Exporting a hexahedral region into XDMF with meshio and importing it into dolfinx
Hexahedrons are exported to XDMF:
import sys
import os
sys.path.append(os.getcwd())
import HexRegion
# A hexahedron region is built by extusion of a rectangular plane that consists of sub-rectangles
# all with the same winding order... 10 segments are extruded with each segment having a length of 10 units
# in the case cm...
hex_reg = HexRegion(10, 10, 'rect_cross_section.json', isShaderActive=False)
# Gather all hexahedrons
hexahedrons = []
materials = []
for hex_index in range(hex_reg.num_hexas()):
    hexahedron = hex_reg.getHexaVerts(hex_index)
    material = hex_reg.TAGs[hex_index]
    hexahedrons.append(hexahedron)
    materials.append(material)
# Convert to numpy array for meshio
hexahedrons = np.array(hexahedrons)
# Create a mapping from material types to integers
material_mapping = {material: idx for idx, material in enumerate(set(materials))}
encoded_materials = np.array([material_mapping[mat] for mat in materials])
# Flatten the hexahedron vertices array for meshio
points = hexahedrons.reshape(-1, 3)
cells = [("hexahedron", np.arange(hexahedrons.shape[0] * 8).reshape(-1, 8))]
# Create the mesh
mesh = meshio.Mesh(points=points, cells=cells)
# Add material data as cell data
mesh.cell_data["material"] = [encoded_materials]
# Export to a file format suitable for dolfinx
mesh.write("hexahedrons.xdmf")
# Print material mapping for reference
print("Material mapping:", material_mapping)
print("Export complete.")
The XDMF files:
importing the hexahedrons.xdmf:
	from dolfinx import mesh
	# Create an XDMFFile object for reading
	with XDMFFile(MPI.COMM_WORLD, "hexahedrons.xdmf", "r") as file:
		mesh_obj = mesh.create_mesh(MPI.COMM_WORLD, file.read_mesh())
		print("Mesh created successfully!")
	  File "/home/prusso/dolfinx-hexahedron/main.py", line 8, in <module>
	  File "/home/prusso/spack/var/spack/environments/fenicsx-env/.spack-env/view/lib/python3.11/site-packages/dolfinx/io/utils.py", line 258, in read_mesh
		cell_shape, cell_degree = super().read_cell_type(name, xpath)
	RuntimeError: <Grid> with name 'mesh' not found.
It seems that are some additional things to take into account when preparing an XDMF for the purposes of importing it into dolfinx.
So far I would like to do things in a way that will satisfy both dolfinx and PyVista.PyVista seems to squack a bit about timeframe data. Why this traceback about Grid from doflinx? How can I resolve the issue and get the XDMF file imported into dolfinx?
A bit later I found:
Mesh generation with Gmsh — DOLFINx 0.9.0.0 documentation (fenicsproject.org)
which maybe looks like a better approach to the problem of importing a custom hexahedron mesh.
gmsh.option.setNumber("Mesh.RecombinationAlgorithm", 2)
gmsh.option.setNumber("Mesh.RecombineAll", 2)
The above code is apparently what merges tetrahedrons into hexahedrons.
