Hello everyone,
My GMSH meshing exercise seems to produce a good mesh, as seen in the GMSH GUI, but the model_to_mesh conversion process chokes, producing a segmentation fault.
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
The code I used is as follows:
import sys
from scipy import optimize as opt
from mpi4py import MPI as nMPI
from dolfinx.mesh import locate_entities_boundary, meshtags
from dolfinx.io import gmshio
from dolfinx import fem
def Model(x):
   comm = nMPI.COMM_WORLD
   mpiRank = comm.rank
   modelRank = 0 # Where GMSH runs
   h = x[0] # cavity depth
   r = x[1] # cavity radius
   rgp = x[2] # Ground plane (and rad sphere) radius
   bl = x[3] # Bowtie length
   bt = x[4] # Metal thickness
   ba = x[5] # Bowtie width
   bx = x[6] # x offset of bowtie
   hd = x[7] # Dielectric thickness
   k0 = x[8] # Wavenumber
   eps = x[9] # Dk of dielectric
   lc = x[10] # Coax len
   rc = x[11] # coax shield rad
   rcc = x[12] # coax center cond rad
   rco = x[13] # coax center cond offset
   eta0 = 377.0
   mmin = 0.02
   mmax = 1.0
   err = 1.0e-3
   lm = 0.5
   ls = 0.025
   lq = 0.1
   if mpiRank == modelRank:
       print("Cavity height = {0:<f}, Cavity radius = {1:<f}, Rad shpere radius = {2:<f}".format(h, r, rgp))
       print("Bowtie Len = {0:<f}, Bowtie metal thickness = {1:<f}, Bowtie width = {2:<f}".format(bl, bt, ba))
       print("Bowtie x offset = {0:<f}, Diel thickness = {1:<f}, Wavenumber = {2:<f}, Dk = {3:<f}".format(bx, hd, k0, eps))
       gmsh.option.setNumber('General.Terminal', 0)
       gmsh.model.add("BowtieAnt")
       gmsh.model.setCurrent("BowtieAnt")
       RadSphere = gmsh.model.occ.addSphere(0, 0, 0, rgp, 1)
       Box1 = gmsh.model.occ.addBox(0, -rgp, 0, rgp, 2*rgp, rgp, 2)
       PCB = gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, hd, r, 7, angle=np.pi)
       Cavity = gmsh.model.occ.addCylinder(0, 0, -h, 0, 0, h, r, 8, angle=np.pi)
       CoaxShield = gmsh.model.occ.addCylinder(rco, 0, -h-lc, 0, 0, lc, rc, 9, angle=2*np.pi)
       CoaxCenter = gmsh.model.occ.addCylinder(rco, 0, -h-lc, 0, 0, h+lc+hd+bt/2, rcc, 10, angle=2*np.pi)
       gmsh.model.occ.rotate([(3,7),(3,8)], 0, 0, 0, 0, 0, 1, -np.pi/2)
       RadZone = gmsh.model.occ.intersect([(3,1)], [(3,2)], 3, removeObject=True, removeTool=True)
       print(RadZone)
       Bowtie1= gmsh.model.occ.addWedge(0, 0, hd, bl, ba, bt, 4, ltx=0)
       gmsh.model.occ.mirror([(3,4)], 0, 1, 0, 0)
       Bowtie2= gmsh.model.occ.addWedge(0, 0, hd, bl, ba, bt, 5, ltx=0)
       Bowtie = gmsh.model.occ.fuse([(3,4)], [(3,5)], 6, removeObject=True, removeTool=True)
       gmsh.model.occ.rotate([(3,6)], 0, 0, 0, 0, 0, 1, np.pi)
       gmsh.model.occ.translate([(3,6)], bl+bx, 0, 0) # Bowtie metal finished
       Metal = gmsh.model.occ.fuse([(3,6)], [(3,10)], 11, removeObject=True, removeTool=True)
       RadZoneFinal = gmsh.model.occ.cut([(3,3)], [(3,11)], 12, removeObject=True, removeTool=False)
       PCBFinal = gmsh.model.occ.cut([(3,7)],[(3,11)], 13, removeObject=True, removeTool=False)
       CavityAndCoax = gmsh.model.occ.fuse([(3,8)], [(3,9)], 14, removeObject=True, removeTool=True)
       CavityAndCoaxFinal = gmsh.model.occ.cut([(3,14)], [(3,11)], 15, removeObject=True, removeTool=True)
       gmsh.model.occ.fragment([(3,12),(3,13),(3,15)], [], -1)
       gmsh.model.occ.synchronize()
       gmsh.option.setNumber('Mesh.MeshSizeMin', mmin)
       gmsh.option.setNumber('Mesh.MeshSizeMax', mmax)
       gmsh.option.setNumber('Mesh.Algorithm', 6) #1=Mesh Adapt, 2=Auto, 3=Initial mesh only, 5=Delaunay, 6=Frontal-Delaunay
       gmsh.option.setNumber('Mesh.MshFileVersion', 2.2)
       gmsh.option.setNumber('Mesh.Format', 1)
       #gmsh.option.setNumber('Mesh.Smoothing', 100)
       gmsh.option.setNumber('Mesh.MinimumCirclePoints', 36)
       gmsh.option.setNumber('Mesh.CharacteristicLengthFromCurvature', 1)
#Set max mesh size
       pt = gmsh.model.getEntities(0)
       gmsh.model.mesh.setSize(pt, lm)
       print(pt)
# Set denser mesh along bowtie metal edges
       pt = gmsh.model.getEntitiesInBoundingBox(bx-err, -ba-err, hd-err, bl+bx+err, ba+err, hd+bt+err)
       print(pt, ls)
       gmsh.model.mesh.setSize(pt,ls)
# Set mesh density along coax
       pt = gmsh.model.getEntitiesInBoundingBox(rco-rcc-err, -rcc-err, hd-err, rcc+rco+err, rcc+err, hd+err)
       print(pt, lq)
       gmsh.model.mesh.setSize(pt,lq)
       pt = gmsh.model.getEntitiesInBoundingBox(rco-rc-err, -rc-err, -lc-h-err, rc+rco+err, rc+err, err)
       print(pt, lq)
       gmsh.model.addPhysicalGroup(3, [12], 1)
       gmsh.model.addPhysicalGroup(3, [13], 2)
       gmsh.model.addPhysicalGroup(3, [15], 3)
       gmsh.model.setPhysicalName(3, 1, "RadZone")
       gmsh.model.setPhysicalName(3, 2, "PCB")
       gmsh.model.setPhysicalName(3, 3, "Cavity")
# set mesh density along dielectric
       gmsh.model.mesh.setTransfiniteCurve(13, 200, meshType="Progression", coef=1.0)
       gmsh.model.mesh.setTransfiniteCurve(15, 200, meshType="Progression", coef=1.0)
# Reduce mesh density on bowtie surface
       P1 = gmsh.model.occ.addPoint(bx+bl/3, 0, hd, lm, tag=100)
       P2 = gmsh.model.occ.addPoint(bx+bl/3, 0, hd+bt, lm, tag=101)
       P3 = gmsh.model.occ.addPoint(bx+2*bl/3, -ba/3, hd, lm, tag=102)
       P4 = gmsh.model.occ.addPoint(bx+2*bl/3, ba/3, hd, lm, tag=103)
       P5 = gmsh.model.occ.addPoint(bx+2*bl/3, -ba/3, hd+bt, lm, tag=104)
       P6 = gmsh.model.occ.addPoint(bx+2*bl/3, ba/3, hd+bt, lm, tag=105)
       gmsh.model.mesh.embed(0, [P2,P5,P6], 2, 10)
       gmsh.model.mesh.embed(0, [P1,P3,P4], 2, 14)
       bb = gmsh.model.getEntities(dim=3)
       pt = gmsh.model.getBoundary(bb, combined=True, oriented=False, recursive=False)
       print(pt)
       inportA = []
       radA = []
       pecA =[]
       for bnd in pt:
          CoM = gmsh.model.occ.getCenterOfMass(bnd[0], bnd[1])
          print(CoM)
          if np.allclose(CoM, [rco, 0, -h-lc]): # Coax input port
              inportA.append(bnd[1])
          elif (np.abs(CoM[0]) < err) or (CoM[2] < hd + bt + err):
              pecA.append(bnd[1])
              radA.append(bnd[1])
       print(inportA, pecA, radA)
       gmsh.model.addPhysicalGroup(2, pecA, 1)
       gmsh.model.setPhysicalName(2, 1, "PEC")
       gmsh.model.addPhysicalGroup(2, inportA, 2)
       gmsh.model.setPhysicalName(2, 2, "Inlet")
       gmsh.model.addPhysicalGroup(2, radA, 3)
       gmsh.model.setPhysicalName(2, 3, "Radiation")
       gmsh.model.mesh.generate(3)
       gmsh.model.mesh.optimize("Gmsh")
       gmsh.fltk.run()
#XXXXX Program dies here XXXXXX
   mesh, ct, fm = gmshio.model_to_mesh(gmsh.model, comm, modelRank, gdim=3)
#XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
       gmsh.finalize()
   return 0
xin = np.array([1.5, 4.0, 8.0, 3.0, 0.05, 1.0, 0.20, 0.25, 1.25, 3.6, 1.0, 0.23, 0.1, 0.6])
res = Model(xin)
sys.exit(0)
Does anyone have an idea where this fault may lie?
Bill
