Finding breaking force based on maximum principal stress from a linear elastic model
If I run a linear elastic model without body forces, and I apply a load of 1N in the same location and fix another location, I can use the resulting maximum principal stress at 1N to extrapolate what force will cause a maximum principal stress (MPS) that causes the brittle material to fail (s_f).
Is it possible to find this force in “one shot” using linearity if a body force is included?
The FE matrix system in this case is:
Ku = F_{body} + F_{applied}
If I am interested in one particular location, I think I could use the stress at 0N applied load (s_0), and the stress at 1N applied load (s_1), while having a body force, and calculate the breaking force using:
F_{break} = \frac{s_f-s_0}{s_1-s_0}
However, since the point of MPS being equal to s_f, at the right F_{break} is unknown before hand, I think this makes the problem nonlinear and can only be solved iterating the force until the force causes s_f. Is this correct? Is there a way of using linearity to not use an iterative method?
Thank you,
Alex
