What changed between using the linear solver and the nonlinear solver?
New to Fenics and to numerical methods for PDEs in general. Any insight would be greatly appreciated.
I’m trying to solve a nonlinear problem with mixed boundary conditions (reaction diffusion with Dirichlet, Neumann, and Robin boundary conditions). To start, I thought I would try just solving the Poisson equation using a nonlinear solver, and build everything up from there.
The following code works just fine:
box_length = 1.0
#finite element parameters
box_length_elements = 128
# Define mesh
mesh = RectangleMesh(Point(0,0), Point(box_length,box_length), box_length_elements, box_length_elements, "right/left")
# Create classes for boundaries
class Left(SubDomain):
        return near(x[0], 0.0)
class Right(SubDomain):
        return near(x[0], box_length)
class Bottom(SubDomain):
        return near(x[1], 0.0)
class Top(SubDomain):
        return near(x[1], box_length)
left = Left()
top = Top()
right = Right()
bottom = Bottom()
boundaries = MeshFunction("size_t", mesh, 1)
left.mark(boundaries, 1)
top.mark(boundaries, 2)
right.mark(boundaries, 3)
bottom.mark(boundaries, 4)
# Define model parameters
D = Constant(1.0)
g_L = Expression("- 10*exp(- pow(x[1] - 0.5, 2))", degree=2)
g_R = Constant(6.0)
f = Constant(1.0)
# Define function space
V = FunctionSpace(mesh, "CG", 2)
# Dirichlet boundary conditions
bcs = [DirichletBC(V, 5.0, boundaries, 2),
       DirichletBC(V, 0.0, boundaries, 4)]
# Define measures for boundary terms
# Define variational form
F = inner(D*grad(u), grad(v))*dx - g_L*v*ds(1) - g_R*v*ds(3) - f*v*dx
a, L = lhs(F), rhs(F)
# Solve problem
solve(a == L, u, bcs)
# Plot solution and gradient
plot(u)
When I change a == L to F == 0 and correspondingly change u = TrialFunction(V) to u = Function(V), DOLPHIN returns the error
Unable to successfully call PETSc function 'MatSetValuesLocal'
What is going on here? What’s the minimal change to this code to use the nonlinear solver?
You probably redefined u in your code.
Here is a minimal example uses the non-linear solver, where the only addition I’ve made to your code is setting a0=1, as you did not define it in your code.
box_length = 1.0
# finite element parameters
# Define mesh
mesh = RectangleMesh(Point(0, 0), Point(box_length, box_length),
left = Left()
top = Top()
right = Right()
bottom = Bottom()
a0 = 1
D = Constant(1.0)
g_R = Constant(6.0)
f = Constant(1.0)
F = inner(a0*grad(u), grad(v))*dx - g_L*v*ds(1) - g_R*v*ds(3) - f*v*dx
#a, L = lhs(F), rhs(F)
# Solve problem
# u = Function(V)
# solve(a == L, u, bcs)
solve(F == 0, u, bcs=bcs)
plot(u)
Thanks so much for the quick reply! Yes, it looks like redefining u was the issue. Thanks so much!
