for my thesis I want to develop a script based on your example for hyperelasticity. Before modifying, I just wanted to make sure that everything works properly and copied all the elements of the example notebook without any manipulation into a .py file and ran this. Thereby, I got the error message
$ /usr/bin/python3 hyperelasticity.py
File "/home/marco/Schreibtisch/Code
/Kernproblem/hyperelasticity.py", line 29, in <module>
left_dofs = fem.locate_dofs_topological(V, facet_tag.dim, facet_tag.find(1))
AttributeError: 'MeshTagsMetaClass' object has no attribute 'find'
That means that I cannot run your script as given on your example page. Could that depend on something I did not consider?
Unfortunately, I could only request the versions of dolfin and fenics, not dolfinx and fenicsx as there exists no such command to request their versions.
In the hope that you can help me understand the problem
Best regards
Marco
The tutorial is almost up to date with main, which is at 0.4.2.0. If you want to use the stable release, consider the notebooks at: GitHub - jorgensd/dolfinx-tutorial at v0.4.0
I tried that one, with the same error. My dolfin doesn’t know the facet_tag.find(1) command. I searched for a dolfinx update on apt, but to no avail. I can’t update it. How am I able to get that working?
That helps! I am sorry I thought you mean that the .py-file and the notebook in said directory are equal and since I cannot use jupyter with dolfinx, I tend to use the .py files. I am sorry for that misunderstanding on my part.
I have a similar problem with gmshio, once a tutorial case is run.
The gmsh-api & gmsh are properly (I assume) installed. Both can be imported without any error.
Despite the following error is received;
NameError: name 'gmshio' is not defined. Did you mean: 'gmsh'?
On my laptop a relatively recent release of dolfinx is installed.
