SEGV fault when interpolating function onto different mesh
I am trying to interpolate a function defined on one mesh onto another mesh in dolfinx 0.7.3. When doing so, I get the following error:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 59.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
I have installed dolfinx (with complex numbers) using conda: conda create -n testenv -c conda-forge fenics-dolfinx petsc=*=complex*
Here is a minimal example reproducing the error:
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-10,-10],[10,10]],[20,20])
V = dolfinx.fem.functionspace(mesh,('CG',1,))
F=dolfinx.fem.Function(V)
F.interpolate(lambda x: x[0],)
new_mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-10,-10],[10,10]],[10,10])
Vnew = dolfinx.fem.functionspace(new_mesh,('CG',1,))
Fnew=dolfinx.fem.Function(Vnew)
Fnew.interpolate(F) # SEGV happens here.
See: dolfinx/python/test/unit/fem/test_interpolation.py at v0.7.3 · FEniCS/dolfinx · GitHub for the up to date syntax
Thanks for the quick reply!
I managed to not get an exception anymore, but the resulting interpolated function does not at all look like what one would expect.
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-10,-10],[10,10]],[100,100])
F.interpolate(lambda x: x[0])
new_mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-10,-10],[10,10]],[4,4])
interp_data = dolfinx.fem.create_nonmatching_meshes_interpolation_data(F.function_space.mesh._cpp_object,F.function_space.element,Fnew.function_space.mesh._cpp_object,padding=1e-14)
Fnew.interpolate(F,nmm_interpolation_data=interp_data)
Fnew.x.scatter_forward()
print(np.real(Fnew.vector.getArray()))
print(new_mesh.geometry.x[:,0])
This outputs
[ 9.8 10.  10.   9.8  9.6 10.   9.6  9.8  9.4 10.   9.2  9.4  9.6  9.2
 10.   9.6  9.2  9.4  9.2  9.6  9.  10.   9.   9.2  9.2]
[  5.  10.  10.   5.   0.  10.   0.   5.  -5.  10.  -5.   0.   5. -10.
  10. -10.  -5.   0.   5. -10.  -5.   0. -10.  -5. -10.]
Am I doing something wrong? In my real code I want to interpolate a F from a large domain with many points to a Fnew on a smaller domain (with fewer points) and in that case I still get a SEGV fault when I increase the resolution of the smaller mesh. For low resolution, where it doesn’t throw an error, the values of Fnew are orders of magnitude larger than the values of F (both the real and imaginary components of Fnew although F only produces real numbers). Increasing the resolution of the smaller mesh slightly increases the values of Fnew as well…
I would increase the padding to 1e-6 or something of that magnitude and see if it helps.
Unfortunately, increasing the padding did not change anything.
I managed to make a MWE that gives a SEGV fault when the resolution of the smaller mesh is increased: The following code,
mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-100,-100],[100,100]],[100,100])
N_points = 100
new_mesh = dolfinx.mesh.create_rectangle(MPI.COMM_WORLD,[[-10,-10],[10,10]],[N_points,N_points])
interp_data = dolfinx.fem.create_nonmatching_meshes_interpolation_data(F.function_space.mesh._cpp_object,F.function_space.element,Fnew.function_space.mesh._cpp_object,padding=1e-6)
Fnew.interpolate(F,nmm_interpolation_data=interp_data) # SEGV fault happens here if N_points > 100
import pyvista
p = pyvista.Plotter()
topology, cell_types, x = dolfinx.plot.vtk_mesh(Vnew)
grid = pyvista.UnstructuredGrid(topology, cell_types, x)
grid['u'] =np.real(Fnew.vector.getArray()[:])
grid.set_active_scalars('u')
warped=grid.warp_by_scalar('u')
p.show_bounds(use_3d_text=False)
p.add_mesh(warped,scalars='u')
p.show()
produces the plot:
But I get the following error if I set N_points to 101 (or anything above 100)
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Am I somehow mixing up the meshes unintentionally?
nvm this,
should have been,
interp_data = dolfinx.fem.create_nonmatching_meshes_interpolation_data(Fnew.function_space.mesh._cpp_object,Fnew.function_space.element,F.function_space.mesh._cpp_object,padding=1e-6)
It works with this change. Thanks again!
