Error involving a list of boundary conditions
I am trying to solve a Stokes equation on a rectangle minus a disk. The mesh was generated like in Mesh generation and conversion with GMSH and PYGMSH | Jørgen S. Dokken. I have boundary conditions on the edges of the rectangle and on the boundary of the inner disk and I collect them in the list bcs. When tying to execute the last line, I’m getting Attribute error: ‘list’ object has no attribute ‘_cpp_object’, but I can’t really understand why, because in Stokes equations using Taylor-Hood elements — DOLFINx 0.10.0.0 documentation a very similar thing was done and it worked. I would very much appreciate your help! Sorry for the long code!
import pyvista as pv
from dolfinx import default_real_type
from dolfinx.fem import functionspace, Function, dirichletbc, locate_dofs_geometrical, form, Constant
from ufl import TrialFunction, TestFunction, div, grad, inner, dx
from basix.ufl import element
filename = 'mesh.xdmf'
with XDMFFile(MPI.COMM_WORLD, filename, "r") as xdmf:
       msh = xdmf.read_mesh(name="Grid")
P2 = element(
    "Lagrange", msh.basix_cell(), degree=2, shape=(msh.geometry.dim,), dtype=default_real_type
P1 = element("Lagrange", msh.basix_cell(), degree=1, dtype=default_real_type)
V, Q = functionspace(msh, P2), functionspace(msh, P1)
gdim = 2
def circle_boundary(x):
    return np.isclose((x[0] - 10)**2 + (x[1] - 5)**2, 2.5**2)
def left_boundary(x):
    return np.isclose(x[0], 0)
def top_bottom_boundary(x):
    return np.isclose(x[1], 0) | np.isclose(x[1], 10)
def right_boundary(x):
    return np.isclose(x[0], 30)
class InletVelocity():
    def __init__(self):
        pass
    def __call__(self, x):
        values = np.zeros((gdim, x.shape[1]), dtype=PETSc.ScalarType)
        values[0] = x[1] * (10 - x[1]) / (25.0)
        return values
class CircleBoundary():
    def __init__(self):
        pass
        values[0] = c1 * np.sin(np.arctan2(x[1] - 5, x[0] - 10)) + d1 * np.cos(np.arctan2(x[1] - 5, x[0] - 10)) + c2 * np.sin(np.arctan2(x[1] - 5, x[0] - 10))**2 + d2 * np.cos(np.arctan2(x[1] - 5, x[0] - 10))**2
        values[1] = c1 * np.sin(np.arctan2(x[1] - 5, x[0] - 10)) + d1 * np.cos(np.arctan2(x[1] - 5, x[0] - 10)) + c2 * np.sin(np.arctan2(x[1] - 5, x[0] - 10))**2 + d2 * np.cos(np.arctan2(x[1] - 5, x[0] - 10))**2
        return values
class NoSlip():
    def __init__(self):
        pass
        return values
class OutletPressure():
    def __init__(self):
        pass
        values = np.zeros((x.shape[1],), dtype=PETSc.ScalarType)
        return values
c1, d1, c2, d2 = 0.1, -0.1, -0.2, 0.2
u_inlet = Function(V)
inlet_velocity = InletVelocity()
u_inlet.interpolate(inlet_velocity)
bcu_inlet = dirichletbc(u_inlet, locate_dofs_geometrical(V, left_boundary))
m = Function(V)
circleboundary = CircleBoundary()
m.interpolate(circleboundary)
bcm = dirichletbc(m, locate_dofs_geometrical(V, circle_boundary))
u_noslip = Function(V)
noslip = NoSlip()
u_noslip.interpolate(noslip)
bcu_noslip = dirichletbc(u_noslip, locate_dofs_geometrical(V, top_bottom_boundary))
p_outlet = Function(Q)
outlet_pressure = OutletPressure()
p_outlet.interpolate(outlet_pressure)
bcp = dirichletbc(p_outlet, locate_dofs_geometrical(Q, right_boundary))
bcs = [bcu_inlet, bcm, bcu_noslip, bcp]
(u, p) = TrialFunction(V), TrialFunction(Q)
(v, q) = TestFunction(V), TestFunction(Q)
f = Constant(msh, (PETSc.ScalarType(0), PETSc.ScalarType(0)))
a = form([[inner(grad(u), grad(v)) * dx, inner(p, div(v)) * dx], [inner(div(u), q) * dx], None])
L = form([inner(f, v) * dx, inner(Constant(msh, PETSc.ScalarType(0)), q) * dx])
problem = LinearProblem(a, L, [bcu_inlet, bcu_noslip, bcm, bcp])
uh = problem.solve()
LinearProblem is an helper function that only works for non block cases (i.e., a plain ufl form, not a list of forms), as clearly stated in the documentation (see for instance dolfinx/python/dolfinx/fem/petsc.py at a1bd6f697e1784c7001caf9ebb32673b1fb22412 · FEniCS/dolfinx · GitHub )
Note that indeed it is not used in the demo you linked to. Instead, follow one of the two approches (monolithic block matrix or nested block matrix) used in the demo.
Hello Francesco,
thank you for your reply and thanks for pointing out that LinearProblem cannot work. If I use
A = assemble_matrix_block(a, bcs=bcs)
or
A = fem.petsc.assemble_matrix_nest(a, bcs=bcs)
I get the error RuntimeError: Diagonal sub-block (1, 1) cannot be ‘None’ and have DirichletBC applied. Consider assembling a zero block.
I now tried to copy the approach in The Stokes equations — FEniCS 22 tutorial and instead of using the function create_velocity_bc, I used my boundary conditions bcs, but the function solve_stokes fails with an assertion error in the line where
assert nsp.test(A)
I guess the variational formulation as specified in the link does not apply for my problem, as I have also boundary conditions for the pressure. Can someone help me to formulate the correct one? Thanks in advance.
You don’t need the null space at all if you have boundary conditions for the pressure, so drop it.
As you want to apply boundary conditions for the pressure, you need to assemble a zero sub-block instead of None, as the error message states. So you probably would need to change
a = form([[ inner(grad(u),  grad(v)) * dx, inner(p, div(v)) * dx], [inner(div(u), q) * dx, None]])
to
a = form([[ inner(grad(u),  grad(v)) * dx, inner(p, div(v)) * dx], [inner(div(u), q) * dx, inner(Constant(domain, ScalarType(0)), q) * p * dx]])
