I am trying to run FEniCS (2019) on a new (Linux) machine. I installed FEniCS through conda, no problem. But when I run my code, at the time of compiling custom C++ expressions, the compilation passes but the link fails.
Here is a MWE:
import dolfin
cpp = '''\
#include <dolfin/function/Expression.h>
class Expr : public dolfin::Expression
public:
Expr() : dolfin::Expression() {}
PYBIND11_MODULE(SIGNATURE, m)
pybind11::class_<Expr, std::shared_ptr<Expr>, dolfin::Expression>
(m, "Expr")
.def(pybind11::init<>());
module = dolfin.compile_cpp_code(cpp)
returns:
File "test.py", line 37, in <module>
File "/var/tmp/fenics-2019.1.0-conda/miniconda/lib/python3.8/site-packages/dolfin/jit/pybind11jit.py", line 95, in compile_cpp_code
module, signature = dijitso_jit(cpp_code, module_name, params,
File "/var/tmp/fenics-2019.1.0-conda/miniconda/lib/python3.8/site-packages/dolfin/jit/jit.py", line 47, in mpi_jit
File "/var/tmp/fenics-2019.1.0-conda/miniconda/lib/python3.8/site-packages/dolfin/jit/jit.py", line 103, in dijitso_jit
return dijitso.jit(*args, **kwargs)
File "/var/tmp/fenics-2019.1.0-conda/miniconda/lib/python3.8/site-packages/dijitso/jit.py", line 212, in jit
lib = load_library(signature, cache_params)
File "/var/tmp/fenics-2019.1.0-conda/miniconda/lib/python3.8/site-packages/dijitso/cache.py", line 363, in load_library
lib = __import__(signature)
ImportError: /home/genet/.cache/dijitso-2019.1.0/lib/dolfin_cpp_module_e0fdf869aed999f1dc7592091234875c.so: undefined symbol: _ZN6dolfin10Expression12set_propertyESsd
Any idea? Thanks!
nate
April 29, 2021, 7:48pm
2
Sanity check: Have you tried running dijitso clean
just to make sure it’s not pulling anything old from the cache?
And after that if you could do:
ldd /home/genet/.cache/dijitso-2019.1.0/lib/dolfin_cpp_module_e0fdf869aed999f1dc7592091234875c.so
(or whatever the signature is that dijitso gives the shared library) to make sure everything’s linked to the right places.
Thanks a lot Nate!
I did try dijitso clean
and removing ~/.cache
multiple times, to no avail—I should have mentioned it.
Here is the output of ldd
linux-vdso.so.1 => (0x00007ffca33ea000)
libmpi.so.12 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libmpi.so.12 (0x00007f6c04016000)
libmpicxx.so.12 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libmpicxx.so.12 (0x00007f6c0473b000)
libpetsc.so.3.13 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libpetsc.so.3.13 (0x00007f6c02c78000)
libslepc.so.3.13 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libslepc.so.3.13 (0x00007f6c02965000)
libhdf5.so.103 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libhdf5.so.103 (0x00007f6c025b2000)
libboost_timer.so.1.74.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libboost_timer.so.1.74.0 (0x00007f6c0472e000)
libdolfin.so.2019.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libdolfin.so.2019.1 (0x00007f6c01fde000)
libstdc++.so.6 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libstdc++.so.6 (0x00007f6c045b9000)
libm.so.6 => /lib64/libm.so.6 (0x00007f6c01cdc000)
libgcc_s.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/libgcc_s.so.1 (0x00007f6c0457e000)
libc.so.6 => /lib64/libc.so.6 (0x00007f6c0190e000)
libgfortran.so.5 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libgfortran.so.5 (0x00007f6c0176e000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f6c01552000)
librt.so.1 => /lib64/librt.so.1 (0x00007f6c0134a000)
libgomp.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libgomp.so.1 (0x00007f6c0131d000)
libquadmath.so.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libquadmath.so.0 (0x00007f6c012e3000)
/lib64/ld-linux-x86-64.so.2 (0x00007f6c0453b000)
libHYPRE.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libHYPRE.so (0x00007f6c00eff000)
libdmumps-5.2.1.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libdmumps-5.2.1.so (0x00007f6c00cd1000)
libumfpack.so.5 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libumfpack.so.5 (0x00007f6c00bfb000)
libklu.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libklu.so.1 (0x00007f6c00bc4000)
libcholmod.so.3 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libcholmod.so.3 (0x00007f6c00abb000)
libamd.so.2 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libamd.so.2 (0x00007f6c0456c000)
libsuperlu_dist.so.6 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libsuperlu_dist.so.6 (0x00007f6c009d9000)
liblapack.so.3 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./liblapack.so.3 (0x00007f6bfea14000)
libptscotchparmetis-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libptscotchparmetis-6.so (0x00007f6c04564000)
libptscotch-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libptscotch-6.so (0x00007f6bfe923000)
libparmetis.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libparmetis.so (0x00007f6bfe89a000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f6bfe696000)
libmpifort.so.12 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libmpifort.so.12 (0x00007f6bfe655000)
libcrypto.so.1.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libcrypto.so.1.1 (0x00007f6bfe389000)
libcurl.so.4 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libcurl.so.4 (0x00007f6bfe2f0000)
libz.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libz.so.1 (0x00007f6bfe2d0000)
libboost_chrono.so.1.74.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libboost_chrono.so.1.74.0 (0x00007f6bfe2c5000)
libboost_filesystem.so.1.74.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libboost_filesystem.so.1.74.0 (0x00007f6bfe2a4000)
libboost_program_options.so.1.74.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libboost_program_options.so.1.74.0 (0x00007f6bfe23b000)
libboost_iostreams.so.1.74.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./libboost_iostreams.so.1.74.0 (0x00007f6bfe222000)
libmumps_common-5.2.1.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libmumps_common-5.2.1.so (0x00007f6bfe1c8000)
libmetis.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libmetis.so (0x00007f6bfe153000)
libpord-5.2.1.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libpord-5.2.1.so (0x00007f6bfe13a000)
libptesmumps-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libptesmumps-6.so (0x00007f6bfe133000)
libptscotcherr-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libptscotcherr-6.so (0x00007f6bfe12e000)
libscotch-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libscotch-6.so (0x00007f6bfe089000)
libscalapack.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libscalapack.so (0x00007f6bfdab4000)
libsuitesparseconfig.so.5 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libsuitesparseconfig.so.5 (0x00007f6bfdaae000)
libcolamd.so.2 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libcolamd.so.2 (0x00007f6bfdaa4000)
libbtf.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libbtf.so.1 (0x00007f6bfda9d000)
libccolamd.so.2 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libccolamd.so.2 (0x00007f6bfda8f000)
libcamd.so.2 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libcamd.so.2 (0x00007f6bfda80000)
libnghttp2.so.14 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libnghttp2.so.14 (0x00007f6bfda56000)
libssh2.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libssh2.so.1 (0x00007f6bfda12000)
libssl.so.1.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libssl.so.1.1 (0x00007f6bfd981000)
libgssapi_krb5.so.2 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libgssapi_krb5.so.2 (0x00007f6bfd932000)
libkrb5.so.3 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libkrb5.so.3 (0x00007f6bfd859000)
libk5crypto.so.3 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libk5crypto.so.3 (0x00007f6bfd839000)
libcom_err.so.3 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libcom_err.so.3 (0x00007f6bfd833000)
libbz2.so.1.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libbz2.so.1.0 (0x00007f6bfd81e000)
liblzma.so.5 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././liblzma.so.5 (0x00007f6bfd7f5000)
libzstd.so.1 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/././libzstd.so.1 (0x00007f6bfd736000)
libscotcherr-6.so => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./././libscotcherr-6.so (0x00007f6bfd730000)
libkrb5support.so.0 => /var/tmp/fenics-2019.1.0-conda/miniconda/lib/./././libkrb5support.so.0 (0x00007f6bfd720000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f6bfd506000)
Does that ring any bell to you? For instance, I see that libm.so.6 => /lib64/libm.so.6
even though there is /var/tmp/fenics-2019.1.0-conda/miniconda/x86_64-conda_cos6-linux-gnu/sysroot/lib/libm.so.6
; could that be a problem?
