Using dolfin version 2019.1.0 and (Open MPI) 2.1.1.
I am embedding Python in C++ (to get both the Python interface for FEniCs and access to mpi functions not available in mpi4py). The Expression class is giving me some trouble as follows:
Minimal example, 2 files:
min_ex.cpp
#include “mpi.h”
#include “Python.h”
#include “iostream”// compile via ““mpic++ -I /usr/include/python3.6m/ min_ex.cpp -lpython3.6m””, or similar, depending what python version you are using
int main(int argc, char *argv){
MPI_Init(&argc, &argv);
int ID_SELF;
MPI_Comm_rank(MPI_COMM_WORLD, &ID_SELF);Py_Initialize(); // Python initialize
PyRun_SimpleString("import sys; import os; sys.path.append(os.getcwd())"); PyObject *pFile = PyImport_Import(PyUnicode_FromString("py_min"));std::cout << "all done " << ID_SELF << std::endl;
Py_Finalize(); // Python finalize
std::cout << "py finalized " << ID_SELF << std::endl;
MPI_Finalize();
return 0;
py_min.py
import dolfin as dol
from mpi4py import MPImesh = dol.UnitSquareMesh(MPI.COMM_SELF, 10, 10)
V = dol.FunctionSpace(mesh, “CG”, 1)
u0 = dol.interpolate(dol.Expression(“1”, degree = 1), V)
print(‘interpolation successful’, u0)
Running this works, except for MPI_Finalize(); always giving
*** The MPI_Comm_rank() function was called after MPI_FINALIZE was invoked.
*** This is disallowed by the MPI standard.
*** Your MPI job will now abort.
The culprit for this appears to be the dol.Expression resp. interpolate. I saw that in previous FEniCs versions there was an optional parameter mpi_comm for Expressions, but it seems to have disappeared? I also tried using my own class, inherited from UserExpression, but the problem persists.
Any help would be appreciated.
