Hello, I’m quite new to FEniCS and I’m encoutering a problem with my program. I’m calculating the displacement of an elastic membrane under internal pressure.
I can vary different parameters such as the pressure of the number of iterations. When the values are not too big, the program works fine and I get very nice plots.
However if I increase the pressure or the meshSize or the number of iterations too much. The displacement vector becomes NaN everywhere.
And I don’t know exactly why.
Do you have any idea of how I could solve this - as a beginner ?
Here’s my code and the plots I get when the values are too high and when they are the working range
from future import print_function
%matplotlib notebookConstants
Re = 12
Ri = 9
p = 220
dP = 5000
H = 9
Hinv = Re - Hiterations = 89
meshSize = 2
E_tip = 1e5
ratio = 10
E_side = E_tip*ratio
tol = 0.1Create Domain & Mesh
domain = Circle(Point(0., 0.), Re, 100) - Circle(Point(0., 0.), Ri, 100)
domain = domain - Rectangle(Point(Re, 0.), Point(-Re, -Re))
+ Rectangle(Point(Ri, -10), Point(Re, 0))
+ Rectangle(Point(-Ri,-10),Point(-Re,0))
#domain = domain + Circle(Point(0., 0.), Ri, 100) + RCreate Mesh
mesh = generate_mesh(domain, meshSize)
meshBeforeContraction = generate_mesh(domain, meshSize)
originalMesh = generate_mesh(domain, meshSize)Set Subdomains and Mark Subdomains
tipDomain = CompiledSubDomain(‘x[0]*x[0] + x[1]x[1] + tol >= RiRi
&& x[0]*x[0] + x[1]x[1] - tol <= ReRe && x[1]>=0- tol &&x[1]>=Hinv-tol
||(x[1] <= 0 + tol &&x[1]>=Hinv && abs(x[0])<=Re+tol && abs(x[0])>=Ri -tol)’,
tol=tol, Hinv=Hinv, Re=Re, Ri=Ri)
sideDomain = CompiledSubDomain('x[1] <= Hinv + tol && x[0]<=Re && x[0]>=Ri -tol ',
tol=tol, Hinv=Hinv, Re=Re, Ri=Ri)subdomains = MeshFunction(‘size_t’, mesh, mesh.topology().dim(), 0)
subdomains.set_all(4)
tipDomain.mark(subdomains, 5)Create Boundaries
class Bottom(SubDomain):
return near(x[1], -10) and on_boundaryclass Inner(SubDomain):
return (near(sqrt(x[0]**2+x[1]**2), Ri, 1e-1) and x[1] > Hinv and on_boundary)
or (near(x[0], Ri) and x[1] > -10 and x[1] < 0 and on_boundary)class InnerHard(SubDomain):
return (near(sqrt(x[0]**2+x[1]**2), Ri, 0.5) and x[1]-tol <= Hinv and x[1] + tol >= 0 and on_boundary)
or (near(abs(x[0]), Ri) and x[1]+tol >= -10 and x[1]-tol <= 0 and x[1]+tol <= Hinv and on_boundary)class InnerSoft(SubDomain):
return (near(sqrt(x[0]**2+x[1]**2), Ri, 0.5) and x[1] >= Hinv and x[1] >= 0 and on_boundary)
or (near(abs(x[0]), Ri) and x[1] >= -10 and x[1] <= 0 and x[1] >= Hinv and on_boundary)Mark facets
facets = MeshFunction(“size_t”, mesh, 1)
facets.set_all(0)
Bottom().mark(facets, 1)
Inner().mark(facets, 3)
InnerHard().mark(facets, 31)
InnerSoft().mark(facets, 32)ds = Measure(“ds”, subdomain_data=facets)
Young Modulus
class Young(UserExpression):
def init(self, subdomains, tip, side, **kwargs):
super().init(**kwargs)
self.subdomains = subdomains
self.side = side
self.tip = tipdef eval_cell(self, values, x, cell): if self.subdomains[cell.index] == 4: values[0] = self.side else: values[0] = self.tipx = SpatialCoordinate(mesh)
Define constants stress/stain :
E = Young(subdomains=subdomains, side=E_side, tip=E_tip, degree=0)
nu = Constant(0.3)
mu = E/2/(1+nu)
lmbda = Enu/(1+nu)/(1-2nu)Define Strain Tenosr
def eps(v):
return sym(as_tensor([[v[0].dx(0), 0, v[0].dx(1)],
[0, v[0]/x[0], 0],
[v[1].dx(0), 0, v[1].dx(1)]]))Define Stress
‘’‘3D hookes law formula of stress’‘’
def sigma(v):
return lmbdatr(eps(v))Identity(3) + 2.0mueps(v)n = FacetNormal(mesh)
V = VectorFunctionSpace(mesh, ‘CG’, degree=2)
V_original = VectorFunctionSpace(originalMesh, ‘CG’, degree=2)
du = TrialFunction(V)
u_ = TestFunction(V)
a = inner(sigma(du), eps(u_))*x[0]dx
l = inner(-pn, u_)*x[0]ds(31) + inner(-pn, u_)*x[0]*ds(32)u = Function(V, name=“Displacement”)
u_original = Function(V_original, name=“original position”)‘’‘THIS IS THE INTERESTING BOUNDARY CASE’‘’
bcs2 = [DirichletBC(V, Constant((0., 0.)), facets, 1)]
#fid = File(“viz/solution.pvd”)
for i in range(0, iterations):
solve(a == l, u, bcs2)
# u.rename(“u”, “u”) #see the QA reported below.
#fid << u, iALE.move(mesh, u) meshBeforeContraction = Mesh(mesh)plt.figure()
#plot(mesh, linewidth=0.2)
plot(originalMesh, linewidth=0.2)
p2 = plot(u, mode=“displacement”)
plt.colorbar(p2)
plt.axhline(y=Hinv, color=‘b’, linestyle=‘–’)plt.show()
plt.title(‘Model before contraction ;’ + 'H = ’ + str(H))
Thank you so much in advance
