditions[i][âPECâ], sub_domains, i)
bcs.append(bc)
bc = DirichletBC(V2.sub(1), boundary_conditions[i][âPECâ], sub_domains, i)
bcs.append(bc)
Build input BC source term and loading term
integral_source =
integrals_load =
if âInputBCâ in boundary_conditions[i]:
r, s = boundary_conditions[i][âInputBCâ]
bb1 = 2.0 * k0 * eta * inner(v_i, cross(n, r)) * ds(i) #Factor of two from field equivalence principle
integral_source.append(bb1)
bb2 = inner(cross(n, v_i), cross(n, u_r)) * b0 * ds(i)
integrals_load.append(bb2)
bb2 = inner(-cross(n, v_r), cross(n, u_i)) * b0 * ds(i)
if âOutputBCâ in boundary_conditions[i]:
r = boundary_conditions[i][âOutputBCâ]
bb2 = (inner(cross(n, v_i), cross(n, u_r)) * k0 + 0.5 * inner(cross(n, v_i), cross(n, u_i)) / r)* ds(i)
bb2 = (inner(-cross(n, v_r), cross(n, u_i)) * k0 + 0.5 * inner(cross(n, v_r), cross(n, u_r)) / r)* ds(i)
for PMC, do nothing. Natural BC.
af = (inner(curl(v_r), curl(u_r)) + inner(curl(v_i), curl(u_i)) - Kr * k0 * k0 * (inner(v_r, u_r) + inner(v_i, u_i))) * dx + sum(integrals_load)
L = sum(integral_source)
u1 = Function(V2)
vdim = u1.vector().size()
print("Vdim = ", vdim)
solve(af == L, u1, bcs, solver_parameters = {âlinear_solverâ : âmumpsâ})
u1_r, u1_i = u1.split(True)
fp = File(âEField_r.pvdâ)
fp << u1_r
fp = File(âEField_i.pvdâ)
fp << u1_i
fp = File(âSIWWaveFile.pvdâ)
ut = u1_r.copy(deepcopy=True)
for i in range(50):
ut.vector().zero()
ut.vector().axpy(-sin(pi * i / 25.0), u1_i.vector())
ut.vector().axpy(cos(pi * i / 25.0), u1_r.vector())
fp << (ut, i)
H = interpolate(h_src, V) # Get input field
P = assemble((-dot(u1_r,cross(curl(u1_i),n))+dot(u1_i,cross(curl(u1_r),n))) * ds(2))
P_refl = assemble((-dot(u1_i,cross(curl(u1_r), n)) + dot(u1_r, cross(curl(u1_i), n))) * ds(1))
P_inc = assemble((dot(H, H) * 0.5 * eta * b0 / k0) * ds(1))
print("k0 = ", K)
print("Beta = ", beta)
print(âIntegrated power on rad boundary:â, P/(2.0 * K * eta))
print(âIncident power at port 1:â, P_inc)
print(âIntegrated reflected power on port 1:â, P_inc - P_refl / (2.0 * K * eta))
eps_c = 1.0
lc = 1.0
E = interpolate(e_src, V) # Incident E field
ccr = assemble(-dot(u1_r - E * (eta / sqrt(eps_c)), E * (eta / sqrt(eps_c))) * ds(1))
cci = assemble(dot(u1_i, E) * ds(1)) * eta / sqrt(eps_c)
cc = assemble(dot(E, E) * ds(1)) * eta * eta / eps_c
Zo = 50.0
rho = complex(ccr / cc, cci / cc)
print(âInput port reflection coefficient: {0:<f}+j{1:<f}â.format(rho.real, rho.imag))
Zin = Zo * (1.0 + rho) / (1.0 - rho)
print(âInput port impedance: {0:<f} + j{1:<f}â.format(Zin.real, Zin.imag))
Zl = Zo * (Zin - (1j) * Zo * tan(K * sqrt(eps_c) * lc)) / (Zo - (1j) * Zin * tan(K * sqrt(eps_c) * lc))
print(âAntenna feedpoint impedance: {0:<f} + j{1:<f}â.format(Zl.real, Zl.imag))
Generate radiation pattern!
print(âGenerate radiation pattern.â)
metadata = {âquadrature_degreeâ: 6, âquadrature_schemeâ: âdefaultâ}
dsm = ds(metadata=metadata)
NumTheta = 25
NumPhi = 100
TwoPi = 6.2831853071
PiOverTwo = 1.5707963268
fp = open(âMonoPattern1.txtâ, âwâ)
print(â#Elevation Azimuth Pvert Phorizâ, file = fp)
Reflection transformations
PMC
JCx = Constant(((-1.0, 0.0, 0.0), (0.0, 1.0, 0.0), (0.0, 0.0, 1.0))) # PMC Reflection thru x = 0 plane
#JCy = Constant(((-1.0, 0.0, 0.0), (0.0, 1.0, 0.0), (0.0, 0.0, -1.0))) # PEC Reflection thru y = -5 plane
JCy = Constant(((1.0, 0.0, 0.0), (0.0, -1.0, 0.0), (0.0, 0.0, 1.0))) # PMC Reflection thru y = -5 plane
MCx = Constant(((1.0, 0.0, 0.0), (0.0, -1.0, 0.0), (0.0, 0.0, -1.0)))
#MCy = Constant(((1.0, 0.0, 0.0), (0.0, -1.0, 0.0), (0.0, 0.0, 1.0)))
MCy = Constant(((-1.0, 0.0, 0.0), (0.0, 1.0, 0.0), (0.0, 0.0, -1.0)))
PEC ground plane
JCz = Constant(((-1.0, 0.0, 0.0), (0.0, -1.0, 0.0), (0.0, 0.0, 1.0))) #PEC reflection thru z = 0 plane
MCz = Constant(((1.0, 0.0, 0.0), (0.0, 1.0, 0.0), (0.0, 0.0, -1.0)))
Surface currents on external boundary
M_r = -cross(n, u1_r)
M_i = -cross(n, u1_i)
J_r = -cross(n, curl(u1_i)) / (k0 * eta)
J_i = cross(n, curl(u1_r)) / (k0 * eta)
for m in range(NumTheta+1):
theta = m * PiOverTwo / NumTheta
print(" ", file = fp) # for Gnuplot
for nn in range(NumPhi+1):
L_r = #List objects for integrals
L_i =
N_r =
N_i =
Do NFF transformation
phi = nn * TwoPi / NumPhi
rr = Expression(('sin(theta)*cos(phi)', 'sin(theta)*sin(phi)', 'cos(theta)'), degree = 3, phi = phi, theta = theta)
rtheta = Expression(('cos(theta)*cos(phi)', 'cos(theta)*sin(phi)', '-sin(theta)'), degree = 3, phi = phi, theta = theta)
rphi = Expression(('-sin(phi)', 'cos(phi)', '0.0'), degree = 3, phi = phi)
Sum up all the image sources taking into account the proper symmetries
First octant
rp1 = Expression(('x[0]', 'x[1]+1.25', 'x[2]'), degree = 1)
sr = J_r * cos(k0 * dot(rr, rp1)) - J_i * sin(k0 * dot(rr, rp1))
si = J_i * cos(k0 * dot(rr, rp1)) + J_r * sin(k0 * dot(rr, rp1))
N_r.append(sr)
N_i.append(si)
qr = M_r * cos(k0 * dot(rr, rp1)) - M_i * sin(k0 * dot(rr, rp1))
qi = M_i * cos(k0 * dot(rr, rp1)) + M_r * sin(k0 * dot(rr, rp1))
L_r.append(qr)
L_i.append(qi)
Second octant x < 0, y > 0, z > 0
rp2 = Expression(('-x[0]', 'x[1]+1.25', 'x[2]'), degree = 1)
sr = JCx * (J_r * cos(k0 * dot(rr, rp2)) - J_i * sin(k0 * dot(rr, rp2)))
si = JCx * (J_i * cos(k0 * dot(rr, rp2)) + J_r * sin(k0 * dot(rr, rp2)))
N_r.append(sr)
N_i.append(si)
qr = MCx * (M_r * cos(k0 * dot(rr, rp2)) - M_i * sin(k0 * dot(rr, rp2)))
qi = MCx * (M_i * cos(k0 * dot(rr, rp2)) + M_r * sin(k0 * dot(rr, rp2)))
L_r.append(qr)
L_i.append(qi)
third octant x < 0, y < 0, z > 0
rp3 = Expression(('-x[0]', '-x[1]-1.25', 'x[2]'), degree = 1)
sr = JCy * JCx * (J_r * cos(k0 * dot(rr, rp3)) - J_i * sin(k0 * dot(rr, rp3)))
si = JCy * JCx * (J_i * cos(k0 * dot(rr, rp3)) + J_r * sin(k0 * dot(rr, rp3)))
N_r.append(sr)
N_i.append(si)
qr = MCy * MCx * (M_r * cos(k0 * dot(rr, rp3)) - M_i * sin(k0 * dot(rr, rp3)))
qi = MCy * MCx * (M_i * cos(k0 * dot(rr, rp3)) + M_r * sin(k0 * dot(rr, rp3)))
L_r.append(qr)
L_i.append(qi)
fourth octant x > 0, y < 0, z > 0
rp4 = Expression(('x[0]', '-x[1]-1.25', 'x[2]'), degree = 1)
sr = JCy * (J_r * cos(k0 * dot(rr, rp4)) - J_i * sin(k0 * dot(rr, rp4)))
si = JCy * (J_i * cos(k0 * dot(rr, rp4)) + J_r * sin(k0 * dot(rr, rp4)))
N_r.append(sr)
N_i.append(si)
qr = MCy * (M_r * cos(k0 * dot(rr, rp4)) - M_i * sin(k0 * dot(rr, rp4)))
qi = MCy * (M_i * cos(k0 * dot(rr, rp4)) + M_r * sin(k0 * dot(rr, rp4)))
L_r.append(qr)
L_i.append(qi)
Fifth octant x > 0, y > 0, z < 0
rp5 = Expression(('x[0]', 'x[1]+1.25', '-x[2]'), degree = 1)
sr = JCz * (J_r * cos(k0 * dot(rr, rp5)) - J_i * sin(k0 * dot(rr, rp5)))
si = JCz * (J_i * cos(k0 * dot(rr, rp5)) + J_r * sin(k0 * dot(rr, rp5)))
N_r.append(sr)
N_i.append(si)
qr = MCz * (M_r * cos(k0 * dot(rr, rp5)) - M_i * sin(k0 * dot(rr, rp5)))
qi = MCz * (M_i * cos(k0 * dot(rr, rp5)) + M_r * sin(k0 * dot(rr, rp5)))
L_r.append(qr)
L_i.append(qi)
Sixth octant x < 0, y > 0, z < 0
rp6 = Expression(('-x[0]', 'x[1]+1.25', '-x[2]'), degree = 1)
sr = JCx * JCz * (J_r * cos(k0 * dot(rr, rp6)) - J_i * sin(k0 * dot(rr, rp6)))
si = JCx * JCz * (J_i * cos(k0 * dot(rr, rp6)) + J_r * sin(k0 * dot(rr, rp6)))
N_r.append(sr)
N_i.append(si)
qr = MCx * MCz * (M_r * cos(k0 * dot(rr, rp6)) - M_i * sin(k0 * dot(rr, rp6)))
qi = MCx * MCz * (M_i * cos(k0 * dot(rr, rp6)) + M_r * sin(k0 * dot(rr, rp6)))
L_r.append(qr)
L_i.append(qi)
seventh octant x < 0, y < 0, z < 0
rp7 = Expression(('-x[0]', '-x[1]-1.25', '-x[2]'), degree = 1)
sr = JCy * JCx * JCz * (J_r * cos(k0 * dot(rr, rp7)) - J_i * sin(k0 * dot(rr, rp7)))
si = JCy * JCx * JCz * (J_i * cos(k0 * dot(rr, rp7)) + J_r * sin(k0 * dot(rr, rp7)))
N_r.append(sr)
N_i.append(si)
qr = MCy * MCx * MCz * (M_r * cos(k0 * dot(rr, rp7)) - M_i * sin(k0 * dot(rr, rp7)))
qi = MCy * MCx * MCz * (M_i * cos(k0 * dot(rr, rp7)) + M_r * sin(k0 * dot(rr, rp7)))
L_r.append(qr)
L_i.append(qi)
Eighth octant x > 0, y < 0, z < 0
rp8 = Expression(('x[0]', '-x[1]-1.25', '-x[2]'), degree = 1)
sr = JCy * JCz * (J_r * cos(k0 * dot(rr, rp8)) - J_i * sin(k0 * dot(rr, rp8)))
si = JCy * JCz * (J_i * cos(k0 * dot(rr, rp8)) + J_r * sin(k0 * dot(rr, rp8)))
N_r.append(sr)
N_i.append(si)
qr = MCy * MCz * (M_r * cos(k0 * dot(rr, rp8)) - M_i * sin(k0 * dot(rr, rp8)))
qi = MCy * MCz * (M_i * cos(k0 * dot(rr, rp8)) + M_r * sin(k0 * dot(rr, rp8)))
L_r.append(qr)
L_i.append(qi)
Compute E_ff
Et_i = -K * assemble((dot(sum(L_r), rphi) + eta * dot(sum(N_r), rtheta)) * dsm(2))
Et_r = K * assemble((dot(sum(L_i), rphi) + eta * dot(sum(N_i), rtheta)) * dsm(2))
Ep_i = K * assemble((dot(sum(L_r), rtheta) - eta * dot(sum(N_r), rphi)) * dsm(2))
Ep_r = -K * assemble((dot(sum(L_i), rtheta) - eta * dot(sum(N_i), rphi)) * dsm(2))
Compute magnitudes
Gvert = (Et_r * Et_r + Et_i * Et_i) / (2.0 * TwoPi * eta * (P * 8.0 / (2.0 * K * eta)))
Ghoriz = (Ep_r * Ep_r + Ep_i * Ep_i) / (2.0 * TwoPi * eta * (P * 8.0 / (2.0 * K * eta)))
print(" {0:f} {1:f} {2:f} {3:f}".format(theta, phi, Gvert, Ghoriz))
print(" {0:f} {1:f} {2:f} {3:f}".format(theta, phi, Gvert, Ghoriz), file = fp)
fp.close()
sys.exit(0)
the error messagw
File â/mnt/hgfs/PMSM-X-main/DualMonopoleïŒćæćé”ć怩çșżïŒ/DualMonopoleRevPhase.pyâ, line 39, in
infile.read(mesh)
RuntimeError:
*** Error: Unable to open XDMF file.
*** Reason: XDMF file âmesh.xdmfâ does not exist.
*** Where: This error was encountered inside XDMFFile.cpp.
*** Process: 0
*** Git changeset: ubuntu
Process finished with exit code 1
Well, your error message relates to
Ie you mesh file does not exist.
This has nothing to do with vtkplotter.
Please reduce the code to a minimal reproducible example and use 3x` encapsulation, ie
```python
# add code here
This is strange, I put the grid file under the same folder, but it was not detected
That is an .msh
file, not .xdmf
file. You Need to convert your mesh
There is already code in the code to convert the.msh file, and it is this code that has the problem
msh = meshio.read("DualMonopole.msh")
for cell in msh.cells:
if cell.type == "tetra":
tetra_cells = cell.data
if key == "tetra":
tetra_data = msh.cell_data_dict["gmsh:physical"][key]
tetra_mesh = meshio.Mesh(points=msh.points, cells={"tetra": tetra_cells},
cell_data={"VolumeRegions":[tetra_data]})
from vtkplotter.dolfin import datadir, plot
mesh = Mesh()
infile.read(mesh)
mvc = MeshValueCollection("size_t", mesh, 3)
infile.read(mvc, "VolumeRegions")
info(mesh)
# Volume domains
File("VolSubDomains.pvd").write(cf)
File("Mesh.pvd").write(mesh)
plot(mesh)
Well, that is not the code you gave above. What error do you get with this code:
this is the error
File â/mnt/hgfs/PMSM-X-main/DualMonopoleïŒćæćé”ć怩çșżïŒ/DualMonopoleConv.pyâ, line 15, in
meshio.write(âmesh.xdmfâ, tetra_mesh)
File â/home/sohar/.local/lib/python3.10/site-packages/meshio/_helpers.pyâ, line 188, in write
return writer(filename, mesh, **kwargs)
File â/home/sohar/.local/lib/python3.10/site-packages/meshio/xdmf/main.pyâ, line 546, in write
XdmfWriter(*args, **kwargs)
File â/home/sohar/.local/lib/python3.10/site-packages/meshio/xdmf/main.pyâ, line 338, in init
import h5py
ModuleNotFoundError: No module named âh5pyâ
The error is very clear, you have not installed h5py
, which can be installed with python3 -m pip install --no-binary=h5py h5py
I have now downloaded h5py, run the code and it says h5py have no attribute âFileâ.Is this a version problem?
File "/mnt/hgfs/PMSM-X-main/DualMonopoleïŒćæćé”ć怩çșżïŒ/DualMonopoleConv.py", line 15, in <module>
File "/home/sohar/.local/lib/python3.10/site-packages/meshio/_helpers.py", line 188, in write
File "/home/sohar/.local/lib/python3.10/site-packages/meshio/xdmf/main.py", line 546, in write
File "/home/sohar/.local/lib/python3.10/site-packages/meshio/xdmf/main.py", line 354, in __init__
self.h5_file = h5py.File(self.h5_filename, "w")
AttributeError: module 'h5py' has no attribute 'File'
Then your h5py
installation is not successful.
Iâve fixed the h5py issue and now itâs back to my original question, I canât install the vtkplotteră
I installed the module with the command
pip install vtkplotter
or
pip3 install vtkplotter
The error are the same
ERROR: Could not find a version that satisfies the requirement vtkplotter (from versions: none)
ERROR: No matching distribution found for vtkplotter
when I use this command
sudo apt-get python3-vtkplotter
the error is
There is no package available for python3-vtkplotter, but it is referenced by other packages.
This could mean that the missing package may have been discarded,
Or it can only be found in other publishing sources
However, the following packages will replace it:
python3-vedo.
then i install vedo ,but the erorr still exist
As far as I can recall vtkplotter was renamed vedo
, thus you have to change the import statement to import vedo
if you have installed GitHub - marcomusy/vedo: A python module for scientific analysis of 3D data based on VTK and Numpy
Maybe @marcomusy can comment?
This is a lower version of the code, now that vtkplotter has been recall vedo, I think the datadir in the import vtkplotter has also changed, but I donât know what the datdir has been changed to.
if key == "tetra":
from vedo.dolfin import datadir, plot
mesh = Mesh()
infile.read(mesh)
info(mesh)
# Volume domains
plot(mesh)
this is the erorr
File "/home/sohar/æĄéą/DualMonopoleïŒćæćé”ć怩çșżïŒ/DualMonopoleConv.py", line 20, in <module>
File "/usr/lib/python3/dist-packages/vedo/__init__.py", line 47, in <module>
settings._init()
File "/usr/lib/python3/dist-packages/vedo/settings.py", line 600, in _init
np.warnings.filterwarnings('ignore', category=np.VisibleDeprecationWarning)
File "/home/sohar/.local/lib/python3.10/site-packages/numpy/__init__.py", line 328, in __getattr__
raise AttributeError("module {!r} has no attribute "
AttributeError: module 'numpy' has no attribute 'warnings'. Did you mean: 'hanning'?
This is very confusing⊠you seem to have a very old installation of vedo
try:
pip uninstall vedo
pip install vedo -U
I reinstalled vedo2023.4.6 but as I said before cannot import name 'datadir
File "/mnt/hgfs/PMSM-X-main/DualMonopoleïŒćæćé”ć怩çșżïŒ/DualMonopoleConv.py", line 20, in <module>
ImportError: cannot import name 'datadir' from 'vedo.dolfin' (/home/sohar/.local/lib/python3.10/site-packages/vedo/dolfin.py)
There is no datadir
in vedo2023.4.6, it does not exist, this means that there is something else going wrong in your environment, unrelated to vedo or dolfinâŠ
Sorry for not replying to you immediately. I delet datadir, .msh
file was successfully convert to .xdmf
file, but the operation results can not converge. I find that dolfinx and dolfin2019.2 are downloaded on my virtual machine. Since the code writer used dolfin2019.2, I successfully run the code in the dolfin2019.2 environment and get the result.
