Fenics Nan for solving PDEs systems
Hi, Fenics staff and users, I had problem on solving a highly difficult PDEs system, the results are Nan. In the PDEs system, the core unknowns are x1 x2 x3 with first three equations (total 21 unknows ), while inside the PDEs system there are parameters(that is why it has 21 unknowns) expressed by x1, x2 x3, which make this PDEs system complicated. I used mixed method and weak form to solve such problem. Could any suggestions pointed out for this simulation ? Thanks for your attention !
The code are shown below
L = 1
H = 1
nx = 20
ny = 20
mesh = RectangleMesh(Point(-1, -1), Point(L, H), nx, ny)
sag = mesh.coordinates()
Initializing material parameters
k = Constant(0.82)
k1 = Constant(-0.82)
E1 = Constant(0.2)
E2 = Constant(0.2)
p = Constant(0.5)
Defining test and trial functions in splitted form
element = VectorElement(‘P’, triangle, 1, dim=21)
v = FunctionSpace(mesh, element)
q = FunctionSpace(mesh, “DG”, 0)
plot(mesh)
v_1, v_2, v_3, v_4, v_5, v_6, v_7, v_8, v_9, v_10, v_11, v_12, v_13, v_14, v_15, v_16, v_17, v_18, v_25, v_26, v_27 = TestFunctions(v)
u = Function(v)
x1, x2, x3, H, a, D, F, K, G, Y, Z, b, c, d, e, f, g, h, b11, b22, b12 = split(u)
x, y = SpatialCoordinate(mesh)
Defining boundary conditions
class left(SubDomain):
tol = 1E-14
return abs(x[0]+1) < tol
class right(SubDomain):
tol = 1E-14
return abs(x[0]-1.0) < tol
class top(SubDomain):
tol = 1E-14
return abs(x[1]-1.0) < tol
class bottom(SubDomain):
tol = 1E-14
return abs(x[1]+1.0) < tol
class middleX(SubDomain):
tol = 1E-14
return abs(x[0]) < tol
class middleY(SubDomain):
tol = 1E-14
return abs(x[1]) < tol
facets = MeshFunction(“size_t”, mesh, 1)
facets.set_all(0)
left().mark(facets, 1)
right().mark(facets, 2)
top().mark(facets, 3)
bottom().mark(facets, 4)
middleX().mark(facets, 5)
middleY().mark(facets, 6)
ds = Measure(“ds”, subdomain_data=facets)
def boundary(x, on_boundary):
return on_boundary
Boundary Conditions
u_R = Expression(‘x[1]’, degree=1)
u_R1 = Expression(‘x[0]’, degree=1)
bc = [
DirichletBC(v.sub(2),Constant(0),facets,1),
DirichletBC(v.sub(2),Constant(0),facets,2),
DirichletBC(v.sub(2),Constant(0),facets,3),
DirichletBC(v.sub(2),Constant(0),facets,4),
DirichletBC(v.sub(0),u_R1,facets,1),
DirichletBC(v.sub(0),u_R1,facets,2),
DirichletBC(v.sub(1),u_R,facets,3),
DirichletBC(v.sub(1),u_R,facets,4),
DirichletBC(v.sub(0),u_R1, facets, 5),
DirichletBC(v.sub(1),u_R, facets, 6),
DirichletBC(v.sub(3),Constant(0),facets,1),
DirichletBC(v.sub(3),Constant(0),facets,2),
DirichletBC(v.sub(3),Constant(0),facets,3),
DirichletBC(v.sub(3),Constant(0),facets,4),
# DirichletBC(V.sub(1), Expression(‘(1-(-0.1751*x[0]x[0]+0.1741))‘, degree =2 ), facets, 3), # Emperical BC applied at the upper and lower edges.
# DirichletBC(V.sub(1), Expression(’(-0.1751
x[0]*x[0]+0.1741)’, degree =2 ), facets, 4)] # Emperical BC applied at the upper and lower edges.
Define source terms
f_1 = project(-kaDH.dx(0)+2kaFH.dx(0)-kaGH.dx(1),q)
f_2 = 0.5E2(D-1)(x1.dx(0)f+x2.dx(0)g+x3.dx(0)h)
f_3 = project(0.5
E2
(D-1)
(x1.dx(1)f+x2.dx(1)g+x3.dx(1)h),q)
f_4 = project((D
b11-2
F
b12+G
b22)pow(a,-1.5),q)
f_5 = project((D
G-F*F),q)
f_6 = project((x1.dx(1)*x1.dx(1)+x2.dx(1)*x2.dx(1)+x3.dx(1)*x3.dx(1)),q)
f_7 = project((x1.dx(0)*x1.dx(1)+x2.dx(0)x2.dx(1)+x3.dx(0)x3.dx(1)),q)
f_8 = project((b22
b11-b12
b12)*pow(a,-2),q)
f_9 = project((x1.dx(0)*x1.dx(0)+x2.dx(0)*x2.dx(0)+x3.dx(0)x3.dx(0)),q)
f_10 = project(x1.dx(0),q)
f_11 = project(x2.dx(0),q)
f_12 = project(x3.dx(0),q)
f_13 = project(x1.dx(0),q)
f_14 = project(x2.dx(0),q)
f_15 = project(x3.dx(0),q)
f_16 = project(x1.dx(1),q)
f_17 = project(x2.dx(1),q)
f_18 = project(x3.dx(1),q)
f_25 = project((Y
(x2.dx(0)*x3.dx(1)-x2.dx(1)x3.dx(0))+Z(x1.dx(1)*x3.dx(0)-x1.dx(0)x3.dx(1))+b(x1.dx(0)*x2.dx(1)-x2.dx(0)x1.dx(1))),q)
f_26 = project((f
(x2.dx(0)*x3.dx(1)-x2.dx(1)x3.dx(0))+g(x1.dx(1)*x3.dx(0)-x1.dx(0)x3.dx(1))+h(x1.dx(0)*x2.dx(1)-x2.dx(0)x1.dx(1))),q)
f_27 = project((c
(x2.dx(0)*x3.dx(1)-x2.dx(1)x3.dx(0))+d(x1.dx(1)*x3.dx(0)-x1.dx(0)x3.dx(1))+e(x1.dx(0)*x2.dx(1)-x2.dx(0)*x1.dx(1))),q)
Define variational problem
FF = -(aDv_1.dx(0)H.dx(0)+v_1a.dx(0)DH.dx(0)+v_1aD.dx(0)H.dx(0))kdx
+2
(v_1.dx(1)aFH.dx(0)+v_1a.dx(1)FH.dx(0)+v_1aF.dx(1)H.dx(0))kdx-(v_1.dx(1)aGH.dx(1)+v_1a.dx(1)GH.dx(1)+v_1aG.dx(1)H.dx(1))kdx
-v_1
D
(H.dx(0)(Y(x1.dx(0)D-x1.dx(1)F)+Z(x2.dx(0)D-x2.dx(1)F)+b(x3.dx(0)D-x3.dx(1)F))+H.dx(1)(Y(-x1.dx(0)F+x1.dx(1)G)+Z(-x2.dx(0)F+x2.dx(1)G)+b(-x3.dx(0)F+x3.dx(1)G)))kdx
+v_1
2
F
(H.dx(0)
(c
(x1.dx(0)D-x1.dx(1)F)+d(x2.dx(0)D-x2.dx(1)F)+e(x3.dx(0)D-x3.dx(1)F))+H.dx(1)(c(-x1.dx(0)F+x1.dx(1)G)+d(-x2.dx(0)F+x2.dx(1)G)+e(-x3.dx(0)F+x3.dx(1)G)))kdx
-v_1
G
(H.dx(0)
(f
(x1.dx(0)D-x1.dx(1)F)+g(x2.dx(0)D-x2.dx(1)F)+h(x3.dx(0)D-x3.dx(1)F))+H.dx(1)(f(-x1.dx(0)F+x1.dx(1)G)+g(-x2.dx(0)F+x2.dx(1)G)+h(-x3.dx(0)F+x3.dx(1)G)))kdx
+v_1
(4
k
pow(a,2)pow(H,3)+2(k1-k)Hpow(a,2)K)dx
-2
v_1
pow(a,2)H(k
H
H+k1
K+E1/8
(G-1)
(G-1)+E2/8
(D-1)(D-1))dx
-0.5
v_1
E1*(G-1)(Y(x2.dx(0)x3.dx(1)-x2.dx(1)x3.dx(0))+Z(x1.dx(1)x3.dx(0)-x1.dx(0)x3.dx(1))+b(x1.dx(0)x2.dx(1)-x2.dx(0)x1.dx(1)))pow(a,1.5)dx
-0.5
v_1
E2
(D-1)
(f
(x2.dx(0)x3.dx(1)-x2.dx(1)x3.dx(0))+g(x1.dx(1)x3.dx(0)-x1.dx(0)x3.dx(1))+h(x1.dx(0)x2.dx(1)-x2.dx(0)x1.dx(1)))pow(a,1.5)dx
-v_1
p
pow(a,2)dx
-v_2
(E1
0.5
(G-1)
(x1.dx(0)Y+x2.dx(0)Z+x3.dx(0)b)+E20.5(D-1)(x1.dx(1)c+x2.dx(1)d+x3.dx(1)e)+0.5E1G.dx(0)G+0.5E1(G-1)
(x1.dx(0)Y+x2.dx(0)Z+x3.dx(0)b)+0.5E2D.dx(1)F)dx
-v_3
(E1
0.5
(G-1)
(x1.dx(0)c+x2.dx(0)d+x3.dx(0)e)+E20.5(D-1)(x1.dx(1)f+x2.dx(1)g+x3.dx(1)h)+0.5E1G.dx(0)F+0.5E1(G-1)(x1.dx(1)Y+x2.dx(1)Z+x3.dx(1)b)+0.5E2D.dx(1)D)dx+(v_4H)dx+(v_5a)dx+(v_6D)dx+(v_7F)dx+(v_8K)dx+(v_9G)dx+(v_10Y+v_10.dx(0)x1.dx(0))dx+(v_11Z+v_11.dx(0)x2.dx(0))dx+(v_12b+v_12.dx(0)x3.dx(0))dx+(v_13c+v_13.dx(1)x1.dx(0))dx+(v_14d+v_14.dx(1)x2.dx(0))dx+(v_15e+v_15.dx(1)x3.dx(0))dx+(v_16f+v_16.dx(1)x1.dx(1))dx+(v_17g+v_17.dx(1)x2.dx(1))dx+(v_18h+v_18.dx(1)x3.dx(1))dx+(v_25b11)dx+(v_26b22)dx+(v_27b12)dx-f_01v_1ds(1)-f_1v_1ds- f_2v_2dx -f_3v_3dx- f_4v_4dx - f_5v_5dx - f_6v_6dx-f_7v_7dx -f_8v_8dx -f_9v_9dx -f_10v_10ds-f_11v_11ds-f_12v_12ds-f_13v_13ds-f_14v_14ds-f_15v_15ds-f_16v_16ds-f_17v_17ds-f_18v_18ds-f_25v_25dx-f_26v_26dx-f_27v_27*dx
##PICARD Iteration
u_ = Expression((‘0.01’,‘0.01’,‘0.01’,‘0.01’,‘1.0’,‘1.0’,‘0.01’,‘0.01’,‘1.0’,‘0.01’,‘0.01’,‘0.01’,‘0.01’,‘0.01’,‘0.01’,‘0.01’, ‘0.01’,‘0.01’,‘1’,‘1’,‘1’), degree =1)
u_k= interpolate(u_,v)
eps = 1.0
tol = 1.0E-2
iter = 0
maxiter = 1
while eps > tol and iter < maxiter:
iter +=1
solve(FF == 0, u, bc)
diff = u.vector().get_local() - u_k.vector().get_local()
eps = np.linalg.norm(diff, ord=np.Inf)
print ('iter= ', iter )
print ('eps= ', eps)
u_k.assign(u)
Best,
Your code is too long for me to parse, but consider the tips and ticks here: Default absolute tolerance and relative tolerance - #4 by nate
Also consider walking before you can run. By this I mean, start with a small simple system making sure that works; and, gradually add complexity until you reach your final full model.
Thanks for your attention and review on my problem !
