Error importing mesh with filleted corners
I have a simple 2D geometry where I fillet each corner. Everything works in gmsh but somehow it causes the `model_to_mesh` operation to fail. I will appreciate if someone could point a way to get around this. Below is an MWE that was tried on dolfinx 0.9 installed through conda:
import dolfinx, gmsh, numpy as np, mpi4py
from dolfinx.io import gmshio
gmsh.finalize()
gmsh.option.setNumber("General.Terminal", 0) # disable output messages
gmsh.clear()
model_rank = 0
occ = gmsh.model.occ
gdim = 2
fillet = 0.1 # 0.0 means no fillet and the code works
ID = 5
OD = 10
L = 10
pnts_fl = 4*[[]]
pnts_fl[0] = occ.addPoint(ID/2, -L/2, 0)
pnts_fl[1] = occ.addPoint(OD/2, -L/2, 0)
pnts_fl[2] = occ.addPoint(OD/2, L/2, 0)
pnts_fl[3] = occ.addPoint(ID/2, L/2, 0)
lines_fl = 4*[[]]
for j in range(len(lines_fl)):
    lines_fl[j] = occ.addLine(pnts_fl[j], pnts_fl[(j+1)%len(lines_fl)])
if fillet > 0.0:
    occ.synchronize()
    fillet_tags = 4*[[]]
        fillet_tags[j] = occ.fillet2D(lines_fl[j], lines_fl[(j+1)%len(lines_fl)], fillet)
    lines_tmp = 8*[[]]
    for j in range(0, 2*len(lines_fl), 2):
        lines_tmp[j] = lines_fl[j//2]
        lines_tmp[j+1] = fillet_tags[j//2]
    lines_fl = lines_tmp
loop_fl1 = occ.addCurveLoop(lines_fl)
fl1 = occ.addPlaneSurface([loop_fl1])
occ.synchronize()
all_doms = gmsh.model.getEntities(gdim)
for j, dom in enumerate(all_doms):
    gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1)  # create the main group/node
# number all boundaries
all_edges = gmsh.model.getEntities(gdim - 1)
for j, edge in enumerate(all_edges):
    gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1])  # create the main group/node
model_rank = 0
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, model_rank, gdim)
The first check to run is if all nodes loaded in the mesh is part of the cells.
I.e. install meshio, and add the lines:
import gmsh, numpy as np
gmsh.clear()
model_rank = 0
gdim = 2
ID = 5
OD = 10
L = 10
pnts_fl = 4 * [[]]
pnts_fl[0] = occ.addPoint(ID / 2, -L / 2, 0)
pnts_fl[1] = occ.addPoint(OD / 2, -L / 2, 0)
pnts_fl[2] = occ.addPoint(OD / 2, L / 2, 0)
pnts_fl[3] = occ.addPoint(ID / 2, L / 2, 0)
lines_fl = 4 * [[]]
    lines_fl[j] = occ.addLine(pnts_fl[j], pnts_fl[(j + 1) % len(lines_fl)])
if fillet > 0.0:
    occ.synchronize()
    fillet_tags = 4 * [[]]
            lines_fl[j], lines_fl[(j + 1) % len(lines_fl)], fillet
    lines_tmp = 8 * [[]]
    for j in range(0, 2 * len(lines_fl), 2):
        lines_tmp[j] = lines_fl[j // 2]
        lines_tmp[j + 1] = fillet_tags[j // 2]
occ.synchronize()
gmsh.option.setNumber("Mesh.SaveAll", 0)
gmsh.write("test.msh")
mm = meshio.read("test.msh")
lines = mm.cells_dict["line"]
triangles = mm.cells_dict["triangle"]
points = mm.points
# Sanity check 1:
# Check that all points in the mesh is part of the triangular cells
unique_cell_vertices = np.unique(triangles.flatten())
print(points.shape[0], unique_cell_vertices)
assert np.allclose(unique_cell_vertices, np.arange(points.shape[0]))
which returns
90 [ 1  3  5  7  9 11 12 13 16 17 42 43 44 45 46 47 48 49 50 51 52 53 54 55
 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
 80 81 82 83 84 85 86 87 88 89]
i.e. there are 90 nodes read in, but you do not have 90 unique nodes in the cells. This stems from
where you are not just getting the boundary of your mesh, but also all edges in GMSH, which are not part of your mesh.
Change this to
all_edges = gmsh.model.getBoundary(all_doms, oriented=False)
which then yields the following mesh:
with
model_rank = 0
import dolfinx.io
gmshio = dolfinx.io.gmshio
mesh, ct, ft = gmshio.model_to_mesh(gmsh.model, MPI.COMM_WORLD, model_rank, gdim)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "w") as xdmf:
    xdmf.write_mesh(mesh)
    xdmf.write_meshtags(ct, mesh.geometry)
    xdmf.write_meshtags(ft, mesh.geometry)
I will be able to incorporate your solution tomorrow or during the weekend but for now I cannot thank you enough for such a swift yet detailed reply!
