Error when trying to implement continuation method to run fluid flow problem at higher Reynolds numbers
I am trying to implement the method called ‘continuation’ discussed below, using a previous solution at some viscosity, to get a solution for a lower viscosity, by using the higher viscosity solution as an initial guess for the solution.
In the previous version of Fenics this was done using the assign() function, now it gives an error. What could I use now instead of that function?
I also tried:
u.vector()[:] = u_old.vector()
p.vector()[:] = p_old.vector()
u_old.vector()[:] = u.vector()
p_old.vector()[:] = p.vector()
A minimal running code giving the error is below.
Thank you,
Alex
from dolfinx import mesh, fem, io, log
from ufl import inner, div, grad, dx
import basix
import time
height = 0.06
width  = 0.08
n_h = 20
n_w = 20
msh = mesh.create_box(MPI.COMM_WORLD, ((-width/2, -width/2, 0.0), (width/2,width/2,height)), (n_h,n_h,n_w), mesh.CellType.tetrahedron)
fdim = msh.topology.dim - 1
rho_air = fem.Constant(msh, 1.225)
# Function to mark noslip
def noslip_boundary1(x):
    return np.isclose(x[2], height)
P2 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 2, shape=(msh.geometry.dim, ))
P1 = basix.ufl.element("Lagrange", msh.topology.cell_name(), 1)
V, Q = fem.functionspace(msh, P2), fem.functionspace(msh, P1)
# Create the function space
TH = basix.ufl.mixed_element([P2, P1])
W = fem.functionspace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition 1
noslip  = fem.Function(V)
facets1 = mesh.locate_entities_boundary(msh, fdim, noslip_boundary1)
dofs1   = fem.locate_dofs_topological((W.sub(0), V), fdim, facets1)
bc0     = fem.dirichletbc(noslip, dofs1, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin it at a point
zero = fem.Function(Q)
zero.x.array[:] = 0
dofs = fem.locate_dofs_geometrical(
    (W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
def body_force_fun(x):
    F_max    = 2.0e-2
    z_offset = 0.02
    r_xy = np.sqrt(x[0]**2 + x[1]**2)
    a = 0.005
    max_val = a * np.exp(-0.5)
    Fr_val  = np.exp(-r_xy**2/(2*a**2)) / max_val
    b = 0.005
    Fz_val = np.exp(-(x[2]-z_offset)**2/(2*b**2))
    F_mag  = F_max * Fr_val * Fz_val
    # -ve sign to get clockwise rotation from array top
    return -F_mag * np.vstack((x[1], -x[0], np.zeros_like(x[2])))
Force_per_unit_vol = fem.Function(V)
Force_per_unit_vol.interpolate(lambda x: body_force_fun(x))
bcs = [bc0, bc2]
w     = fem.Function(W)
w_old = fem.Function(W)
(u, p) = ufl.split(w)
(u_old, p_old) = ufl.split(w_old)
(v, q) = ufl.TestFunctions(W)
for mair in [4.0e-5, 1.8e-5]:
    mu_air  = fem.Constant(msh, mair)
    u.assign(u_old)
    p.assign(p_old)
    F = rho_air*inner(grad(u)*u, v)*dx + \
        mu_air*inner(grad(u), grad(v))*dx - \
        inner(Force_per_unit_vol, v)*dx - \
        inner(p, div(v))*dx - \
        div(u)*q*dx
    dw = ufl.TrialFunction(W)
    dF = ufl.derivative(F, w, dw)
    problem = NonlinearProblem(F, w, bcs=bcs, J=dF)
    solver.rtol   = 1e-6
    solver.report = True
    solver.error_on_nonconvergence = False
    # Custom solver options
    opts = PETSc.Options()  # type: ignore
    ksp = solver.krylov_solver
    ksp.setFromOptions()
    # Compute the solution
    start = time.time()
    solver.solve(w)
    end   = time.time()
    u_old.assign(u)
    p_old.assign(p)
    print('\n')
    print(msh.topology.index_map(msh.topology.dim).size_local)
    print((end - start) / 60)
    print('\n\n')
u = w.sub(0).collapse()
p = w.sub(1).collapse()
# Write the solution to file
with io.XDMFFile(MPI.COMM_WORLD, "pressure.xdmf", "w") as pfile_xdmf:
    p.x.scatter_forward()
    pfile_xdmf.write_mesh(msh)
    pfile_xdmf.write_function(p)
with io.XDMFFile(MPI.COMM_WORLD, "velocity.xdmf", "w") as ufile_xdmf:
    u.x.scatter_forward()
    P1 = basix.ufl.element("Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,))
    u1 = fem.Function(fem.functionspace(msh, P1))
    u1.interpolate(u)
    ufile_xdmf.write_mesh(msh)
    ufile_xdmf.write_function(u1)
with io.XDMFFile(MPI.COMM_WORLD, "body_force.xdmf", "w") as ufile_xdmf:
    Force_per_unit_vol.x.scatter_forward()
    u1.interpolate(Force_per_unit_vol)
fe.assign and u.vector()[:] has been replaced with function.x.array[:].
So in your loop, replace the fe.assign for (u, p) with
w.x.array[:] = w_old.x.array[:]
Similarly, at the end
w_old.x.array[:] = w.x.array[:]
Thank you Nick, this works
