Error on combine test or trial functions from different spaces
I encountered an error message as follow. I tried some online solutions but they don’t work in my case. Would anyone be able to offer me some guidance or assistance?
Found different Arguments with same number and part.
Did you combine test or trial functions from different spaces?
The Arguments found are:
  v_0
  v_1
  v_1
  v_0
ERROR:UFL:Found different Arguments with same number and part.
  v_0
  v_1
  v_1
  v_0
  File "/Users/victoriachan/Documents/CityU Doc/FYP/python_files/ProgramV3.py", line 53, in <module>
    a = form(inner(kappa * div(w), div(p)) * dx + inner(grad(kappa * div(w)), p - grad(v)) * ds + inner(w - grad(u), grad(kappa * div(p))) * ds + tau/h**2 * inner(kappa*(w - grad(u)), p - grad(v)) * ds)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 176, in form
    return _create_form(form)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 171, in _create_form
    return _form(form)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/dolfinx/fem/forms.py", line 145, in _form
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ffcx/codegeneration/jit.py", line 165, in compile_forms
    ffcx.naming.compute_signature(forms, _compute_option_signature(p)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ffcx/naming.py", line 33, in compute_signature
    object_signature += ufl_object.signature()
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/form.py", line 435, in signature
    self._compute_signature()
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/form.py", line 685, in _compute_signature
    self._compute_renumbering())
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/form.py", line 648, in _compute_renumbering
    cn = self.coefficient_numbering()
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/form.py", line 421, in coefficient_numbering
    self._analyze_form_arguments()
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/form.py", line 635, in _analyze_form_arguments
    arguments, coefficients = extract_arguments_and_coefficients(self)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/algorithms/analysis.py", line 139, in extract_arguments_and_coefficients
    error(msg)
  File "/Users/victoriachan/opt/anaconda3/envs/fenicsdolxconda/lib/python3.10/site-packages/ufl/log.py", line 135, in error
ufl.log.UFLException: Found different Arguments with same number and part.
  v_0
  v_1
  v_1
  v_0
My code:
from dolfinx import fem
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc,
                         extract_function_spaces, form,
                         locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle,
                          locate_entities_boundary)
from ufl import div, ds, dx, grad, inner
# Create mesh
msh = create_rectangle(MPI.COMM_WORLD,
                       [np.array([0, 0]), np.array([1, 1])],
                       [32, 32],
                       CellType.triangle, GhostMode.none)
def noslip_boundary(x):
    return np.logical_or(np.logical_or(np.isclose(x[0], 0.0),
                                       np.isclose(x[0], 1.0)),
                         np.logical_or(np.isclose(x[1], 0.0),
                                       np.isclose(x[1], 1.0)))
P2 = ufl.VectorElement("Lagrange", msh.ufl_cell(), 2)
P1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
V, Q = FunctionSpace(msh, P2), FunctionSpace(msh, P1)
noslip = np.zeros(msh.geometry.dim, dtype=PETSc.ScalarType)
facets = locate_entities_boundary(msh, 1, noslip_boundary)
bc0 = dirichletbc(noslip, locate_dofs_topological(V, 1, facets), V)
bcs = [bc0] # For more than 1 boundary conditions: bcs = [bc0, bc1]
(w, u) = ufl.TrialFunction(V), ufl.TrialFunction(Q)
(p, v) = ufl.TestFunction(V), ufl.TestFunction(Q)
kappa = 1.0
tau = 1.0
h = 3.0
# a = inner(kappa * div(w), div(p)) * dx + inner(grad(kappa * div(w)), p - grad(v)) * ds + inner(w - grad(u), grad(kappa * div(p))) * ds + tau/h**2 * inner(kappa*(w - grad(u)), p - grad(v)) * ds
A = fem.petsc.assemble_matrix(a, bcs=bcs)
I’ve already told you that you should use a Mixed-element.
In general, I would strongly advice you to familiarize yourself with the demos
https://docs.fenicsproject.org/dolfinx/v0.6.0/python/demos.html#demos
and if you want more details, consider the tutorial:
https://jsdokken.com/dolfinx-tutorial/
Thanks @dokken. I tried but I can’t find the term “norm_u_0” . Am I missing something?
My code:
# Create mesh
                       [32, 32],
# Create the function space
TH = P2 * P1
W = FunctionSpace(msh, TH)
W0, _ = W.sub(0).collapse()
# Function to mark x = 0, x = 1, y = 0, y = 1
# No slip boundary condition
noslip = Function(V)
dofs = locate_dofs_topological((W.sub(0), V), 1, facets)
bc0 = dirichletbc(noslip, dofs, W.sub(0))
# Since for this problem the pressure is only determined up to a
# constant, we pin the pressure at the point (0, 0)
zero = Function(Q)
zero.x.set(0.0)
dofs = locate_dofs_geometrical((W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc1 = dirichletbc(zero, dofs, W.sub(1))
bcs = [bc0, bc1]
(w, u) = ufl.TrialFunctions(W)
(p, v) = ufl.TestFunctions(W)
kappa = 1.0
tau = 1.0
h = 3.0
L = form(inner(u, v) * dx)
# Assemble LHS matrix and RHS vector
b = fem.petsc.assemble_vector(L)
# Set Dirichlet boundary condition values in the RHS
fem.petsc.set_bc(b, bcs)
# Create and configure solver
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("superlu_dist")
# Compute the solution
U = Function(W)
ksp.solve(b, U.vector)
u = U.sub(0).collapse()
p = U.sub(1).collapse()
# Compute norms
norm_u_3 = u.x.norm()
norm_p_3 = p.x.norm()
if MPI.COMM_WORLD.rank == 0:
    print("(D) Norm of velocity coefficient vector (monolithic, direct): {}".format(norm_u_3))
    print("(D) Norm of pressure coefficient vector (monolithic, direct): {}".format(norm_p_3))
assert np.isclose(norm_u_3, norm_u_0)
# Write the solution to file
with XDMFFile(MPI.COMM_WORLD, "out_stokes/new_velocity.xdmf", "w") as ufile_xdmf:
    u.x.scatter_forward()
    ufile_xdmf.write_mesh(msh)
    ufile_xdmf.write_function(u)
with XDMFFile(MPI.COMM_WORLD, "out_stokes/my.xdmf", "w") as pfile_xdmf:
    p.x.scatter_forward()
    pfile_xdmf.write_mesh(msh)
    pfile_xdmf.write_function(p)
The error message:
(D) Norm of velocity coefficient vector (monolithic, direct): nan
(D) Norm of pressure coefficient vector (monolithic, direct): nan
  File "/Users/victoriachan/Documents/CityU Doc/FYP/python_files/ProgramV4.py", line 98, in <module>
NameError: name 'norm_u_0' is not defined. Did you mean: 'norm_u_3'?
Also, I am wondering from which part I can start to solve the problem to get its eigenvalue. Thank you so much for your kind help.
Please look carefully at the demo, as norm_u_0 = u.x.norm() is defined in the code.
Eigenvalue problems are solved with SLEPc.
This has been illustrated in many posts on the forum (for instance: Eigenvalue solver problem) and in the documentation I’ve already referred you to.
Please spend some time reading through the demos and related posts before asking further questions.
Ok, thank you so much!
