Dear dokken,
Firstly I would like to honestly thank you for your help. Let me explain my problem. I want to solve the 2D Navier-Stokes equations in a rectangular domain. I want to strongly impose the pressure at the inlet and the outlet through Dirichlet conditions. I use P2-P0 elements for the velocity and the pressure, respectively, because I will use this code later to an FSI problem where the pressure must be discontinuous. So I found the centroids of the mesh and I store them in the inlet_DG and outlet_DG lists for the inlet and outlet respectively. Then I make a loop for the inlet and outlet in order to build the Dirichlet conditions. The problem is when I apply the BCs the index (which is just an iterative parameter in inlet_DG and outlet_DG) has the last value of the loop and hence the datum function is called for only one index. I think it would be better to mark those centroids with a MeshFunction and then to apply the Dirichlet BCs on these boundaries, but I do not know if it possible to mark points which do not belong to the mesh (as the pressure dofs are in the center of each element). Here is my code.
import sys
import time
from numericalMethod import *
import scipy.sparse as sp
# Compiler Settings
t0 = time.time()
comm = MPI.comm_world
rank = comm.Get_rank()
nprocs = comm.Get_size()
parameters['form_compiler']['optimize'] = True
parameters['form_compiler']['cpp_optimize'] = True
parameters["form_compiler"]["quadrature_degree"] = 3
parameters['form_compiler']["cpp_optimize_flags"] = '-O2 -funroll-loops'
mpi_comm_world=MPI.comm_world
PETScOptions.set("mat_mumps_icntl_14",40.0)
set_log_level(40)
# Import Meshes
mesh = Mesh()
hdf = HDF5File(mesh.mpi_comm(),"./mesh/file.h5","r")
hdf.read(mesh,"/mesh",False)
subdomains = MeshFunction("size_t",mesh,2)
hdf.read(subdomains,"/subdomains")
boundaries = MeshFunction("size_t",mesh,1)
hdf.read(boundaries,"/boundaries")
# Boundaries & Subdomains ID
boundaryIndex = {}
with open("./mesh/boundaryIndex.txt") as bi:
for i, line in enumerate(bi):
fields = line.strip().split()
boundaryIndex.update( { fields[0] : fields[1]} )
fluid = int(boundaryIndex.get('fluid'))
inlet = int(boundaryIndex.get('inlet'))
outlet = int(boundaryIndex.get('outlet'))
wall = int(boundaryIndex.get('wall'))
# Find centroids of the mesh
centroid = []
for cell_no in range(mesh.num_cells()):
coc = Cell(mesh, cell_no).midpoint()
coo = []
coo.append(coc.x())
coo.append(coc.y())
coo.append(coc.z())
centroid.append(coo)
# Store the centroids of the inlet and the outlet
inlet_DG = []
outlet_DG = []
for i in range(len(centroid)):
if (abs(centroid[i][0]-0.0041)<1.e-4):
inlet_DG.append(i)
if (abs(centroid[i][0]-0.9958)<1.e-4):
outlet_DG.append(i)
# Newton Raphson
def NewtonRaphson(res,jac,bcs_,w,corr,rank):
a_tol , r_tol = 1.0e-8, 1.0e-8
nIter = 0
bNorm = 1.0
xNorm = 1.0
relax = 1.0
while (bNorm >= r_tol and xNorm >= a_tol and nIter < 10 ) :
A = assemble(jac)
B = assemble(-res)
[bc.apply(A,B) for bc in bcs_]
Solver = LUSolver(A,"mumps")
Solver.solve(corr.vector(),B)
xNorm = corr.vector().norm('l2')
bNorm = B.norm('l2')
w.vector()[:] += relax*corr.vector()[:]
nIter += 1
if rank == 0:
print( ' iter: {0:2d} Res: {1:3.2E} Corr: {2:3.2E}'.format(nIter,bNorm,xNorm))
# Function space
V = VectorElement('CG' ,mesh.ufl_cell(),2)
P = FiniteElement('DG' ,mesh.ufl_cell(),0)
VP = FunctionSpace(mesh,MixedElement([V,P]))
phi,eta = TestFunctions(VP)
# pin points
# Set datum pressure
def datum(x, on_boundary ):
tol = 1.e-4
p = near( x[0], centroid[index][0] , tol) and near(x[1], centroid[index][1] , tol)
if ( p is True):
return (p)
# BCs
pIn = Constant(1.0)
pOut = Constant(0.0)
ns2 = Constant((0.0,0.0))
vFluidWall = DirichletBC(VP.sub(0), ns2 ,boundaries, wall )
for index in inlet_DG:
bcpIn = []
bcpInH = []
bcpIn.append( DirichletBC(VP.sub(1), pIn , datum0 ,'pointwise'))
# homogeneous bcpIn
bcpInH.append(DirichletBC(VP.sub(1), pOut , datum0 ,'pointwise'))
for index in outlet_DG:
bcpOut = []
bcpOut.append(DirichletBC(VP.sub(1), pOut , datum1,'pointwise'))
bcs = [vFluidWall] + bcpIn + bcpOut
bcsH = [vFluidWall] + bcpInH + bcpOut # homegeneous bcs
W = Function(VP)
[bc.apply(W.vector()) for bc in bcs]
u,p = split(W)
# stresses
def tau(X):
nu = Constant(0.1)
return nu*(grad(X)+grad(X).T)
def cauchy(X,P):
return -P*Identity(len(X)) + tau(X)
# weak forms
dx = Measure("dx")(subdomain_data=subdomains)
ds = Measure("ds")(subdomain_data=boundaries) # outer boundary
dS = Measure("dS")(subdomain_data=boundaries) # inner boundary
Diff = inner( cauchy(u,p) , grad(phi))*dx()
outFBC = - inner( dot( cauchy(u,p),n ),phi )*ds(outlet)
inFBC = - inner( dot( cauchy(u,p),n ),phi )*ds(inlet)
Cont = eta*div(u)*dx()
Conv = inner(grad(u)*u, phi)*dx()
Res = Diff + Cont + Conv + outFBC + inFBC
Jac = derivative(Res,W)
Corr = Function(VP)
# Solve
if rank == 0:
print( "---------------------------------------------------------------")
print( "\n")
print( "Start solving...")
print( "\n")
NewtonRaphson(Res,Jac,bcsH,W,Corr,rank)
# Export the solution
ufile = File("results/velocity.pvd")
pfile = File("results/pressure.pvd")
u,p = W.split(True)
u.rename("u","u")
p.rename("p","p")
ufile << u
pfile << p
Thank you very much
G.K.
