I have a mesh that looks like this:
As you can see the inner circle is labeled with 3 and outside of it with 4.
Now suppose I have a function f(x,y) that is exclusively defined on the circle. I need to extend it to a function on the whole domain such that the values of the extended function is f(x,y) inside of the circle and zero outside. Inspired by this link, I came up with the following code:
#parent mesh
mesh = Mesh('Mesh.xml')
Volume = MeshFunction('size_t' , mesh , 'Mesh_physical_region.xml' )
bnd_mesh = MeshFunction('size_t', mesh , 'Mesh_facet_region.xml')
#Submesh
Sub_Mesh=SubMesh(mesh,Volume, 3)
surface_marker = MeshFunction("size_t", Sub_Mesh, Sub_Mesh.topology().dim() - 1, 0)
volume_marker = MeshFunction("size_t", Sub_Mesh, Sub_Mesh.topology().dim())
#Function spaces
S = FunctionSpace(mesh,'P',1)
S_sub = FunctionSpace(Sub_Mesh,'P',1)
#dof and vertex maps
dofb_vb = np.array(dof_to_vertex_map(S_sub), dtype=int)
v_dof = np.array(vertex_to_dof_map(S), dtype=int)
#Function on the parent mesh and array for value assignments
ff = Function(S)
array = ff.vector().array()
#The function on the submesh
f = Expression('x[0]*x[0]',degree=0)
f_sub = project(f,S_sub)
#See what the function on the submesh looks like
File('sub_domain.pvd')<<f_sub
#Extend
array[v_dof[dofb_vb]] = f_sub.vector().array()
ff.vector()[:] = array
#See what the extension looks like
File('domain.pvd')<<ff
But the result comes out wrong. Here is the function on the submesh:
and this is what my method gives as the extension.
Could you please help me understand what the issue is?
Best,
