Hello !
I have a function defined on a submesh and I would like to extend it to the mesh that was used initially to create the submesh (with the value 0).
Here’s a MWE of what I want to do (using main branch of dolfinx)
import dolfinx, dolfinx.io, dolfinx.fem as fem, dolfinx.mesh
mesh = dolfinx.mesh.create_unit_cube(MPI.COMM_WORLD, 10, 10, 10, dolfinx.mesh.CellType.tetrahedron)
submesh_entities = dolfinx.mesh.locate_entities(mesh, dim=3, marker=lambda x: (x[0] < 0.5) & (x[1] < 0.5))
submesh, vertex_map, geom_map = dolfinx.mesh.create_submesh(mesh, mesh.topology.dim, submesh_entities)
def f_expr(x):
return x[0]
CG1_submesh = fem.FunctionSpace(submesh, ("CG", 1))
f_submesh = fem.Function(CG1_submesh)
f_submesh.interpolate(f_expr)
CG1_mesh = fem.FunctionSpace(mesh, ("CG", 1))
f_mesh = fem.Function(CG1_mesh)
f_mesh.vector.set(0.)
tree = dolfinx.geometry.BoundingBoxTree(submesh, 3)
num_entities_local = submesh.topology.index_map(3).size_local + submesh.topology.index_map(3).num_ghosts
entities = np.arange(num_entities_local, dtype=np.int32)
midpoint_tree = dolfinx.geometry.create_midpoint_tree(submesh, 3, entities)
def f_mesh_expr(x):
cells = dolfinx.geometry.compute_closest_entity(tree, midpoint_tree, submesh, x.T)
return f_submesh.eval(x.T, cells).T
f_mesh.interpolate(f_mesh_expr, cells=submesh_entities)
with dolfinx.io.XDMFFile(mesh.comm, "f_mesh.xdmf", "w") as file:
file.write_mesh(mesh)
file.write_function(f_mesh)
with dolfinx.io.XDMFFile(submesh.comm, "f_submesh.xdmf", "w") as file:
file.write_mesh(submesh)
file.write_function(f_submesh)
This code actually works and we can see the results in paraview (submesh solution on the left and extended solution on the right).
However it fails if I try to do the same with vector valued functions :
def f_expr(x):
return x
CG1_submesh = fem.VectorFunctionSpace(submesh, ("CG", 1))
CG1_mesh = fem.VectorFunctionSpace(mesh, ("CG", 1))
def f_mesh_expr(x):
We can see that the values are not correctly computed
So obviously I must be doing something wrong but I can’t figure out what that would be.
Any help would be appreciated!
Thanks
