Facets orientation in inner surface with fenicsX
I’ve been trying to add some force on an inner surface. However, the facets seems to have incoherent orientation.
According to Integrating over an interior surface - #4 by MiroK using different mesh domains on both sides of the surface should be sufficient to get a coherent orientation. Let me introduce a MWE. The mesh is generated with gmsh and consist of two blocks of same height, one inserted in the other. I have one tag for each: tag_silicone and tag_homogeneous. I will also tag each interface surface separately. Here is the code:
tag_frame = 0
gmsh.model.occ.addBox(-1, -1, -1, 10, 10, 3, tag=tag_frame)
gmsh.model.occ.addBox(0, 0, -1, 8, 8, 3, tag=tag_frame+1)
tag_silicone = 2
tag_homogeneous = 3
gmsh.model.occ.cut([(3, tag_frame)], [(3, tag_frame+1)],tag=tag_silicone)
gmsh.model.occ.addBox(0, 0, -1, 8, 8, 3, tag=tag_homogeneous)
gmsh.model.occ.fragment([(3,tag_silicone)],[(3,tag_homogeneous)])
gmsh.model.occ.synchronize()
inner_marker_1 = 10
inner_marker_2 = 11
inner_marker_3 = 12
inner_marker_4 = 13
inner_interfaces_1=[]
inner_interfaces_2=[]
inner_interfaces_3=[]
inner_interfaces_4=[]
for surface in gmsh.model.getEntities(dim=2):
  com = gmsh.model.occ.getCenterOfMass(surface[0], surface[1])
  if (abs(com[2]-0.5)<1.e-6):
    if (abs(com[0])<1.e-6): inner_interfaces_1.append(surface[1])
    elif (abs(com[0]-8)<1.e-6): inner_interfaces_2.append(surface[1])
    elif (abs(com[1])<1.e-6): inner_interfaces_3.append(surface[1])
    elif (abs(com[1]-8)<1.e-6): inner_interfaces_4.append(surface[1])
gmsh.model.addPhysicalGroup(2, inner_interfaces_1, inner_marker_1)
gmsh.model.setPhysicalName(2, inner_marker_1, "neutral interface")
gmsh.model.addPhysicalGroup(2, inner_interfaces_2, inner_marker_2)
gmsh.model.setPhysicalName(2, inner_marker_2, "neutral interface")
gmsh.model.addPhysicalGroup(2, inner_interfaces_3, inner_marker_3)
gmsh.model.setPhysicalName(2, inner_marker_3, "neutral interface")
gmsh.model.addPhysicalGroup(2, inner_interfaces_4, inner_marker_4)
gmsh.model.setPhysicalName(2, inner_marker_4, "neutral interface")
volumes = gmsh.model.getEntities(dim=3)
silicon_marker = 11
homogeneous_marker = 12
gmsh.model.addPhysicalGroup(3, [tag_silicone], silicon_marker)
gmsh.model.setPhysicalName(3, silicon_marker, "Silicone")
gmsh.model.addPhysicalGroup(3, [tag_homogeneous], homogeneous_marker)
gmsh.model.setPhysicalName(3, homogeneous_marker, "HomogeneousMaterial")
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.15)
gmsh.model.mesh.generate(3)
gmsh.write("Box.msh")
gmsh.finalize()
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
msh = meshio.read("Box.msh")
tetra_mesh = create_mesh(msh, "tetra")
triangle_mesh = create_mesh(msh, "triangle")
meshio.write("Box.xdmf", tetra_mesh)
meshio.write("BoxT.xdmf", triangle_mesh)
Now I will compute the surface of each interface surface of 4 different manners.
  • Integrate 1dS over the corresponding domain
  • Integrate n\cdot n_0 dS where n_0 is the reference normal, and n the computed normal
  • Integrate n\cdot n_0 dS + 0 dx i.e. try the trick to add dx with subdomains to get coherent orientation of facets
  • Integrate (n\cdot n_0)^2 dS
Note: In practice, I don’t need the surface, but I have to use the normal.
The resulting script is
from weakref import ref
from dolfinx import fem, mesh
file_name = "Box.xdmf"
file_nameT = "BoxT.xdmf"
with XDMFFile(MPI.COMM_WORLD, file_name, "r") as xdmf:
  domain = xdmf.read_mesh(name="Grid")
  ct = xdmf.read_meshtags(domain, name = "Grid")
domain.topology.create_connectivity(domain.topology.dim, domain.topology.dim-1)
with XDMFFile(MPI.COMM_WORLD, file_nameT, "r") as xdmf:
  ft = xdmf.read_meshtags(domain, name = "Grid")
V = fem.VectorFunctionSpace(domain, ("CG", 2))
silicon_marker = 11
silicon_tets = ct.indices[ct.values==silicon_marker]
silicon_dofs = fem.locate_dofs_topological(V, 3, silicon_tets)
homogeneous_tets = ct.indices[ct.values==homogeneous_marker]
homogeneous_dofs = fem.locate_dofs_topological(V, 3, homogeneous_tets)
marked_tets = np.hstack([silicon_tets, homogeneous_tets])
marked_values = np.hstack([np.full(len(silicon_tets), 1, dtype = np.int32), np.full(len(homogeneous_tets), 2, dtype = np.int32)])
sorted_tets = np.argsort(marked_tets)
tet_tag = mesh.meshtags(domain, 3, marked_tets[sorted_tets], marked_values[sorted_tets])
inner_marker_1 = 10
inner_marker_2 = 11
inner_marker_3 = 12
inner_marker_4 = 13
pressure_facets_1 = ft.indices[ft.values==inner_marker_1]
pressure_facets_2 = ft.indices[ft.values==inner_marker_2]
pressure_facets_3 = ft.indices[ft.values==inner_marker_3]
pressure_facets_4 = ft.indices[ft.values==inner_marker_4]
marked_facets = np.hstack([pressure_facets_1, pressure_facets_2, pressure_facets_3, pressure_facets_4])
    np.full(len(pressure_facets_1), 0, dtype = np.int32),
    np.full(len(pressure_facets_2), 1, dtype = np.int32),
    np.full(len(pressure_facets_3), 2, dtype = np.int32),
    np.full(len(pressure_facets_4), 3, dtype = np.int32),])
facet_tag = mesh.meshtags(domain, 2, marked_facets[sorted_facets], marked_values[sorted_facets])
dS = ufl.Measure('dS', domain=domain, subdomain_data=facet_tag, metadata=metadata)
dx = ufl.Measure("dx", domain=domain, metadata=metadata, subdomain_data=tet_tag)
u = fem.Function(V)
I = ufl.variable(ufl.Identity(3))
F = ufl.variable(I+ufl.grad(u))
J = ufl.variable(ufl.det(F))
N = ufl.FacetNormal(domain)
Finv = ufl.inv(F)
n = J*Finv.T*N
vec_x = fem.Constant(domain,PETSc.ScalarType((1.0,0,0)))
vec_y = fem.Constant(domain,PETSc.ScalarType((0.0,1.0,0)))
vecs=[-vec_x,vec_x,-vec_y,vec_y]
reference = 8.0*3.0
for i in range(0,4):
    SurfaceForm_inner = fem.form(fem.Constant(domain, PETSc.ScalarType(1.))*dS(i))
    surface_inner =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_inner), op=MPI.SUM)
    SurfaceForm_inner_2 = fem.form(ufl.inner(n('-'),vecs[i])*dS(i))
    surface_inner_2 =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_inner_2), op=MPI.SUM)
    SurfaceForm_inner_3 = fem.form(ufl.inner(n('-'),vecs[i])*dS(i)+ fem.Constant(domain, PETSc.ScalarType(0.0))*dx)
    surface_inner_3 =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_inner_3), op=MPI.SUM)
    SurfaceForm_inner_4 = fem.form(ufl.inner(n('-'),vecs[i])**2*dS(i))
    surface_inner_4 =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_inner_4), op=MPI.SUM)
    print(f"Checking pressure on surface {i}: reference={reference}, {surface_inner} {surface_inner_2} {surface_inner_3} {surface_inner_4}")
Each output line should contains 4 output values, first and last should be coherent as they do not depends on the facets orientation. A correct last value should indicate the n is normal to the facet. If I understood the trick to get coherent orientation, third value should be correct.
However my output is
Checking pressure on surface 0:
   reference=24.0, 23.999999999999897 23.80972755772505 23.80972755772505 23.999999999999897
Checking pressure on surface 1:
   reference=24.0, 23.99999999999983 -18.501788312810014 -18.501788312810014 23.99999999999983
Checking pressure on surface 2:
   reference=24.0, 23.99999999999986 23.736066937512884 23.736066937512884 23.99999999999986
Checking pressure on surface 3:
   reference=24.0, 24.0 -18.570081136289787 -18.570081136289787 24.0
Any idea what am I doing wrong ?
Best
After further inspection of the source code, it seems like there is a bug that makes it impossible to order the interior facet integrals (for now).
Im working on a fix.
I found some way to fix my problem, but it does not generalize very well. As I know the real normal, I can then use the ufl conditional operator:
    n_corr=ufl.conditional(ufl.le(ufl.inner(N('+'),vecs[i]),0.0),n('-'),n('+'))
    SurfaceForm_inner = fem.form(ufl.inner(n_corr,vecs[i])*dS(i))#+ fem.Constant(domain, PETSc.ScalarType(0.0))*dx)
    print(f"Checking pressure on surface {i}: reference={reference}, {surface_inner} ")
However it works only as my normal vector is very specific (constant on each side).
I have pushed a fix: Fix consistent restriction of one-sided interior facet integrals by jorgensd · Pull Request #2127 · FEniCS/dolfinx · GitHub
Hopefully it will get merged soon, and the example in the issue should illustrate how to use the restrictions.
