I’m working on a transient thermo-mechanical problem and I’ve noticed that the execution time increases significativally when I substitute the constant source term with a time dependent source term.
With the constant source (declared as f = fem.Constant(msh, ScalarType((0.0, 0.0))) ), execution takes around 1.5s, whereas with the time dependent source, it takes around 117.6s. Therefore, I’m wondering if there is a more efficient way of defining or updating this function.
The strategy I’m using is to define the source term as a function f_exp(x,t) and using interpolate for uptading at each step t, ie.,
f.interpolate(partial(f_exp_1, t)).
Indeed, I’ve noticed that it is the interpolation itself that is consuming a lot of time. As illustrated on the MWE bellow, interpolationg for a fixed time step takes around 6 seconds, even with a small mesh (20x20). Hence, when executing the transient problem, with several time steps, the execution time is very high.
I wonder if anyone could help me understand why this interpolation is taking so long. I suspect it has something to do with the way I define this long expression, since the second one (simpler) takes substantially less time.
Exists on my machine were:
Execution time 1: 6.352968215942383
Execution time 2: 0.002003192901611328
Any suggestions? I appreciate very much any help.
# Auxiliary packages
from petsc4py import PETSc # Linear algebra backend
from mpi4py import MPI # MPI
# Import dolfinx and ufl modules
from dolfinx import geometry
from dolfinx import fem
from dolfinx import io
from dolfinx import la
from dolfinx.mesh import (CellType, create_unit_square, locate_entities, exterior_facet_indices, create_rectangle, meshtags)
from ufl import sin, SpatialCoordinate, FiniteElement, VectorElement, MixedElement, TestFunction, TrialFunction, split, Identity, Measure, dx, ds, grad, nabla_grad, div, dot, inner, tr, as_vector, FacetNormal
from functools import partial
# Import dolfinx modules and ufl
from dolfinx.io import gmshio
import dolfinx.cpp as _cpp
import time
Lx = 1.0; Ly = 1.0; N = 20
msh = create_rectangle(comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (Lx, Ly)), n=(N, N),
cell_type=CellType.triangle, diagonal = dolfinx.cpp.mesh.DiagonalType.crossed)
E, nu = 30e9, 0.25 # Young modulus, Poisson ratio
mu = fem.Constant(msh, ScalarType(E/(2.0*(1.0 + nu)))) # Lamé constants
lbd = fem.Constant(msh, ScalarType(E*nu/((1.0 + nu)*(1.0 - 2.0*nu))))
alpha = fem.Constant(msh, ScalarType(12e-6)) # thermal expansion
### Function spaces ###
degree_u = 1; degree_T = 1
el_u = VectorElement("CG", msh.ufl_cell(), degree_u, dim=2)
el_T = FiniteElement("CG", msh.ufl_cell(), degree_T)
el_m = MixedElement([el_u , el_T])
W = fem.FunctionSpace(msh, el_m)
U, _ = W.sub(0).collapse()
V, _ = W.sub(1).collapse()
def f_exp_1(t, x):
return (np.full_like(x[0], (np.pi**2)*np.sin(np.pi*x[0])*np.sin(np.pi*x[1])-
(np.pi**2)*np.cos(np.pi*x[0])*np.cos(np.pi*x[1])-alpha*np.pi*np.exp(-np.pi*t)*np.cos(np.pi*x[0])),
(np.pi**2)*np.cos(np.pi*x[0])*np.cos(np.pi*x[1])-alpha*np.pi*np.exp(-np.pi*t)*np.sin(np.pi*x[1])))
ti = time.time()
f = fem.Function(U)
f.interpolate(partial(f_exp_1,0))
tf = time.time()
print('Execution time 1: '+str(tf - ti))
def f_exp_2(t, x):
return (np.full_like(x[0], np.pi*np.exp(-np.pi*t)*np.cos(np.pi*x[0])),
np.full_like(x[0], np.pi*np.exp(-np.pi*t)*np.sin(np.pi*x[1])))
ti = time.time()
f = fem.Function(U)
f.interpolate(partial(f_exp_2,0))
tf = time.time()
print('Execution time 2: '+str(tf - ti))```
