I am trying to use SFEpy to simulate a simple 1 D sedimentation problem which I do have an analytical solution for. I am getting a lot of instability in my solutions. The part of the solution in the lower radial range looks OK but near the bottom of the range there is so much instability. I tried implement a crank-nicolson scheme but it didn’t make a difference so I left it out here to keep the code simple. Any help I could get on this would be much appreciated!
Here is my example solution. The analytical solution would look like a step function for each timepoint.
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
# Parameters
s_svedberg = 20 # Sedimentation coefficient (s)
s_s = s_svedberg * 10 ** (-13) # Convert to seconds
rpm = 30000 # Rotations per minute
omega_rad_per_s = 2 * np.pi * rpm / 60 # Angular velocity (rad/s)
t_s = 0.0 # start time
T_s = 1500.0 # Total simulation time (s)
num_steps = 1500 # Number of time steps
dt_s = T_s / num_steps # Time step size (s)
# Define the radial positions
r_min_cm = 6.2 # Minimum radial position (cm)
r_max_cm = 7.2 # Maximum radial position (cm)
domain = mesh.create_interval(MPI.COMM_WORLD, nx=100, points=[r_min_cm, r_max_cm])
V = fem.functionspace(domain, ("Lagrange", 1))
# Concentration at the previous time step
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.x.array[:] = 1 # initial concentration
# Define solution variable
c = fem.Function(V) # Concentration at the current time step
r = ufl.SpatialCoordinate(domain)[0] # Radial coordinate
# Strong form of the equation: dc/dt = -s * omega^2 * (r * dc/dr + 2c)
a = u *v* ufl.dx - dt_s * s_s * omega_rad_per_s**2 * (2 * u * v * ufl.dx + u * r * ufl.grad(v)[0] * ufl.dx)
L = u_n * v * ufl.dx
# ## Preparing linear algebra structures for time dependent problems
bilinear_form = fem.form(a)
linear_form = fem.form(L)
# Create PETSc matrix and vector for the system
A = assemble_matrix(bilinear_form)
b = create_vector(linear_form)
# Create a PETSc solver
solver.setOperators(A)
# Store solutions at 20 evenly spaced time points
time_points = np.linspace(0, T_s, 20)
solutions = []
# Time-stepping loop
for n in range(num_steps):
t_s += dt_s
# Assemble the right-hand side vector
with b.localForm() as b_local:
b_local.set(0.0)
assemble_vector(b, linear_form)
# Solve the linear system
solver.solve(b, c.x.petsc_vec)
c.x.scatter_forward()
# Update previous solution
u_n.x.array[:] = c.x.array.copy()
# Save solution at the specified time points
if n % (num_steps // 20) == 0:
solutions.append((t_s, c.x.array.copy()))
# Plot solution using Matplotlib
if domain.comm.rank == 0:
r_coords_cm = domain.geometry.x[:, 0] # Radial coordinates (x-axis, in cm)
plt.figure()
for t_s, c_values in solutions:
plt.plot(r_coords_cm, c_values, label=f"t = {t_s:.0f} s")
plt.ylim(-0.01, 10.1)
plt.xlabel("Radial Position (cm)")
plt.ylabel("Concentration")
plt.legend()
plt.grid(True)
