Error with time-dependent pressure boundary condition with Oasisx
Good evening,
I am trying to solve the unsteady Navier Stokes equation in a complex geometry, and for now everything worked fine using Oasisx.
However, I want to try to implement a time-dependent Dirichlet boundary condition for the pressure, but I cannot implement it.
As my code is very long, I implemented a time-dependent pressure condition starting from this code and also referring to the definition of oasisx.PressureBC here.
The MWE is:
import oasisx
from oasisx import DirichletBC, LocatorMethod, FractionalStep_AB_CN
from typing import List
def inlet(x):
    return np.isclose(x[0], 0)
def wall(x):
    return np.logical_or(np.isclose(x[1], 0), np.isclose(x[1], 1))
def outlet(x):
    return np.isclose(x[0], 10)
domain = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([10, 1])], [
    50, 5], cell_type=dolfinx.mesh.CellType.triangle)
bcs_p: List[oasisx.PressureBC] = []
bc_inlet_x = DirichletBC(dolfinx.fem.Constant(domain, 1.),
                         method=LocatorMethod.GEOMETRICAL, marker=inlet)
bc_inlet_y = DirichletBC(dolfinx.fem.Constant(domain, 0.),
bc_wall = DirichletBC(dolfinx.fem.Constant(domain, 0.), method=LocatorMethod.GEOMETRICAL,
                      marker=wall)
outlet_facets = dolfinx.mesh.locate_entities_boundary(domain, domain.topology.dim - 1, outlet)
ft = dolfinx.mesh.meshtags(domain, domain.topology.dim-1, outlet_facets,
                           np.full_like(outlet_facets, 1, dtype=np.int32))
class  Pressure_Outlet():
    def __init__(self, t:float):
        self.t = t
    def eval(self,x: np.typing.NDArray[np.float64]):
        return 1*self.t
t = 0.
p_val = Pressure_Outlet(t)
bcs_p: List[oasisx.PressureBC] = [oasisx.PressureBC(p_val.eval, (ft, 1))]
bcs_u = [[bc_inlet_x, bc_wall], [bc_wall, bc_inlet_y]]
# fractional step solver
solver = FractionalStep_AB_CN(
    mesh=domain,
    u_element=("Lagrange", 2),
    p_element=("Lagrange", 1),
    bcs_u=bcs_u,
    bcs_p=bcs_p,
    solver_options={"tentative": {"ksp_type": "preonly", "pc_type": "lu"}, "pressure": {
        "ksp_type": "preonly", "pc_type": "lu"}, "scalar": {"ksp_type": "preonly", "pc_type": "lu"}},
    body_force=None
# Time-stepping
T_start, T_end, dt = 0.0, 1, 0.001
num_steps = int((T_end - T_start) // dt)
with dolfinx.io.VTXWriter(domain.comm, "poisseuille.bp", [solver.u], engine="BP4") as writer:
    for step in range(num_steps):
        p_val.t = t
        solver.solve(dt, nu=0.01, max_iter=10)
        writer.write(dt*step)
And the error is:
TypeError                                 Traceback (most recent call last)
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/oasisx/bcs.py:215, in PressureBC.create_bcs(self, V, Q)
    214 try:
--> 215     rhs = [self._value * n_i * v.dx(i) * ds for i, n_i in enumerate(n)]
    216 except TypeError:
    217     # If input is lambda function interpolate into local function
TypeError: unsupported operand type(s) for *: 'method' and 'Indexed'
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py:397, in Function.interpolate(self, u, cells, nmm_interpolation_data)
    395 try:
    396     # u is a Function or Expression (or pointer to one)
--> 397     _interpolate(u, cells)
    398 except TypeError:
    399     # u is callable
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/functools.py:909, in singledispatch.<locals>.wrapper(*args, **kw)
    906     raise TypeError(f'{funcname} requires at least '
    907                     '1 positional argument')
--> 909 return dispatch(args[0].__class__)(*args, **kw)
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py:373, in Function.interpolate.<locals>._interpolate(u, cells)
    372 """Interpolate a cpp.fem.Function"""
--> 373 self._cpp_object.interpolate(u, cells, nmm_interpolation_data)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. (self: dolfinx.cpp.fem.Function_float64, f: numpy.ndarray[numpy.float64], cells: numpy.ndarray[numpy.int32]) -> None
    2. (self: dolfinx.cpp.fem.Function_float64, u: dolfinx.cpp.fem.Function_float64, cells: numpy.ndarray[numpy.int32], nmm_interpolation_data: Tuple[List[int], List[int], List[float], List[int]]) -> None
    3. (self: dolfinx.cpp.fem.Function_float64, expr: dolfinx::fem::Expression<double, double>, cells: numpy.ndarray[numpy.int32]) -> None
Invoked with: <dolfinx.cpp.fem.Function_float64 object at 0x7f3b3720d0b0>, <bound method Pressure_Outlet.eval of <__main__.Pressure_Outlet object at 0x7f3b372b4110>>, array([  0,   1,   2,   3,   4,   5,   6,   7,   8,   9,  10,  11,  12,
        13,  14,  15,  16,  17,  18,  19,  20,  21,  22,  23,  24,  25,
        26,  27,  28,  29,  30,  31,  32,  33,  34,  35,  36,  37,  38,
        39,  40,  41,  42,  43,  44,  45,  46,  47,  48,  49,  50,  51,
        52,  53,  54,  55,  56,  57,  58,  59,  60,  61,  62,  63,  64,
        65,  66,  67,  68,  69,  70,  71,  72,  73,  74,  75,  76,  77,
        78,  79,  80,  81,  82,  83,  84,  85,  86,  87,  88,  89,  90,
        91,  92,  93,  94,  95,  96,  97,  98,  99, 100, 101, 102, 103,
       104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116,
       117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129,
       130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142,
       143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155,
       156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168,
       169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181,
       182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194,
       195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207,
       208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220,
       221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233,
       234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246,
       247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259,
       260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272,
       273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285,
       286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298,
       299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311,
       312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324,
       325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337,
       338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350,
       351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363,
       364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376,
       377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389,
       390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402,
       403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415,
       416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428,
       429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441,
       442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454,
       455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467,
       468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480,
       481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493,
       494, 495, 496, 497, 498, 499], dtype=int32), ((), (), (), ())
IndexError                                Traceback (most recent call last)
Cell In[3], line 49
     44 bcs_u = [[bc_inlet_x, bc_wall], [bc_wall, bc_inlet_y]]
     48 # fractional step solver
---> 49 solver = FractionalStep_AB_CN(
     50     mesh=domain,
     51     u_element=("Lagrange", 2),
     52     p_element=("Lagrange", 1),
     53     bcs_u=bcs_u,
     54     bcs_p=bcs_p,
     55     solver_options={"tentative": {"ksp_type": "preonly", "pc_type": "lu"}, "pressure": {
     56         "ksp_type": "preonly", "pc_type": "lu"}, "scalar": {"ksp_type": "preonly", "pc_type": "lu"}},
     57     body_force=None
     58 )
     61 # Time-stepping
     62 T_start, T_end, dt = 0.0, 1, 0.001
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/oasisx/fracstep.py:198, in FractionalStep_AB_CN.__init__(self, mesh, u_element, p_element, bcs_u, bcs_p, solver_options, jit_options, body_force, options)
    196 self._bcs_p = bcs_p
    197 for bcp in self._bcs_p:
--> 198     bcp.create_bcs(self._Vi[0][0], self._Q)
    199     for i in range(self._mesh.geometry.dim):
    200         forms[i].append(bcp.rhs(i))
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/oasisx/bcs.py:219, in PressureBC.create_bcs(self, V, Q)
    218     self._u = _fem.Function(Q)
--> 219     self._u.interpolate(self._value)  # type: ignore
    220     rhs = [self._u * n_i * v.dx(i) * ds for i, n_i in enumerate(n)]
    222 # Create rhs contribution from natural boundary condition
File ~/anaconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py:402, in Function.interpolate(self, u, cells, nmm_interpolation_data)
    400 assert callable(u)
    401 x = _cpp.fem.interpolation_coords(self._V.element, self._V.mesh.geometry, cells)
--> 402 self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells)
IndexError: invalid axis: 0 (ndim = 0)
I do not understand what am I doing wrong, as I implemented other time-dependent Dirichlet boundary condition for the velocity with a similar sintax without getting any error.
Then, as I am asking about time dependent pressure boundary condition, I know that using this kind of boundary condition with IPCS scheme is not well supported, and I tried to follow the suggestions given in this reply modifying the scheme as suggested, however even if I got overall convergence I have unphysical solution on the boundary where the dirichlet pressure is imposed.
Any suggestion to which scheme could better suit a time-dependent pressure profile to be imposed on a boundary?
Thank you for your time.
I’m not at a computer for a few days, but this looks wrong to me, as I think it should be
        return  np.full(x.shape[1], 1*self.t, dtype=dolfinx.default_scalar_type)
As the code expects an array of size number of points out.
This is illustrated in the documentation of PressureBC (see examples: time dependent bc) API Reference — Oasisx
Please also note that this doesn’t set the pressure strongly, but as -nu du/dn +pn = g(t) as also stated in the documentation
