I am working on solving a set of two non-linear differential equations that are also time dependent. I am using the version fenics-dolfinx 0.9.0 and fenics-ufl 2024.2.0 and I installed them using conda-forge on my macOS Ventura13.1 (chip M1). My MWE is the following:
import pygmsh
from dolfinx import fem, io
from ufl import TestFunction, TrialFunction, inner, dx, grad, SpatialCoordinate
# %% Create mesh
# Generate the spherical surface mesh with pygmsh
with pygmsh.geo.Geometry() as geom:
radius = 1.0 # Radius of the sphere
sphere = geom.add_ball([0, 0, 0], radius, mesh_size=0.05)
mesh = geom.generate_mesh(dim=2)
# Filter out mixed cells and retain only triangles
triangle_cells = mesh.cells_dict["triangle"]
mesh = meshio.Mesh(
points=mesh.points,
# Save the filtered mesh in XDMF format
meshio.write("SphericalSurfaceMesh.xdmf", mesh)
# %% Load the mesh and integrate the system
# Load the filtered mesh into FEniCSx
with io.XDMFFile(MPI.COMM_WORLD, "SphericalSurfaceMesh.xdmf", "r") as infile:
fenics_mesh = infile.read_mesh(name="Grid")
Du = fem.Constant(fenics_mesh, 1.0)
# Define the function space for the scalar fields u1 and u2
V = fem.functionspace(fenics_mesh, ("CG", 1))
# Initial conditions
x = SpatialCoordinate(fenics_mesh)
u1 = fem.Function(V) # Current solution for u1
u2 = fem.Function(V) # Current solution for u2
u1_minus = fem.Function(V) # Previous solution for u1
u2_minus = fem.Function(V) # Previous solution for u2
def initial_conditions_u1(x):
return 1.0 + x[0]
def initial_conditions_u2(x):
return 1.0 + x[1]
u1.interpolate(initial_conditions_u1)
u2.interpolate(initial_conditions_u2)
u1_minus.x.array[:] = u1.x.array[:]
u2_minus.x.array[:] = u2.x.array[:]
# Time-stepping parameters
T = 1.0
dt = 0.1
t = dt
# Define test functions
v1 = TestFunction(V)
v2 = TestFunction(V)
# Define nonlinear functions for FHN
def f(u1, u2):
return -u1**3 + u1 - u2
def g(u1, u2):
return 0.1 * (u1 - 0.5 * u2 + 0.1)
# Residuals for u1 and u2
F1 = (inner(u1, v1) - inner(u1_minus, v1) + dt*Du*inner(grad(u1), grad(v1)) - dt*inner(f(u1, u2), v1)) * dx
F2 = (inner(u2, v2) - inner(u2_minus, v2) + dt*Du*inner(grad(u2), grad(v2)) - dt*inner(g(u1, u2), v2)) * dx
# Combine the residuals into a nonlinear problem
F_total = F1 + F2
# Define the nonlinear problem
problem = NonlinearProblem(F_total, fem.Function(V))
# Configure the solver
solver.rtol = 1e-6
solver.report = True
# PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()
opts["ksp_type"] = "gmres"
opts["pc_type"] = "hypre"
opts["pc_hypre_type"] = "boomeramg"
opts["ksp_rtol"] = 1e-8
ksp.setFromOptions()
# Time-stepping loop
while t <= T:
# Solve the nonlinear problem
n, converged = solver.solve(u1) # Use u1 as the overall solution
if not converged:
raise RuntimeError(f"Newton solver did not converge at time {t}")
# Update previous solutions
# Extract the mesh coordinates for visualization
coordinates = fenics_mesh.geometry.x # Nodal coordinates
x, y, z = coordinates[:, 0], coordinates[:, 1], coordinates[:, 2]
# Plot the solution
u1_values = u1.x.array
fig = plt.figure(figsize=(10, 10))
ax = fig.add_subplot(projection="3d")
ax.scatter(x, y, z, c=u1_values, cmap="viridis", marker="o", s=10)
And the error is the following:
File ~/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/spyder_kernels/customize/utils.py:209, in exec_encapsulate_locals(code_ast, globals, locals, exec_fun, filename)
207 if filename is None:
208 filename = "<stdin>"
--> 209 exec_fun(compile(code_ast, filename, "exec"), globals, None)
210 finally:
211 if use_locals_hack:
212 # Cleanup code
File ~/Desktop/FEMSphere_v3.py:106
103 # Time-stepping loop
104 while t <= T:
105 # Solve the nonlinear problem
--> 106 n, converged = solver.solve(u1) # Use u1 as the overall solution
107 if not converged:
108 raise RuntimeError(f"Newton solver did not converge at time {t}")
File ~/miniconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/nls/petsc.py:51, in NewtonSolver.solve(self, u)
48 def solve(self, u: fem.Function):
49 """Solve non-linear problem into function u. Returns the number
50 of iterations and if the solver converged."""
---> 51 n, converged = super().solve(u.x.petsc_vec)
52 u.x.scatter_forward()
53 return n, converged
RuntimeError: Failed to successfully call PETSc function 'KSPSolve'. PETSc error code is: 73, Object is in wrong state
It is probably due to how I am defining the variables used by the solver, but I have not found a different way to do it. I have seen similar questions in the forum but the solutions were dependent in the ‘ufl.split’ function, which I do not use in here, or in redefinition of other variables. For what I have read it might also be that the way that I update the variable at t-1 is not the correct way of doing it, but is the only replacement that I found for the old function .assign.
