Hi everyone!
I used dolfinx 0.4.0 version and my code runs. But i upgraded ububtu to version 22.04 to install dolfinx 0.5.2.
And now I have a problem with dolfinxgeometry.compute_closest_entity.
Now I get this error in a vertex…
RuntimeError: GJK error: max iteration limit reached
my code
vx_np = np.loadtxt('vx.txt')
vx_aux = vx_np[:,1:4]
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "venturi.xdmf", "r") as xdmf:
domain = xdmf.read_mesh(name="Grid")
cf = xdmf.read_meshtags(domain, name = 'Grid')
tdim = domain.topology.dim
tree = dolfinx.geometry.BoundingBoxTree(domain, tdim)
num_entities_local = domain.topology.index_map(tdim).size_local + domain.topology.index_map(tdim).num_ghosts
entities = np.arange(num_entities_local, dtype = np.int32)
mid_tree = dolfinx.geometry.create_midpoint_tree(domain, tdim,entities)
mesh_geom = domain.geometry.x
tol = 1e-5
def closest_point(mesh, point,tol):
points = point
entity = dolfinx.geometry.compute_closest_entity(tree, mid_tree, mesh, points)
geom_dof = dolfinx.cpp.mesh.entities_to_geometry(mesh,tdim,[entity], False)
#print('geom',geom_dof)
mesh_nodes = mesh_geom[geom_dof][0]
#print('mesh_nodes', mesh_nodes)
dis = dolfinx.geometry.compute_distance_gjk(points, mesh_nodes)
#print('dis',dis)
index = -100
for i in range(len(mesh_nodes)):
#print(mesh_nodes[i])
if np.abs(mesh_nodes[i][0]-points[0]+ dis[0]) < tol and np.abs(mesh_nodes[i][1]-points[1]+ dis[1]) < tol and np.abs(mesh_nodes[i][2]-points[2]+ dis[2]) < tol :
index = i
if (index == -100):
return point, index
return points - dis , geom_dof[0][index]
b = []
indices = []
ind = int(0)
for i in range(len(vx_aux)):
if(i%20000 == 0):
print(i)
a,j = closest_point(domain,vx_aux[i],tol)
if (j == -100):
b.append(a)
indices.append(0)
indices.append(j)
The flies are here 136.02 MB folder on MEGA
Thank you!
