Integral of inner surface wrongly evaluate to zero in 3D
I have a 3D mesh containing an inner surface, and I want to add some force on it. By inner surface, I mean a surface between two blocks.
I know how to do that with external forces.
Let me give a MWE: first generate some example with gmsh, and get the xdmf files with meshio.
tag_frame = 0
gmsh.model.occ.addBox(-1, -1, -1, 10, 10, 3, tag=tag_frame)
gmsh.model.occ.addBox(0, 0, -1, 8, 8, 3, tag=tag_frame+1)
tag_silicone = 2
tag_homogeneous = 3
gmsh.model.occ.cut([(3, tag_frame)], [(3, tag_frame+1)],tag=tag_silicone)
gmsh.model.occ.addBox(0, 0, -1, 8, 8, 3, tag=tag_homogeneous)
gmsh.model.occ.fragment([(3,tag_silicone)],[(3,tag_homogeneous)])
gmsh.model.occ.synchronize()
inner_marker = 2
xmin_marker = 3
xmin_interfaces=[]
inner_interfaces=[]
for surface in gmsh.model.getEntities(dim=2):
  com = gmsh.model.occ.getCenterOfMass(surface[0], surface[1])
  if (abs(com[0]+1)<1.e-6):
    xmin_interfaces.append(surface[1])
  elif (abs(com[2]-0.5)<1.e-6):
    if (abs(com[0])<1.e-6): inner_interfaces.append(surface[1])
    elif (abs(com[0]-8)<1.e-6): inner_interfaces.append(surface[1])
    elif (abs(com[1])<1.e-6): inner_interfaces.append(surface[1])
    elif (abs(com[1]-8)<1.e-6): inner_interfaces.append(surface[1])
print(f"Nb of left surfaces: {len(xmin_interfaces)}")
print(f"Nb of inner surfaces: {len(inner_interfaces)}")
gmsh.model.addPhysicalGroup(2, inner_interfaces, inner_marker)
gmsh.model.setPhysicalName(2, inner_marker, "neutral interface")
gmsh.model.addPhysicalGroup(2, xmin_interfaces, xmin_marker)
gmsh.model.setPhysicalName(2, xmin_marker, "xmin interface")
volumes = gmsh.model.getEntities(dim=3)
silicon_marker = 11
homogeneous_marker = 12
gmsh.model.addPhysicalGroup(3, [tag_silicone], silicon_marker)
gmsh.model.setPhysicalName(3, silicon_marker, "Silicone")
gmsh.model.addPhysicalGroup(3, [tag_homogeneous], homogeneous_marker)
gmsh.model.setPhysicalName(3, homogeneous_marker, "HomogeneousMaterial")
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.15)
gmsh.model.mesh.generate(3)
gmsh.write("Box.msh")
gmsh.finalize()
    out_mesh = meshio.Mesh(points=points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    return out_mesh
msh = meshio.read("Box.msh")
tetra_mesh = create_mesh(msh, "tetra")
triangle_mesh = create_mesh(msh, "triangle")
meshio.write("Box.xdmf", tetra_mesh)
meshio.write("BoxT.xdmf", triangle_mesh)
Now if I open BoxT.xdmf with paraview, I can seem my interfaces, everything seems good.
So let’s load this with fenicsX:
from dolfinx import fem, mesh
file_name = "Box.xdmf"
file_nameT = "BoxT.xdmf"
with XDMFFile(MPI.COMM_WORLD, file_name, "r") as xdmf:
  domain = xdmf.read_mesh(name="Grid")
domain.topology.create_connectivity(domain.topology.dim, domain.topology.dim-1)
with XDMFFile(MPI.COMM_WORLD, file_nameT, "r") as xdmf:
  ft = xdmf.read_meshtags(domain, name = "Grid")
V = fem.VectorFunctionSpace(domain, ("CG", 2))
inner_marker = 2
xmin_marker = 3
attach_facets = ft.indices[ft.values==xmin_marker]
attach_dofs = fem.locate_dofs_topological(V, 3, attach_facets)
pressure_facets = ft.indices[ft.values==inner_marker]
marked_facets = np.hstack([attach_facets, pressure_facets])
marked_values = np.hstack([
    np.full(len(attach_facets), 1, dtype = np.int32),
    np.full(len(pressure_facets), 2, dtype = np.int32)])
facet_tag = mesh.meshtags(domain, 2, marked_facets[sorted_facets], marked_values[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
SurfaceForm_inner = fem.form(fem.Constant(domain, PETSc.ScalarType(1.))*ds(2))
surface_inner =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_inner), op=MPI.SUM)
SurfaceForm_attach = fem.form(fem.Constant(domain, PETSc.ScalarType(1.))*ds(1))
surface_attach =  domain.comm.allreduce(fem.assemble_scalar(SurfaceForm_attach), op=MPI.SUM)
print(f"Checking attach surface={surface_attach}")
print(f"Checking pressure surface={surface_inner}")
The output is:
Checking attach surface=30.00000000000009
Checking pressure surface=0.0
So something is wrong, the outer surface evaluates to correct value, but inner surface gets zero . I checked that pressure_facets was not empty. Just taking one of the inner side instead also leads to zero value.
One other strange thing is that changing mesh characteristic lengths
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", 0.15)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", 0.5)
leads to PETSC ERROR: Caught signal number 11 SEGV.
Would someone have a hint how to correct this, so that I can work with inner surfaces?
Thanks
The integration measure for facets that is shared between two cells is "dS" not "ds", which is the integration measure for external facets, i.e. those only connected to a single cell.
