Hello everyone, I am actually trying to solve a 3D traction problem and I would like to use mpirun.
However the following error occurs whenever I try to :
Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 2 with PID 0 on node rep-calcul1 exited on signal 11 (Segmentation fault).
Here is the code I am currently using :
