I am encountering an error when running this minimal working example (see below) of a nonlinear mixed FEniCSx problem inside an HPC environment using Apptainer. I built the FEniCSx image inside the container, but I am unsure whether the issue is related to PETSc configuration, MPI, or how dolfinx was built inside the container.
Issue : I repeatedly encounter Runtime Error PETSc code 63, and AttributeError of ‘NonlinearProblem’ object having no attribute ‘_snes’. This is when trying to initialize the nonlinear problem instance in the code line
problem = NonlinearProblem(F, U, J=fem.form(J), bcs=[bc], petsc_options_prefix=petsc_options)
The FEniCSx configuration I have inside the container is :
Python 3.12.3
/dolfinx-env/bin/python
fenics-basix 0.10.0
fenics-dolfinx 0.10.0
fenics-ufl 2025.2.0
mpi4py 4.1.1
petsc4py 3.24.0
Here is the MWE :
from dolfinx import mesh, fem, io, nls, log, io
import os
import basix
a = 10 # domain size
b = 6 # height of initial gaussian
c = 5e-2 # stdev of initial gaussian
kappa = 0.1 # diffusion coefficient
Pe = 0.5 # Desired Peclet Number (to compute mesh size, always <1)
cfl = 0.5
alpha = 1e-3 # reaction term
q = 1 # constant in the beta-term, equal to q/epsilon where q=1
epsilon = 0.3 # constant in the reaction term
u_pc = 3 # limit in the step-function
t = 0 # Start time
T = 30 # End time
max_wind = 1
nx, ny = 200,200
h = (a/200)
dt = 0.1
num_steps = np.int64(T//dt)
# initialize domain
bottom_left = np.array([-a,-a])
top_right = np.array([a,a])
domain = mesh.create_rectangle(MPI.COMM_WORLD, [bottom_left, top_right], [nx, nx], mesh.CellType.triangle)
el_u = basix.ufl.element("Lagrange", domain.basix_cell(), 1)
el_beta = basix.ufl.element("Lagrange", domain.basix_cell(), 1)
el_mixed = basix.ufl.mixed_element([el_u, el_u])
mixed_space = fem.functionspace(domain, el_mixed)
# set homogenous dirichlet bcs
w_D = fem.Function(mixed_space)
w_D.x.array[:] = 0.0
boundary_facets = mesh.locate_entities_boundary(domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
wh = fem.Function(mixed_space)
dofs = fem.locate_dofs_topological(mixed_space, fdim, boundary_facets)
bc = fem.dirichletbc(w_D, dofs)
bc.set(wh.x.array)
wh.x.scatter_forward()
# setup variational form
# Test functions and unknown
V0 = mixed_space.sub(0).collapse()[0]
V1 = mixed_space.sub(1).collapse()[0]
v_, w_ = ufl.TestFunctions(mixed_space)
U = fem.Function(mixed_space) # unknown solution
u_, beta_ = ufl.split(U)
U_prev = fem.Function(mixed_space)
a, b, c = 20, 6, 5e-2
def ic_func_u(x):
y = 6 * np.exp( -0.05* ((x[0]+9)**2 + (x[1]+9)**2))
return y
def ic_func_beta(x):
# x has shape (gdim, npoints)
npoints = x.shape[1]
return np.random.uniform(0.0, 1.0, size=npoints)
U_prev.sub(0).interpolate(ic_func_u)
U_prev.sub(1).interpolate(ic_func_beta)
u_prev_fn, beta_prev_fn = U_prev.split()
u_pc_const = fem.Constant(domain, PETSc.ScalarType(u_pc))
delta_const = fem.Constant(domain, PETSc.ScalarType(0.05))
t = (u_ - (u_pc - delta_const)) / (2.0 * delta_const)
# polynomial ramp
ramp = 3*t**2 - 2*t**3
H = ufl.conditional(ufl.lt(u_, u_pc - delta_const), 0.0, ufl.conditional(ufl.gt(u_, u_pc + delta_const), 1.0, ramp))
dt_const = fem.Constant(domain, PETSc.ScalarType(dt))
epsilon_const = fem.Constant(domain, PETSc.ScalarType(epsilon))
q_const = fem.Constant(domain, PETSc.ScalarType(q))
kappa_const = fem.Constant(domain, PETSc.ScalarType(kappa))
alpha_const = fem.Constant(domain, PETSc.ScalarType(alpha))
u_term = u_ / (1 + epsilon_const * u_)
F1 = ((-H * (epsilon_const / q_const) * ufl.exp(u_term) * beta_) * dt_const * v_
- beta_ * v_
+ beta_prev_fn * v_) * ufl.dx
val_c = fem.Constant(domain, PETSc.ScalarType(float(np.sqrt(2)/(2))))
wind_vec = ufl.as_vector([val_c, val_c])
F2 = ((kappa_const * ufl.dot(ufl.grad(u_), ufl.grad(w_))
+ w_ * ufl.dot(wind_vec, ufl.grad(u_))
- H * beta_ * ufl.exp(u_term) * w_
+ alpha_const * u_ * w_) * dt_const
+ u_ * w_ - u_prev_fn * w_) * ufl.dx
F = F1 + F2
u_sol = fem.Function(V0)
beta_sol = fem.Function(V1)
# setup solver
problem = NonlinearProblem(F, U, bcs=[bc])
# configure linear solver
solver.report = False
solver.error_on_nonconvergence = True
solver.rtol = np.sqrt(np.finfo(float).eps) * 1e-2
ksp = solver.krylov_solver
opts = PETSc.Options()
prefix = ksp.getOptionsPrefix()
opts[f"{prefix}ksp_rtol"] = 1e-8
opts[f"{prefix}ksp_max_it"] = 1000
sys = PETSc.Sys()
if sys.hasExternalPackage("superlu_dist"):
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "superlu_dist"
elif sys.hasExternalPackage("mumps"):
ksp.setFromOptions()
solver.solve(U)
