Hey there,
I just started with FENICS. I copied this program from a tutorial, but it doesn’t work for me:
PROGRAM
dimensiones y numero de puntos en x y en y
L=25.
H=1.
Nx=250
Ny=10
mallado
mesh = RectangleMesh(Point(0., 0.), Point(L,H), Nx, Ny, “crossed”)
desplazamientos en 2d (viga plana) la derivada de los desplazamientos son las deformaciones (eps)
def eps(v):
return sym(grad(v))
parámetros ed la viga
E = Constant(1e5)
nu = Constant(0.3)
model = “plane_stress”
mu = E/2/(1+nu)
lmbda = Enu/(1+nu)/(1-2nu)
if model == “plane_stress”:
lmbda = 2mulmbda/(lmbda+2*mu)
def sigma(v):
return lmbdatr(eps(v))Identity(2) + 2.0mueps(v)
consideraremos polinomio de grado 2 para interpolar y una carga distribuida uniformemente de valores (0,-f)
carga = 1e-3
f = Constant((0, -carga))
cálculo de la solución
V = VectorFunctionSpace (mesh, ‘Lagrange’, degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du),eps(u_))*dx
l = inner(f,u_)*dx
#cálculo
def left(x, on_boundary):
return near(x[0], 0.)
bc = DirichletBC(V, Constant((0.,0.)), left)
u = Function(V, name=“Displacement”)
solve (a==1, u, bc)
plot(1e3*u, mode=“displacement”)
The error I get is
*** Error: Unable to define nonlinear variational problem F(u; v) = 0 for all v.
*** Reason: Expecting the residual F to be a linear form (not rank 2).
*** Where: This error was encountered inside NonlinearVariationalProblem.cpp.
*** Process: 0
I’ve read the problem is because I’m using a bad trial function, but how to fix it?
Thanks
