Error while using NewtonSolver in conjunction with NonlinearProblem
Dear. Researchers
I have successfully programmed nonlinear time-dependent problem using fenics. To leverage the capability of fenicsx for applying multipoint constraint on the model, I have trasnsferred the code into fenicsx format. uppon runnig the code I have received the following message in the output:
solver_problem = NewtonSolver(MPI.COMM_WORLD,problem)
File “/home/mohammad-jalili/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/nls/petsc.py”, line 60, in init
self._A = create_matrix(problem.a)
AttributeError: ‘NonlinearProblem’ object has no attribute ‘a’. Did you mean: ‘A’?
Exception ignored while calling deallocator <function NewtonSolver.del at 0x794181b16a30>:
File “/home/mohammad-jalili/anaconda3/envs/fenicsx/lib/python3.14/site-packages/dolfinx/nls/petsc.py”, line 67, in del
for obj in filter(lambda obj: obj is not None, (self._A, self._b)):
AttributeError: ‘NewtonSolver’ object has no attribute ‘_A’
The solver part of the code is as follows:
‘’'python
= ufl.Measure(“dx”, domain = refined_domain)
Form_c = ((c_new - c_old)/dt_barv_cdx
+ beta*ufl.inner(ufl.grad(c_new),ufl.grad(v_c))*dx
+ ((1-n_new)*c_new)v_cdx)
zeta = c_characteristic/Molarity
Form_n = ((n_new - n_old)/dt_bar * v_n * dx
- zetac_new(1 - n_new)v_ndx)
Form_total = Form_c + Form_n
Gain = ufl.derivative(Form_total, w,dw)
problem = NonlinearProblem(Form_total, w,petsc_options_prefix= “reaction-diffusion” ,bcs = bcs_problem, J = Gain)
solver_problem.convergence_criterion = “residual”
solver_problem.atol = 1e-9
solver_problem.rtol = 1e-7
solver_problem.max_it = 10
solver_problem.report = True
solver_problem.error_on_nonconvergence = False
print(type(problem))
w_old.x.array[:] = w.x.array
for step in range(num_steps_bar):
t += dt_bar
solver_problem.solve(w)
I will be really appreciated for any assistance to resolve the issue.
You seem to be mixing the new and old implementation of NonlInearProblem, see:
and
for a usage example.
I am so grateful for your response. I have modified the solver and now it runs but the convergence is largely deteriorated compared with the Fenics-version of the code. please note that I do not change the specification and structure of Fenics counterpart while transferring the code into Fenicsx. Besides, the types of linear solver and line search method is MUMPS and “bt” for both cases. However, after running the code I have received converged_reason equal -8 which implies convergence to local minimum of weak form. During the debugging process, I have recognized that Dirichlet boundary conditions are not properly enforced. I applied the procedure described in the forum but it was unsuccessful. I will put the selected part of the code. Any assistance will be appreciated.
‘’'python
from dolfinx.mesh import create_rectangle
import basix.ufl
from dolfinx.mesh import meshtags, locate_entities_boundary
from dolfinx.fem import functionspace, Function, locate_dofs_topological, Constant, locate_dofs_geometrical
from dolfinx.mesh import compute_midpoints
from dolfinx import geometry
from dolfinx.cpp.mesh import CellType
from ufl.classes import *
from ufl.algorithms import *
from ufl import Measure
import os
from pathlib import Path
from dolfinx import default_real_type, log, plot
Time parameters
num_steps = 72000
t = 0.0
t_end = 3600
dt = t_end/num_steps
BC_thickness = 100e-6
Oxide_thickness = 1e-6
Lx = 60e-6
Ly = BC_thickness + Oxide_thickness
refine_length = BC_thickness - 10e-6
Parameters
x_bar = Ly
BC_bar = BC_thickness/x_bar
Oxide_bar = Oxide_thickness/x_bar
Lx_bar = Lx/x_bar
Ly_bar = Ly/x_bar
refine_length_bar = refine_length/x_bar
print(refine_length_bar)
c_characteristic = 0.32e6
Geometry
nx, ny = 300,1000
domain = create_rectangle(MPI.COMM_WORLD, [np.array([0,0]), np.array([Lx_bar,Ly_bar])], [nx,ny])
tdim = domain.topology.dim
def refine_cells(x, tol=1e-16):
return x[1] >= refine_length_bar + tol
cells2 = dolfinx.mesh.locate_entities(domain,tdim,refine_cells)
print(“cells shape”,np.shape(cells2))
domain.topology.create_connectivity(tdim,tdim-1)
domain_topo = domain.topology
associated_edges = dolfinx.mesh.compute_incident_entities(domain_topo,cells2,2,1)
refined_domain,,= dolfinx.mesh.refine(domain,associated_edges)
with XDMFFile(MPI.COMM_WORLD,“refined_domain_scaled.xdmf”,“w”) as xdmf:
xdmf.write_mesh(refined_domain)
element_degree = 1
variant = basix.LagrangeVariant.equispaced
c_el = basix.ufl.element(“Lagrange”, refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
n_el = basix.ufl.element(“Lagrange”, refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
total_elements = basix.ufl.mixed_element([c_el,n_el])
ME = dolfinx.fem.functionspace(refined_domain, total_elements)
w = dolfinx.fem.Function(ME)
w.name = “WW”
w_old = dolfinx.fem.Function(ME)
dw = ufl.TrialFunction(ME)
c_new,n_new = ufl.split(w)
c_old,n_old = ufl.split(w_old)
w.sub(0).x.array[:] = 0.0
w.sub(1).x.array[:] = 0.0
x= ufl.SpatialCoordinate(refined_domain)
w.sub(1).interpolate(lambda x: np.where(x[1] >= BC_bar, 1.0, 0.0))
def top(x):
return np.isclose(x[1], Ly_bar)
def bottom(x):
return np.isclose(x[1], 0.0)
c_space, _ = ME.sub(0).collapse()
c_bc_top = dolfinx.fem.Function(c_space)
c_bc_top.x.array[:] = 1.55
top_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, tdim-1, top)
top_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(0), c_space), tdim-1, top_facets)
c_space_bot, _ = ME.sub(0).collapse()
c_bc_bot = dolfinx.fem.Function(c_space)
c_bc_bot.x.array[:] = 0.0
bottom_facets = dolfinx.mesh.locate_entities_boundary(refined_domain, tdim-1, bottom)
bot_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(0), c_space), tdim-1, bottom_facets)
bc_c_top = dolfinx.fem.dirichletbc(c_bc_top, top_dofs,c_space)
bc_c_bot = dolfinx.fem.dirichletbc(c_bc_bot,bot_dofs,c_space)
bcs_problem = [bc_c_top, bc_c_bot]
Please format the code with 3x`,
i.e.
```python
# Add code here
import basix.ufl
import os
# Time parameters
num_steps = 72000
t = 0.0
t_end = 3600
Lx = 60e-6
x_bar = Ly
Lx_bar = Lx/x_bar
Ly_bar = Ly/x_bar
nx, ny = 300,1000
print("cells shape",np.shape(cells2))
refined_domain,_,_= dolfinx.mesh.refine(domain,associated_edges)
with XDMFFile(MPI.COMM_WORLD,"refined_domain_scaled.xdmf","w") as xdmf:
element_degree = 1
c_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
n_el = basix.ufl.element("Lagrange", refined_domain.topology.cell_name(), element_degree, variant, dtype = default_real_type)
v_c,v_n = ufl.TestFunctions(ME)
dc,dn = ufl.TrialFunctions(ME)
with XDMFFile(refined_domain.comm, "phase_sub.xdmf", "w") as xdmf:
    xdmf.write_function(w.sub(1))
def top(x):
def bottom(x):
bot_dofs = dolfinx.fem.locate_dofs_topological((ME.sub(0), c_space_bot), tdim-1, bottom_facets)
bc_c_top = dolfinx.fem.dirichletbc(c_bc_top, top_dofs,ME.sub(0))
bc_c_bot = dolfinx.fem.dirichletbc(c_bc_bot,bot_dofs,ME.sub(0))
D = dolfinx.fem.Constant(refined_domain,2e-13)
eta = dolfinx.fem.Constant(refined_domain,1e-5)
Molarity = dolfinx.fem.Constant(refined_domain,1.11e5)
t_characteristic = 1/(Molarity*eta)
t_bar = t_end/t_characteristic
dt_bar = dt/t_characteristic
num_steps_bar = 72000
beta = D/(Molarity*eta*x_bar**2)
dx = ufl.Measure("dx", domain = refined_domain)
Form_c = ((c_new - c_old)/dt_bar*v_c*dx
           + ((1-n_new)*c_new)*v_c*dx)
           - zeta*c_new*(1 - n_new)*v_n*dx)
problem = NonlinearProblem(Form_total, w,petsc_options_prefix= "reaction-diffusion" ,bcs = bcs_problem, J = Gain)
use_superlu = PETSc.IntType == np.int64  # or PETSc.ScalarType == np.complex64
sys = PETSc.Sys()  # type: ignore
if sys.hasExternalPackage("mumps") and not use_superlu:
    linear_solver = "mumps"
elif sys.hasExternalPackage("superlu_dist"):
    linear_solver = "superlu_dist"
    linear_solver = "petsc"
petsc_options = {
    "snes_type": "newtonls",
    "snes_linesearch_type": "bt",
    "snes_atol": 1e-5,
    "snes_rtol": 1e-6,
    "ksp_type": "preonly",
    "pc_type": "lu",
    "pc_factor_mat_solver_type":linear_solver,
    "snes_monitor": None,
    "snes_max_it": 1000
    Form_total, w, petsc_options_prefix="reaction-diffusion", petsc_options=petsc_options, J = Gain, bcs = bcs_problem
c_new_c = w.sub(0).collapse()
n_new_c = w.sub(1).collapse()
with XDMFFile(MPI.COMM_WORLD, "results2D-fenicsx/solution.xdmf", "w") as xdmfout:
    xdmfout.write_mesh(refined_domain)
    t += dt_bar
    _ = problem.solve()
    converged_reason = problem.solver.getConvergedReason()
    num_iterations = problem.solver.getIterationNumber()
    print(f"Step {step}: {converged_reason=} {num_iterations=}")
    xdmfout.write_function(c_new_c,t)
    xdmfout.write_function(n_new_c,t)
xdmfout.close()
