I’ve written code inspired by this example on performing a parametric study in parallel, where one uses MPI_COMM_SELF and MPI_COMM_WORLD. My code only works for one process and never seems to terminate for 2 processes or more. I am sure it’s not a memory issue because the mesh size is quite small. It does end when you take the write and read part out from the first “if” condition, so it seems to be fenics related. Does anyone know why this does not run (or end) with mpirun -np 2 python parallel.py
Here is the executable code:
# vim: tabstop=8 expandtab shiftwidth=4 softtabstop=4
import random
import pickle
import time
# import index_handler
import sys
N = 100
deg_fe = 1
mesh = UnitSquareMesh(N, N)
#Define periodic boundary conditions.
#Left edge and bottom edge are target domain
return ((near(x[0], 0) or near(x[1], 0.)) and not (near(x[0], 1.) or near(x[1], 1.))) and on_boundary
def map(self, x, y):
#Map top right corner to origin.
if near(x[0], 1.) and near(x[1], 1.):
y[0] = x[0] - 1.
y[1] = x[1] - 1.
#Map right edge of domain to left edge.
elif near(x[0], 1.):
y[0] = x[0] - 1.
y[1] = x[1]
#Map top edge of domain to bottom edge.
elif near(x[1], 1.):
y[0] = x[0]
y[1] = x[1] - 1.
#Need else statement for some unknown reason.
y[0] = -1.
y[1] = -1.
# Define mesh, function space, and BC
pbc = PeriodicBoundary()
V = FunctionSpace(mesh, 'CG', deg_fe, constrained_domain=pbc) #Function space for FE solution
directorypath = "results/"
comm = MPI.COMM_WORLD
rank = comm.Get_rank()
size = comm.Get_size()
if(rank == 0):
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=1)
fFile = HDF5File(MPI.COMM_SELF,directorypath+"potential.h5","w")
fFile.write(interpolate(f, V), "/V")
fFile.close()
fFile = HDF5File(MPI.COMM_SELF,directorypath+"potential.h5","r")
W = Function(V)
fFile.read(W, "/V")
fFile.close()
comm.barrier()
def print_rank(rank):
print(rank)
print_rank(rank)
