Error in loading xdmf file: unable to recognise cell type
I am trying to load a mesh from an xdmf file generating from the following code.
import pygmsh
with pygmsh.occ.Geometry() as geom:
    geom.characteristic_length_min = 0.1
    geom.characteristic_length_max = 0.1
    rectangle1 = geom.add_rectangle([0.0, 0.0, 0.0], 1.0, 0.5)
    rectangle2 = geom.add_rectangle([0.0, 0.5, 0.0], 1.0, 0.5)
    geom.boolean_fragments(rectangle1, rectangle2)
    mesh = geom.generate_mesh()
mesh.write("out.xdmf")
Then I use “infile” to read the mesh into fenics by below code.
mesh = Mesh()
with XDMFFile("out.xdmf") as infile:
    infile.read(mesh)
But I encounter an error below:
Error: Unable to recognise cell type.
Reason: Unknown value “mixed”.
Where: This error was encountered inside XDMFFILE.cpp.
Process: 0
May I enquire that how can I resolve this error? Thank you.
This has been covered in several other topics: Transitioning from mesh.xml to mesh.xdmf, from dolfin-convert to meshio
Line mesh in a 2D space - #2 by dokken
Etc.
