You are simply not saving the triangle mesh to an xdmf file, thus
cannot find the file.
Here is an MWE of working code (renaming the mesh file and removing your path variable):
filename="mesh"
msh=meshio.read(filename + ".msh")
cells=mesh.get_cells_type(cell_type)
cell_data=mesh.get_cell_data("gmsh:physical", cell_type)
points = mesh.points[:,:2] if prune_z else mesh.points
out_mesh=meshio.Mesh(points=points, cells={
cell_type: cells}, cell_data={"name_to_read": [cell_data]})
return out_mesh
tetra_mesh=create_mesh(msh, "tetra")
triangle_mesh=create_mesh(msh,"triangle")
meshio.write(filename + "_tetra.xdmf", tetra_mesh)
meshio.write(filename + "_triangle.xdmf", triangle_mesh)
with XDMFFile(filename + "_tetra.xdmf") as infile:
infile.read(mesh)
mvc_3d = MeshValueCollection("size_t", mesh, 3)
infile.read(mvc_3d, "name_to_read")
mf_3d = cpp.mesh.MeshFunctionSizet(mesh, mvc_3d)
mvc_2d = MeshValueCollection("size_t", mesh, 2)
with XDMFFile(filename + "_triangle.xdmf") as infile:
infile.read(mvc_2d, "name_to_read")
mf_2d = cpp.mesh.MeshFunctionSizet(mesh, mvc_2d)
