I am working on an optimization problem, which finds the optimized material property while part of the material property is fixed. See following for an example code with poisson’s equation and some illustrations.
In the above drawing, kappa2 is meant to be an area with a constant value, while kappa1 takes the form of any function input. Note that using an expression with a conditional statement would not work properly in my optimization implementation.
One way I’m picturing the implementation be something like this: kappa = kappa1+kappa2, where kappa1 only defines in the purple subdomain, and kappa2 only defines in the yellow subdomain.
I am struggling how to make this implementation work, any advice is appreciated.
from mshr import*
domain = Rectangle(Point(0., 0.), Point(1., 1.))
domain.set_subdomain(1, Rectangle(Point(0.6, 0.1), Point(0.8, 0.3)) )
mesh = generate_mesh(domain, 30)
mf = MeshFunction("size_t", mesh, 2, mesh.domains())
fig = plt.figure(figsize=(6.4*2,4.8*2),dpi=800)
plot(mesh, "2D mesh")
plot(mf, "Subdomains")
def boundary(x):
return x[0] < DOLFIN_EPS or x[0] > 1.0 - DOLFIN_EPS
u0 = Constant(0.0)
bc = DirichletBC(V, u0, boundary)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2)
g = Expression("sin(5*x[0])", degree=2)
kappa = Function(V)
a = inner( kappa* grad(u), grad(v))*dx
L = f*v*dx + g*v*ds
Forward = a-L
