Hi, I am trying to create a simple disk mesh with an inner disk in it that is cut out, but I am getting an annoying bug.
This is the code:
from dolfinx import mesh
class DiskwithHoleMesh():
def __init__(self,
radius_inner = 0.3,
radius = 1.0,
center = (0.0, 0.0),
resolution: float = 0.005,
output_dir: str = './meshes',
self.radius = radius
self.center = center
self.resolution = resolution
self.name = 'disk'
self.radius_inner = radius_inner
self.output_dir = output_dir
if not os.path.exists(self.output_dir):
os.makedirs(self.output_dir)
def create_mesh(self,
order: int = 1):
domain = self.create_disk(self.name, order)
return domain
def create_disk(self, name: str = 'disk_with_hole', order: int = 1) -> gmsh.model:
model = gmsh.model()
model.add(name)
model.setCurrent(name)
outer_sphere = model.occ.addDisk(self.center[0], self.center[1], 0, self.radius, self.radius)
inner_sphere = model.occ.addDisk(self.center[0], self.center[1], 0, self.radius_inner,
self.radius_inner)
model_dim_tags = model.occ.cut([(2, outer_sphere)], [(2, inner_sphere)],
removeObject=True, removeTool=True)
model.occ.synchronize()
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", self.resolution)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", self.resolution)
model.mesh.generate(2)
gmsh.write(f"{self.output_dir}/{self.name}.msh")
domain, cell_marker, facet_marker = dolfinx.io.gmshio.model_to_mesh(
model, MPI.COMM_WORLD, 0, gdim=2)
gmsh.finalize()
return domain
disk_mesh = DiskwithHoleMesh(radius_inner=0.3, radius=1.0, resolution=0.05)
domain = disk_mesh.create_mesh(order=2)
disk_mesh.plot_mesh()
I am getting the following error:
in model_to_mesh(model, comm, rank, gdim, partitioner, dtype) [258](https://file+.vscode-resource.vscode-cdn.net/home/sebastian/my_code/GPstuff/~/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/io/gmshio.py:258) perm_sort = np.argsort(cell_dimensions) [260](https://file+.vscode-resource.vscode-cdn.net/home/sebastian/my_code/GPstuff/~/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/io/gmshio.py:260) # Broadcast cell type data and geometric dimension --> [261](https://file+.vscode-resource.vscode-cdn.net/home/sebastian/my_code/GPstuff/~/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/io/gmshio.py:261) cell_id = cell_information[perm_sort[-1]]["id"] [262](https://file+.vscode-resource.vscode-cdn.net/home/sebastian/my_code/GPstuff/~/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/io/gmshio.py:262) tdim = cell_information[perm_sort[-1]]["dim"] [263](https://file+.vscode-resource.vscode-cdn.net/home/sebastian/my_code/GPstuff/~/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/io/gmshio.py:263) num_nodes = cell_information[perm_sort[-1]]["num_nodes"] IndexError: index -1 is out of bounds for axis 0 with size 0
Any help on this is more than appreciated!
