FEniCS Mechanics in Anaconda- OpenBLAS error
Installed FEniCS Mechanics via anaconda. Ran example codes from tutorial. When ran fourth example " Time-dependent Anisotropic Material" given in the tutorial; Few initial lines printed:
Newton iteration 0: r (abs) = 0.000e+00 (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-09)
Newton solver finished in 0 iterations and 0 linear solver iterations.
t = 0.010000
Newton iteration 0: r (abs) = 1.801e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-09)
Then following line keeps on getting printed:
OpenBLAS Warning : Detect OpenMP Loop and this application may hang. Please rebuild the library with USE_OPENMP=1 option.
When debugged, solver.full_solve() last line in examples caused it. Stepped into it and “step” function in BaseMechanicsSolver class from basemechanics.py file was last called.
import fenicsmechanics as fm
mesh_file = fm.get_mesh_file_names("ellipsoid", refinements="1000um", ext="h5")
mat_dict = {
    'const_eqn': 'guccione',
    'type': 'elastic',
    'incompressible': True,
    'density': 0.0,
    'bt': 1.0,
    'bf': 1.0,
    'bfs': 1.0,
    'C': 10.0,
    'fibers': {
        'fiber_files': mesh_file,
        'fiber_names': [['fib1', 'fib2', 'fib3'],
                        ['she1', 'she2', 'she3']],
        'elementwise': True
mesh_dict = {
    'mesh_file': mesh_file,
    'boundaries': mesh_file
formulation_dict = {
    'time': {
        'dt': 0.01,
        'interval': [0., 1.]
    'element': 'p2-p1',
    'domain': 'lagrangian',
    'bcs':{
        'dirichlet': {
            'displacement': [[0., 0., 0.]],
            'regions': [10], # Integer ID for base plane
        'neumann': {
            'regions': [20], # Integer ID for inner surface
            'types': ['pressure'],
            'values': ['10.0*t']
config = {
    'material': mat_dict,
    'mesh': mesh_dict,
    'formulation': formulation_dict
problem = fm.SolidMechanicsProblem(config)
solver = fm.SolidMechanicsSolver(problem, fname_disp='results/displacement.pvd')
solver.set_parameters(linear_solver="superlu_dist")
solver.full_solve()
