Error in importing and reading 3D hexahedral meshes created in Gmsh
I am trying to import a 3D mesh consisting of hexahedrons, quadrangles and lines created in Gmsh (Gmsh script provided after the MWE). The following MWE tries to read the mesh and calculate areas of surfaces, lengths of sides, and the volume. I am using dolfin 2019.2.0.dev0
MWE:
               "eliminate_zeros": True, \
               "precompute_ip_const": True}
import numpy
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
msh = meshio.read("mesh.msh")
hexa_mesh = create_mesh(msh, "hexahedron", True)
quad_mesh = create_mesh(msh, "quad", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mesh.xdmf", hexa_mesh)
meshio.write("surface.xdmf", quad_mesh)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
xdmf = XDMFFile(mesh.mpi_comm(),"mesh.xdmf")
xdmf.read(mesh)   # Generates error
xdmf.close()
with XDMFFile("surface.xdmf") as infile:
sf = cpp.mesh.MeshFunctionSizet(mesh, mvc)
xdmf.close()
mvc = MeshValueCollection("size_t", mesh, mesh.topology().dim()-2)
def assemble_edge(tag):
    mv = MeshView.create(mf, tag)
    return assemble(Constant(1.0)*dx(domain=mv))
dx_custom = Measure("ds", domain=mesh, subdomain_data=sf)
dv_custom = Measure("dx", domain=mesh, subdomain_data=cf)
print(f"Volume = {assemble(Constant(1.0)*dv_custom(19))}")
print(f"frontbottomline = {assemble_edge(4)}")
print(f"fronttopline = {assemble_edge(3)}")
print(f"frontleftline = {assemble_edge(1)}")
print(f"frontrightline = {assemble_edge(2)}")
print(f"lefttopline = {assemble_edge(5)}")
print(f"leftbottomline = {assemble_edge(6)}")
print(f"righttopline = {assemble_edge(7)}")
print(f"rightbottomline = {assemble_edge(8)}")
print(f"backtopline = {assemble_edge(9)}")
print(f"backbottomline ={assemble_edge(10)}")
print(f"backleftline = {assemble_edge(11)}")
print(f"backrightline = {assemble_edge(12)}")
print(f"frontsurface = {assemble(Constant(1.0)*dx_custom(13))}")
print(f"leftsurface = {assemble(Constant(1.0)*dx_custom(14))}")
print(f"rightsurface = {assemble(Constant(1.0)*dx_custom(15))}")
print(f"topsurface = {assemble(Constant(1.0)*dx_custom(16))}")
print(f"bottomsurface = {assemble(Constant(1.0)*dx_custom(17))}")
print(f"backsurface = {assemble(Constant(1.0)*dx_custom(18))}")
This generates the following error:
*** Error:   Unable to order hexahedron cell.
*** Reason:  Cell is not orderable.
*** Where:   This error was encountered inside HexahedronCell.cpp.
Here is the Gmsh script:
SetFactory("OpenCASCADE");
Point(1) = {0.0, 0.25, 0.0, 1.0};
Point(2) = {9.0, 0.25, 0.0, 1.0};
Point(3) = {11.0, 0.25, 0.0, 1.0};
Point(4) = {20.0, 0.25, 0.0, 1.0};
Point(5) = {0.0, -0.25, 0.0, 1.0};
Point(6) = {9.0, -0.25, 0.0, 1.0};
Point(7) = {11.0, -0.25, 0.0, 1.0};
Point(8) = {20.0, -0.25, 0.0, 1.0};
Point(9) = {10.0, 0.25-0.017455, 0.0, 1.0};
Point(10) = {10.0, -0.25-0.017455, 0.0, 1.0};
Line(1) = {1, 2};
Line(2) = {3, 4};
Line(3) = {4, 8};
Line(4) = {8, 7};
Line(5) = {1, 5};
Line(6) = {5, 6};
Point(11) = {0.0, 0.25, 0.5, 1.0};
Point(12) = {9.0, 0.25, 0.5, 1.0};
Point(13) = {11.0, 0.25, 0.5, 1.0};
Point(14) = {20.0, 0.25, 0.5, 1.0};
Point(15) = {0.0, -0.25, 0.5, 1.0};
Point(16) = {9.0, -0.25, 0.5, 1.0};
Point(17) = {11.0, -0.25, 0.5, 1.0};
Point(18) = {20.0, -0.25, 0.5, 1.0};
Point(19) = {10.0, 0.25-0.017455, 0.5, 1.0};
Point(20) = {10.0, -0.25-0.017455, 0.5, 1.0};
Line(9) = {11, 12};
Line(10) = {13, 14};
Line(11) = {14, 18};
Line(12) = {18, 17};
Line(13) = {11, 15};
Line(14) = {15, 16};
Line(17) = {14, 4};
Line(18) = {18, 8};
Line(19) = {15, 5};
Line(20) = {11, 1};
Line(21) = {12, 19};
Line(22) = {19, 13};
Line(23) = {2, 9};
Line(24) = {9, 3};
Line(25) = {16, 20};
Line(26) = {20, 17};
Line(27) = {6, 10};
Line(28) = {10, 7};
Line(29) = {9, 19};
Line(30) = {10, 20};
Physical Curve("fronttop", 3) = {9, 21, 22, 10};
Physical Curve("frontbottom", 4) = {14, 25, 26, 12};
Physical Curve("backbottom", 10) = {6, 27, 28, 4};
Physical Curve("backtop", 9) = {1, 23, 24, 2};
Physical Curve("frontleft", 1) = {13};
Physical Curve("leftbottom", 6) = {19};
Physical Curve("lefttop", 5) = {20};
Physical Curve("backleft", 11) = {5};
Line(31) = {2, 12};
Line(32) = {3, 13};
Line(33) = {6, 16};
Line(34) = {7, 17};
Physical Curve("righttop", 7) = {17};
Physical Curve("rightbottom", 8) = {18};
Physical Curve("backright", 12) = {3};
Physical Curve("frontright", 2) = {11};//+
Curve Loop(1) = {2, -17, -10, -32};
Plane Surface(1) = {1};
Curve Loop(2) = {24, 32, -22, -29};
Plane Surface(2) = {2};
Curve Loop(3) = {23, 29, -21, -31};
Plane Surface(3) = {3};
Curve Loop(4) = {1, 31, -9, 20};
Plane Surface(4) = {4};
Physical Surface("top", 16) = {4, 3, 2, 1};
Curve Loop(5) = {14, -33, -6, -19};
Plane Surface(5) = {5};
Curve Loop(6) = {33, 25, -30, -27};
Plane Surface(6) = {6};
Curve Loop(7) = {28, 34, -26, -30};
Plane Surface(7) = {7};
Curve Loop(8) = {4, 34, -12, 18};
Plane Surface(8) = {8};
Physical Surface("bottom", 17) = {5, 6, 7, 8};
Curve Loop(9) = {9, 21, 22, 10, 11, 12, -26, -25, -14, -13};
Plane Surface(9) = {9};
Physical Surface("front", 13) = {9};
Curve Loop(10) = {2, 3, 4, -28, -27, -6, -5, 1, 23, 24};
Plane Surface(10) = {10};
Physical Surface("back", 18) = {10};
Curve Loop(11) = {20, 5, -19, -13};
Plane Surface(11) = {11};
Physical Surface("left", 14) = {11};
Curve Loop(12) = {18, -3, -17, 11};
Plane Surface(12) = {12};
Physical Surface("right", 15) = {12};
Surface Loop(1) = {4, 10, 1, 12, 8, 7, 9, 3, 2, 6, 5, 11};
Volume(1) = {1};
Physical Volume("volume", 19) = {1};
For meshing, I selected the 2D algorithm to be Frontal-Delaunay for quads (experimental), the 3D algorithm is Delaunay, 2D recombination algorithm is Blossom. I checked the box for Recombine all triangular meshes and selected the subdivision algorithm to be All Hexas.
I am sorry if this is a trivial question. I haven’t worked with hexahedral meshes before. I searched the group but I found nothing that solves this issue. I am not sure if I am creating the mesh incorrectly in Gmsh or if I am doing something wrong while importing it to FEniCS.
Please advise. Thanks in advance!
Long story short, if you want to use hexahedral elements you need to use DOLFINx
Long story:
Legacy FEniCS does not support hexahedral meshes from file, mainly due to the fact that they are not possible to order, as the error message states:
This has been addressed in DOLFINx (GitHub - FEniCS/dolfinx: Next generation FEniCS problem solving environment) with Construction of Arbitrary Order Finite Element Degree-of-Freedom Maps on Polygonal and Polyhedral Cell Meshes | ACM Transactions on Mathematical Software
