Error defining surface and measures for a 3D mesh imported from Gmsh
I am importing a 3D rectangular beam mesh from Gmsh (script provided after MWE). The rectangular 3D beam has length 10, width 0.5, and height 0.5. I am defining the volume, surface, and line measures as given in the MWE below. When I assemble, I am getting the right volume. But the values of the areas of the surfaces and the lines are way off!
MWE:
import matplotlib.patches as mpatches
from ufl import cofac, sqrt
from scipy import linalg as la
from ufl import *
from ufl.classes import *
import pandas as pd
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
import numpy
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
msh = meshio.read("mesh.msh")
tetra_mesh = create_mesh(msh, "tetra", True)
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("surface.xdmf", triangle_mesh)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
xdmf = XDMFFile(mesh.mpi_comm(),"mesh.xdmf")
xdmf.read(mesh)
xdmf.close()
with XDMFFile("surface.xdmf") as infile:
sf = cpp.mesh.MeshFunctionSizet(mesh, mvc)
xdmf.close()
mvc = MeshValueCollection("size_t", mesh, mesh.topology().dim()-2)
ds_custom = Measure("dS", domain=mesh, subdomain_data=mf)  # Line measure
dx_custom = Measure("dx", domain=mesh, subdomain_data=sf)    # Surface measure
dv_custom = Measure("dx", domain=mesh, subdomain_data=cf)    # Volume measure
print(f"Volume = {assemble(Constant(1.0)*dv_custom(19))}")            # Should be 2.5
print(f"frontbottomline = {assemble(Constant(1.0)*ds_custom(4))}")    # Should be 10
print(f"fronttopline = {assemble(Constant(1.0)*ds_custom(3))}")       # Should be 10
print(f"frontleftline = {assemble(Constant(1.0)*ds_custom(1))}")      # Should be 0.5
print(f"frontrightline = {assemble(Constant(1.0)*ds_custom(2))}")     # Should be 0.5
print(f"lefttopline = {assemble(Constant(1.0)*ds_custom(5))}")        # Should be 0.5
print(f"leftbottomline = {assemble(Constant(1.0)*ds_custom(6))}")     # Should be 0.5
print(f"righttopline = {assemble(Constant(1.0)*ds_custom(7))}")       # Should be 0.5
print(f"rightbottomline = {assemble(Constant(1.0)*ds_custom(8))}")    # Should be 0.5
print(f"backtopline = {assemble(Constant(1.0)*ds_custom(9))}")        # Should be 10
print(f"backbottomline = {assemble(Constant(1.0)*ds_custom(10))}")    # Should be 10
print(f"backleftline = {assemble(Constant(1.0)*ds_custom(11))}")      # Should be 0.5
print(f"backleftline = {assemble(Constant(1.0)*ds_custom(12))}")      # Should be 0.5
print(f"frontsurface = {assemble(Constant(1.0)*dx_custom(13))}")      # Should be 5
print(f"leftsurface = {assemble(Constant(1.0)*dx_custom(14))}")       # Should be 0.25
print(f"rightsurface = {assemble(Constant(1.0)*dx_custom(15))}")      # Should be 0.25
print(f"topsurface = {assemble(Constant(1.0)*dx_custom(16))}")        # Should be 5
print(f"bottomsurface = {assemble(Constant(1.0)*dx_custom(17))}")     # Should be 5
print(f"backsurface = {assemble(Constant(1.0)*dx_custom(18))}")       # Should be 5
This gives the following output:
Volume = 2.5000000000002993
frontbottomline = 0.5088177178912574
fronttopline = 0.026856850843952427
frontleftline = 0.0012651138839902972
frontrightline = 0.0012576415390319338
lefttopline = 0.23572496165217366
leftbottomline = 0.04524590534914055
righttopline = 0.003959317943007174
rightbottomline = 0.001385418482056354
backtopline = 0.02318226274902181
backbottomline = 0.023506977188747825
backleftline = 0.0009567354242365273
backleftline = 0.0012058685118405636
frontsurface = 0.04434651358155991
leftsurface = 0.002269191407108078
rightsurface = 0.0022366414437487514
topsurface = 0.04266836365558237
bottomsurface = 0.04323308955707949
backsurface = 0.04398366574788088
The values of the surface areas and length of the lines are way off!
Here is the Gmsh script:
SetFactory("OpenCASCADE");
Point(1) = {0.0, 0.0, 0.0, 1.0};
Point(2) = {0.0, 0.0, 0.5, 1.0};
Point(3) = {10.0, 0.0, 0.5, 1.0};
Point(4) = {10.0, 0.0, 0.0, 1.0};
Point(5) = {0.0, 0.5, 0.0, 1.0};
Point(6) = {10.0, 0.5, 0.0, 1.0};
Point(7) = {10.0, 0.5, 0.5, 1.0};
Point(8) = {0.0, 0.5, 0.5, 1.0};
Line(1) = {8, 7};
Line(2) = {7, 3};
Line(3) = {3, 2};
Line(4) = {2, 8};
Line(5) = {5, 8};
Line(6) = {1, 2};
Line(7) = {1, 5};
Line(8) = {5, 6};
Line(9) = {6, 7};
Line(10) = {1, 4};
Line(11) = {4, 3};
Line(12) = {4, 6};
Curve Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Curve Loop(2) = {6, 4, -5, -7};
Plane Surface(2) = {2};
Curve Loop(3) = {11, -2, -9, -12};
Plane Surface(3) = {3};
Curve Loop(4) = {8, -12, -10, 7};
Plane Surface(4) = {4};
Curve Loop(5) = {11, 3, -6, 10};
Plane Surface(5) = {5};
Curve Loop(6) = {1, -9, -8, 5};
Plane Surface(6) = {6};
Surface Loop(1) = {6, 1, 3, 5, 2, 4};
Volume(1) = {1};
Physical Curve("fronttop", 3) = {1};
Physical Curve("frontbottom", 4) = {3};
Physical Curve("frontleft", 1) = {4};
Physical Curve("frontright", 2) = {2};
Physical Curve("lefttop", 5) = {5};
Physical Curve("leftbottom", 6) = {6};
Physical Curve("righttop", 7) = {9};
Physical Curve("rightbottom", 8) = {11};
Physical Curve("backtop", 9) = {8};
Physical Curve("backbottom", 10) = {10};
Physical Curve("backleft", 11) = {7};
Physical Curve("backright", 12) = {12};
Physical Surface("front", 13) = {1};
Physical Surface("left", 14) = {2};
Physical Surface("right", 15) = {3};
Physical Surface("top", 16) = {6};
Physical Surface("bottom", 17) = {5};
Physical Surface("back", 18) = {4};
Physical Volume("vol", 19) = {1};
I am not sure what I am doing wrong in defining the measures. Any suggestions would be greatly appreciated! Thanks in advance!
Hi, I haven’t try by myslef. Maybe you can try
ds_custom = Measure("dP", domain=mesh, subdomain_data=mf)    # Line measure
dx_custom = Measure("dS", domain=mesh, subdomain_data=sf)    # Surface measure
Source from measure.py,
# Enumeration of valid domain types
_integral_types = [
    # === Integration over full topological dimension:
    ("cell", "dx"),  # Over cells of a mesh
    # === Integration over topological dimension - 1:
    ("exterior_facet", "ds"),  # Over one-sided exterior facets of a mesh
    ("interior_facet", "dS"),  # Over two-sided facets between pairs of adjacent cells of a mesh
    # === Integration over topological dimension 0
    ("vertex", "dP"),  # Over vertices of a mesh
    # === Integration over custom domains
    ("custom", "dc"),  # Over custom user-defined domains (run-time quadrature points)
    ("cutcell", "dC"),  # Over a cell with some part cut away (run-time quadrature points)
        "interface",
        "dI",
Hi @Yanjun ,
gives
frontbottomline = 1000.0
fronttopline = 1000.0
frontleftline = 50.0
frontrightline = 50.0
lefttopline = 50.0
leftbottomline = 50.0
righttopline = 50.0
rightbottomline = 50.0
backtopline = 1000.0
backbottomline = 1000.0
backleftline = 50.0
backleftline = 50.0
frontsurface = 0.0
leftsurface = 0.0
rightsurface = 0.0
topsurface = 0.0
bottomsurface = 0.0
backsurface = 0.0
However, for some reason,
dx_custom = Measure("ds", domain=mesh, subdomain_data=sf)
gives the output where the volume and the surface areas are close, but the lengths of lines are way off!
frontbottomline = 0.01243360001988918
fronttopline = 0.012673148013984142
frontleftline = 0.0005413524268829276
frontrightline = 0.000605883828851856
lefttopline = 0.0006321980459450495
leftbottomline = 0.0006248896443573343
righttopline = 0.0005858728932500689
rightbottomline = 0.0007363234475738806
backtopline = 0.013333970591006435
backbottomline = 0.013250335575372394
backleftline = 0.000709491433048344
backleftline = 0.0007213413236293295
frontsurface = 5.000000000000001
leftsurface = 0.2500000000000004
rightsurface = 0.24999999999999944
topsurface = 4.999999999999967
bottomsurface = 5.000000000000003
backsurface = 4.999999999999966
Edge integrals are not supported in 3D meshes without using MeshView.
You have corrected the integral measure for the surfaces (ds, not dS)
Consider the following:
                           cell_type: cells}, cell_data={"name_to_read": [cell_data]})
    return out_mesh
mesh = Mesh()
xdmf = XDMFFile(mesh.mpi_comm(), "mesh.xdmf")
xdmf.read(mesh)
xdmf.close()
xdmf.close()
dx_custom = Measure("ds", domain=mesh, subdomain_data=sf)    # Surface measure
# Should be 2.5
# Should be 5
# Should be 0.25
# Should be 0.25
# Should be 5
# Should be 5
# Should be 5
def assemble_edge(tag):
    mv = MeshView.create(mf, tag)
    return assemble(Constant(1.0)*dx(domain=mv))
# Should be 10
print(f"frontbottomline = {assemble_edge(4)}")
# Should be 10
print(f"fronttopline = {assemble_edge(3)}")
# Should be 0.5
print(f"frontleftline = {assemble_edge(1)}")
# Should be 0.5
print(f"frontrightline = {assemble_edge(2)}")
# Should be 0.5
print(f"lefttopline = {assemble_edge(5)}")
# Should be 0.5
print(f"leftbottomline = {assemble_edge(6)}")
# Should be 0.5
print(f"righttopline = {assemble_edge(7)}")
# Should be 0.5
print(f"rightbottomline = {assemble_edge(8)}")
# Should be 10
print(f"backtopline = {assemble_edge(9)}")
# Should be 10
print(f"backbottomline = {assemble_edge(10)}")
# Should be 0.5
print(f"backleftline = {assemble_edge(11)}")
# Should be 0.5
print(f"backleftline = {assemble_edge(12)}")
returning
Volume = 2.5000000000000027
frontsurface = 5.0
leftsurface = 0.25
rightsurface = 0.25
topsurface = 5.0
bottomsurface = 5.0
backsurface = 5.0
frontbottomline = 10.0
fronttopline = 10.0
frontleftline = 0.5
frontrightline = 0.5
lefttopline = 0.5
leftbottomline = 0.5
righttopline = 0.5
rightbottomline = 0.5
backtopline = 10.0
backbottomline = 10.0
backleftline = 0.5
backleftline = 0.5
For further posts, please remove extra imports and other unused parts of the code.
