Time dependent solver error does not decrease with mesh size
Hi everyone,
I have a time dependent temperature solver that fails my mesh convergence test, namely, the L2 error I get (when compared to the exact solution) stays constant with decreasing mesh size. It looks like a simple problem, and I am comparing against an exact solution, so I am really lost as to why my test fails.
My MWE is:
# Choose a mesh. You can also import a previously adapted mesh
mesh = RectangleMesh(Point(0, 0), Point(1, 1), 40, 40)
t = Constant(0)
t_old = Constant(0) # used for time stepping the source code
tol = 1E-14
def full_boundary(x, on_boundary):
    return on_boundary
class InitialConditions(UserExpression):
    def __init__(self, **kwargs):
        super().__init__(kwargs)
    def eval_cell(self, value, x, ufc_cell):
        value[0] = x[0]*x[1] # exact solution evaluated at t=0.0
    def value_shape(self):
        return()
class GoverningEquations(NonlinearProblem):
    def __init__(self, a, L, bcs):
        self.L = L
        self.a = a
        self.bcs = bcs
    def F(self, b, x):
        assemble(self.L, tensor=b)
        for bc in self.bcs:
            bc.apply(b, x)
    def J(self, A, x):
        assemble(self.a, tensor=A)
        for bc in self.bcs:
            bc.apply(A)
# Define function space
S = FiniteElement("CG", triangle, 1)
W = FunctionSpace(mesh, S)
# Define Function for the previously converged step and TestFunction(s)
# w0 = Function(W)
dw = TrialFunction(W) # used for the bilinear form
(s1) = TestFunction(W) # used for the linear form
# constant velocity vector
u_vec = Constant((-1.0, 1.0))
theta = 0.5# parameter for the theta scheme in time
dt = 0.001 # timestep size
# Form compiler options
x = SpatialCoordinate(mesh)
facet_f = MeshFunction("size_t", mesh, mesh.topology().dim() - 1) # FACET function
# Create the measure
ds = Measure("ds", domain=mesh, subdomain_data=facet_f)
T0 = Function(W)
T = Function(W)
Texact = Expression('x[0]*x[1] + sin(2*pi*t)',  t=t, element=S, domain=mesh)
Qexact = Expression('2*pi*cos(2*pi*t) -(x[0] - x[1])', t=t, element=S, domain=mesh)
Qexact_old = Expression('2*pi*cos(2*pi*t) - (x[0] - x[1])', t=t_old, element=S, domain=mesh)
TExact = Function(W)
T_init = InitialConditions(degree=2)
T.interpolate(T_init)
T0.interpolate(T_init)
# T^{k+theta}
T_mid = (1.0 - theta)*T0 + theta*T
Qexact_mid = (1.0 - theta)*Qexact_old + theta*Qexact
L0 =  (1/dt) * (T*s1 - T0*s1)*dx() + (dot(u_vec, grad(T_mid)) * s1 + inner(grad(s1), grad(T_mid))) * dx()
L1 = - Qexact_mid*s1 * dx()
L  = L0 + L1
J2 = derivative(L, T, dw)
# Step in time
tt = 0.0
T_final = 10*dt
bc = [DirichletBC(W, Texact, full_boundary)]
problem = GoverningEquations(J2, L, bc)
solver = NewtonSolver()
solver.parameters["linear_solver"] = "lu"
solver.parameters["convergence_criterion"] = "incremental"
solver.parameters["relative_tolerance"] = 1e-6
W2 = FunctionSpace(mesh, S)
while(tt < T_final):
    t_old.assign(tt)
    tt += dt
    print("tt is ", tt)
    T0.vector()[:] = T.vector()
    t.assign(tt)
    solver.solve(problem, T.vector())
    T_ex_pr = project(Texact, W2)
    error_L2 = errornorm(T_ex_pr, T, 'L2')
    # Print errors
    print('error_L2 =', error_L2)
The error increases at each timestep, and it stays constant with decreasing mesh size, so I am clearly not solving the equation.
I have tried different manufactured solutions and decreasing dt, always with the same result. I am basing my code on the Cahn Hilliard demo . Any advice would be greatly appreciated!
Skimming your code, are you sure your expressions for Q are correct? I think you have a typo with a - sign in the wrong place. Try:
Qexact = Expression('2*pi*cos(2*pi*t) +(x[0] - x[1])', t=t, element=S, domain=mesh)
You’re right! I had a typo with the sign (sorry about that - I tried many manufactured solutions).
The error is now smaller, but still increasing with timesteps, and still staying constant (or at least, with no signs of convergence) after reducing mesh size.
You need to consider the error incurred by both the spatial and temporal discretisation. Particularly by taking into account the CFL criterion. Accommodating for this by selecting \Delta t = f_\text{CFL}(h_\text{min}) for an appropriate functional measure f_\text{CFL}(\cdot) I observe optimal \mathcal{O}(h^2) convergence rates with your Crank-Nicholson scheme.
The CFL condition! Of course! I can’t believe I forgot about it. Thank you for explaining how to get the information from the spatial domain. I’ll put in a checker at the beginning of my code to make sure I satisfy CFL.
